2015 Toyota Tacoma 3" Carrier Bearing drop?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by chancepeeler, Oct 28, 2015.
  1. Oct 30, 2015 at 12:43 PM
    #61
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    its not crazy considering there have been MANY of us that have swapped in the bushing to solve vibe issues... also toyota has a TSB regarding the needle bearing.
    If they dont know what you are talking about walk away from that mechanic.
  2. Oct 30, 2015 at 4:43 PM
    #62
    chancepeeler
    chancepeeler [OP] Active Member
    Chance
    2017 Inferno TACOMA TRD OFF-ROAD
    3" Toytec lift, Bilstein 5100's, 33'' Toyo RT
    Ok so I'm going through with the ECGS clamshell bushing. I'm not sure which side needs it. Is there one of these on each side that could possibly be bad or just 1?
  3. Oct 30, 2015 at 4:47 PM
    #63
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    Drivers side is the only one
  4. Oct 31, 2015 at 10:16 AM
    #64
    chancepeeler
    Chance
    Why if I drice it does it seem that the noise goes away after 15 min of driving. Does the bushing heat up and expand. Idk. Is it normal?
  5. Nov 9, 2015 at 6:29 AM
    #65
    chancepeeler
    Chance
    Ok update guys the gear from ECGS took care of all my issues. Most of you called that for sure.
  6. Nov 9, 2015 at 6:31 AM
    #66
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Yes I did thank you sir Post # 2
  7. Mar 18, 2016 at 4:48 PM
    #67
    jtkkz
    jtkkz Well-Known Member
    Bay Area, Ca.
    2005 Tacoma DC 4WD
    OME lift kit / Fifteen52 Analog wheels
    i have been reading this thread, so i just installed a complete OME 2" lift kit on 2005 tacoma, with CB drop kit installed , got my front end aligned.
    I also noticed a bit of vibrations at low speed (20-40mph)
    Will I need to replaced ECGS bearing too or can i add another spacer to the CB, will this solve my vibration issue?
