2015 Tacoma 2" Leveling Lift Kit Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Michael_Westen, Oct 18, 2017.
  1. Oct 18, 2017 at 7:59 AM
    Chase8059
    Chase8059 Kinda Well-Known
    Chase
    ESVA
    2015 DCSB TRD Sport | Super White : 2008 Lexus IS 350
    OME 887, JBA UCAs, 1.5 AAL, Fox 2.0 RR w CD adj., SCS SR8s Gunmetal, Falken AT3/W 265/70r17
    If you get a new coil paired with the 5100 shock/strut then you don't need to play with the settings.
    If you want to just get 5100s and reuse your existing coils, you can choose the setting on the 5100 that you like. In order to change the setting you have to take about the coil over completely apart.
  2. Oct 18, 2017 at 9:06 AM
    Fitz235
    Fitz235 Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    Shouldn't need UCA's for a 2" lift. 2.5" and above, usually warrants UCA's.
    ChadsPride and PackCon[QUOTED] like this.
  3. Oct 18, 2017 at 9:09 AM
    Michael_Westen
    Michael_Westen [OP] Well-Known Member
    NC
    2018 Tacoma Double Cab TRD Off Road Inferno
    I called the guy that has the truck in the link and he said there is a spacer in front. I know this is a tall ask but by looking at the photo can anyone tell if it might in fact have spacers or any type of lift in the rear?
    ChadsPride likes this.
  4. Oct 18, 2017 at 9:11 AM
    Fitz235
    Rob
    New Hampshire
    I would guess no, if he has 2" in the front. It looks level, to slightly bro-leanish.
  5. Oct 18, 2017 at 9:25 AM
    Michael_Westen
    NC
    I asked a guy at work and he suggested that the rims and tires are what is making the rear look taller with nothing added, your take.
  6. Oct 18, 2017 at 9:39 AM
    PackCon
    PackCon Well-Known Member
    Connor
    2017 Subaru Forester Limited
    The wheels are tires are making the truck look ugly.
    If the tires have a shorter diameter then the wheel gap will give the impression the rear is taller.
  7. Oct 18, 2017 at 9:45 AM
    PackCon
    Connor
    The tires on that truck are 275/55/20. Which are a hair taller than my 265/70/17s which are taller than stock by 1.4".
    He probably has an AAL or block in the rear.
  8. Oct 18, 2017 at 9:47 AM
    Michael_Westen
    NC
  9. Oct 18, 2017 at 9:48 AM
    cvisinho
    cvisinho Well-Known Member
    Rhode Island
    2005 TRD Sport DCSB new frame edition
    Bilstein 5100's, Eibach springs, Cali Raised Amber fogs,Cali Raised side projecting ditch lights, 17" gunmetal trd pro reps w/ falken wildpeaks, MESO interior lighting, Alpine ilx Android auto head unit, rear view camera, blue sea fuse panel, mbrp cat back, Morimoto retros in Depos, Ranch cap, triple black clazzios, DIY thin lip satoshi with FJ letters, oem roof rack, AJT climate knobs, slim sub behind rear seat, fosgate speakers all around, thule cap rack
    Cheapest option as discussed. Bilstein 5100's set at .85 or 1.75.
    Rears of the tacoma on stock leafs are 1" taller than front with an empty bed. So the .85 setting will get you about dead even, the 1.75 will get you a tad over even.
    Literally this much roughly.
    I
    I
    I
    Ive had billies set at .85 in front for about 2 years. Until a rear shock broke recently. Ive had 265/75-16 all along, no issues with rubbing.
    I am adding eibach/toytec 2.5" coils on billies set at 0 up front and adding a 1.5" rear add a leaf (AAL) this time around. Level, just a little bump in height to possibly sneak some 255/85 in there this spring.
  10. Oct 18, 2017 at 9:49 AM
    PackCon
    Connor
    Add A Leaf.
    The truck has leaf springs in the rear. If you buy packs to add to them the rear gets taller.
    Do this, don't go block. Block lifts just stick a block in there which rides horrible.
  11. Oct 18, 2017 at 11:13 AM
    Michael_Westen
    NC
    Ok, had the guy measure right behind the front fender and in front of the rear fender and he said they were at 20". With that said would you think the rear has been lifted any at all or is it stock?
  12. Oct 18, 2017 at 11:15 AM
    cvisinho
    Rhode Island
    i bet the front is only lifted.
    Rear is 1" higher than front to begin with.
    Bumping the front makes everything level in theory.
  13. Oct 18, 2017 at 11:19 AM
    PackCon
    Connor
    Most level kits over 1.5" for this truck are rear and front lifts.
  14. Oct 18, 2017 at 11:26 AM
    Chase8059
    Chase
    ESVA
    Just ask the guy to take some photos of the rear axle and rear shocks. That should give us enough to look at to tell you.
  15. Oct 18, 2017 at 11:30 AM
    #35
    PackCon
    Connor
    I don't think it matters exactly what the truck in the picture has.
    What do YOU want OP? Are you going for a similar wheel/tire set up? If so go with the kit that supports that set up.
    Just FYI wheels exactly like that truck are M/T so very expensive, low tread life, they are effing loud, will throw off your spedometer and odometer and reduce mpgs.
  16. Oct 18, 2017 at 11:34 AM
    #36
    cvisinho
    Rhode Island
    I guess we would have to know what it was to start off with to figure this out then.
    Good luck OP
  17. Oct 18, 2017 at 11:34 AM
    #37
    Chase8059
    Chase
    ESVA
    I agree, but it sounds like OP is curious about what exactly the level kit consists of.
  18. Oct 18, 2017 at 12:02 PM
    #38
    Michael_Westen
    NC
    Here you go guys.
  19. Oct 18, 2017 at 12:05 PM
    #39
    ChadsPride
    Sponsored by TacomaWorld.com
    Yup - 1" block under the leafs
    Chase8059 likes this.
  20. Oct 18, 2017 at 12:07 PM
    #40
    Michael_Westen
    NC
    With that being a 1" rear block would a 2" spacer up front still be able to give you a level look or would you need something more?
