2015 Toyota Tacoma 3" Carrier Bearing drop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chancepeeler, Oct 28, 2015.
  1. Oct 28, 2015 at 2:22 PM
    #41
    chancepeeler
    chancepeeler [OP] Active Member
    Chance
    2017 Inferno TACOMA TRD OFF-ROAD
    3" Toytec lift, Bilstein 5100's, 33'' Toyo RT
    I guess it could be if you weren't OCD and too broke to fix things lol
  2. Oct 28, 2015 at 2:26 PM
    #42
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    I have replaced every piece of armor and suspension on my truck multiple times. I have spent whole days diagnosing vibes by trying long lists of things. My truck is currently vibe free, long traveled, on 35s but that doesn't mean it will stay that way. when I started working on my truck 2 years ago I had never even removed a wheel from a vehicle. Now I have my truck apart almost every other week.
  3. Oct 28, 2015 at 2:31 PM
    #43
    chancepeeler
    Chance
    Dang. Yea mine has 12,000 miles on it and I can't freaking stand that there is a problem. Ive had many mechanics look at it and none can find the cause.
  4. Oct 28, 2015 at 3:07 PM
    #44
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    says the guy with a freaking bad ass truck!
    Mademan925[QUOTED] likes this.
  5. Oct 28, 2015 at 3:16 PM
    #45
    chancepeeler
    Chance
    Ok did some driving around and the noise almost stops when I put into 4wd! Wtf?
  6. Oct 28, 2015 at 3:20 PM
    #46
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Needle Bearing it is
  7. Oct 28, 2015 at 3:22 PM
    #47
    chancepeeler
    Chance
    Costly to fix?
  8. Oct 28, 2015 at 3:25 PM
    #48
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  9. Oct 28, 2015 at 3:39 PM
    #49
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2016 4Runner TRD Pro
    So what if I've got the "whur whur whur" vibration in the floor and it used to go away in 4hi, but now it does it all the time regardless of 2hi/4hi? Does that just mean that the needle is so worn it does it all the time, or its not the differential at all?
  10. Oct 29, 2015 at 8:35 AM
    #50
    chancepeeler
    Chance
    Have you put the carrier bearing drop kit in? I am trying that here in a few hours and will let you know if it takes care of it.
  11. Oct 29, 2015 at 8:50 AM
    #51
    nd4spdbh
    SoCal
    Yup. if you let it go long enough the front needle bearing will eat at the CV to the point of no return.
  12. Oct 29, 2015 at 9:12 AM
    #52
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    sub'd for outcome
    point of no return :eek:
    what happens if you dont catch the needle bearing in time?
  13. Oct 29, 2015 at 9:15 AM
    #53
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Time for a new axle, and not sure maybe damage the diff
  14. Oct 29, 2015 at 9:17 AM
    #54
    99TacoDriver
    South Louisiana
    so pretty much you can replace a needle bearing for cheaper than a whole axle if you catch it in time...i saw a video on youtube of a guy that replaced his needle bearing or maybe a bushing in there that supposedly fisxed the vibs...not sure if it was a 1st or 2nd gen though...been a while since ive seen it
  15. Oct 29, 2015 at 9:20 AM
    #55
    99TacoDriver
    South Louisiana
    maybe this video will help OP
  16. Oct 29, 2015 at 9:22 AM
    #56
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    99TacoDriver[QUOTED] likes this.
  17. Oct 29, 2015 at 9:24 AM
    #57
    99TacoDriver
    South Louisiana
    yeap thats the video i was talking about! apparently that bushing will help with the angle created by the lift and reduce some of the wear on the bearing
    Unchained 5150 likes this.
  18. Oct 29, 2015 at 12:37 PM
    #58
    chancepeeler
    Chance
    Ok so an update. On my lunch break I put in the Carrier Bearing Drop kit and It took away the loudest noise I was hearing. CRAZY that 3/8 of an inch has that much impact. Sure doesn't have that much impact with a woman lol... I keep hearing some small noise now from the front but can't tell if I am searching for things or I got it done.. Will keep posted
  19. Oct 29, 2015 at 12:58 PM
    #59
    nd4spdbh
    SoCal
    CV gets scored and will need to be replaced.... no harm to the diff.
  20. Oct 30, 2015 at 12:30 PM
    #60
    chancepeeler
    Chance
    Ok Carrier Bearing drop fix some problems but not enough. I guess the next step is the bearing replacement from ECGS. I spoke to a few mechanics and they act like my crazy when I describe what Ive been told and what needs to be replaced. Any ideas?
