2015 Toyota Tacoma 3" Carrier Bearing drop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chancepeeler, Oct 28, 2015.
  1. Oct 28, 2015 at 1:51 PM
    chancepeeler
    chancepeeler [OP] Active Member
    Chance
    2017 Inferno TACOMA TRD OFF-ROAD
    3" Toytec lift, Bilstein 5100's, 33'' Toyo RT
    I tried that as well and they had me send pictured of my tire lift on the truck. They said it was put on correct and they have never heard of some of the issues I am having. BUT oddly enough if I get on here a lot of people have seen these issues.
  2. Oct 28, 2015 at 1:51 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Do you have a spec sheet from when the alignment was done?
  3. Oct 28, 2015 at 1:51 PM
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    K. just checking. Most people have issues getting a good alignment with stock ucas and a 3 inch lift. Its to earlier to be the needle bearing on your truck so IDK if its not the drive shaft and your sure its not the wheels and tires.
  4. Oct 28, 2015 at 1:52 PM
    chancepeeler
    Chance
    Im not sure I will check. I have had so much done and looked at here lately I am going nuts. I will look.
  5. Oct 28, 2015 at 1:52 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    is your truck 4x4???
    10 bucks says the vibration goes away in 4hi. its the front diff bushing.
    Unchained 5150 likes this.
  6. Oct 28, 2015 at 1:53 PM
    chancepeeler
    Chance
    I wish it is still there in 4hi.
  7. Oct 28, 2015 at 1:53 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    :bowdown:
  8. Oct 28, 2015 at 1:53 PM
    Mademan925
    Nick
    Discovery Bay, CA
    Trucks brand new. shouldn't be the diff bushing. That takes time to wear.
  9. Oct 28, 2015 at 1:53 PM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    Aftermarket UCAs are required for a proper alignment for anything over 2.5" lift in the front.
    Mademan925 likes this.
  10. Oct 28, 2015 at 1:54 PM
    chancepeeler
    Chance
    I went over every component with the Toyota guy who has been doing it for 40 years he said. He said only thing it could be would be carrier bearing.. so we start there
  11. Oct 28, 2015 at 1:54 PM
    nd4spdbh
    SoCal
    my truck instantly did it when i lifted... had all of 9k miles on it.
    Either way OP if you think its the CB, go to the hardware store, get two longer metric bolts of the proper size, and some fender washers, that away you can play with what height of cb drop works best. Took about a half inch on mine.
  12. Oct 28, 2015 at 1:55 PM
    chancepeeler
    Chance
    Did it make the same noises and vibrations? What did it cost to fix and did warranty cover anything?
  13. Oct 28, 2015 at 1:55 PM
    Mademan925
    Nick
    Discovery Bay, CA
    Interesting.
  14. Oct 28, 2015 at 1:56 PM
    nd4spdbh
    SoCal
    warranty will not cover it.... East coast gear supply has the bushing for 60 bucks, i made the puller tool and replaced it myself in about an hour n a half.
  15. Oct 28, 2015 at 1:57 PM
    #35
    chancepeeler
    Chance
    Ok well I have already ordered the Drop kit and will install and go from there. If that doesn't work then its back to the drawing board and will try what you have suggested. It originally sounded like it was coming from the front but now it is getting louder and sounds more rear.
  16. Oct 28, 2015 at 1:58 PM
    #36
    Mr Salty
    Mr Salty "Give up the good to go for the great"
    Hermmy
    SoCal (Bro Capital of the world)
    White SR5 Pre-runner
    Lots of chrome
    If being sacastic... :)
    If not I disagree. Not directed at you, but many on here don't know much of anything yet seem so eager to offer advice.
    Contacting the seller could lead him to a solution as I'm sure these issues are quite common. This also makes it so his communication is limited to a select few vs. a shit ton of people saying "try this and try that" even if the "this" and "that" isn't even related to the issue at hand. Also I suggest discussing the matter over the phone vs. typing this shit out. So much is lost in communication through typing.
    Mademan925
    I stand corrected, the comp he bought from is no help. In this case the forum is maybe his best bet.
    And my wife said I can't admit it when I'm wrong... I sure showed her
    Mademan925[QUOTED] likes this.
  17. Oct 28, 2015 at 2:02 PM
    #37
    Mr Salty
    Hermmy
    Lots of chrome
    Well I guess they are useless than... best of luck finding it.
  18. Oct 28, 2015 at 2:09 PM
    #38
    Mademan925
    Nick
    Discovery Bay, CA
    U bolts torqed at least to 90lbs?
  19. Oct 28, 2015 at 2:11 PM
    #39
    chancepeeler
    Chance
    LoL idk I will have them looked at.. Im a loan officer behind a desk I know nothing! :annoyed:
  20. Oct 28, 2015 at 2:11 PM
    #40
    Mademan925
    Nick
    Discovery Bay, CA
    Im an underwriter... Learning your truck is all part of the fun...
    T4RFTMFW likes this.
