2015 TRD
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Voodoo Actual, Jul 31, 2015.
  1. Jul 31, 2015 at 11:07 AM
    Voodoo Actual
    Voodoo Actual [OP] Well-Known Member
    2015 TRD Pro
    Hey guys,
    I just purchased a 2015 TRD Pro last week.
    It comes with a TRD air filter. Would an intake give me more efficiency and power? If so, what do y'all recommend?
    I also have a hi-lift that I used on my last vehicle. Is there another jack or a base for the bottle jack that would be better and what is the best system to carry a hi-lift in a Tacoma?
    Lastly, for now, is there a small spacer lift, maybe an inch or two? I like the how my truck handles but I am loaded up a lot of the time so I want my ride higher once I'm loaded up to be what my un loaded height is.
    Also, what do you need to do to get the dogs to run with the brights?
    Thanks!
  2. Jul 31, 2015 at 11:22 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    3.
    You already have the Pro suspension, which is about a 2" leveling lift up front over stock and upgraded extended travel shocks all the way around. If you want better handling/height when loaded you may look at a 1.5" 3 leaf progressive add-a-leaf (AAL) for the rear. I went with the Icons on a similar setup and really like the way it handles.
    Don't pull out your Pro suspension for 5100s, that would be a major downgrade.
  3. Jul 31, 2015 at 11:22 AM
    Voodoo Actual
    2015 TRD Pro
    I don't really want to change the suspension out to OME at this point. I like how it handles. I want a spacer to compensate for the weight. This is done on a lot of rigs, Wranglers, trucks, etc. including leveling kits from the dealer although that's only the front and I need the front and rear. So what's wrong with it? The Bilstien reservoirs that come with the truck aren't, so I wasn't looking to junk them in the first week.
  4. Jul 31, 2015 at 11:25 AM
    Voodoo Actual
    2015 TRD Pro
    I'm not ditching the Pro suspension. It's pretty good.
    Where would I find that progressive leaf and will it stay soft? I like compliant suspension - stiff won't work for how I use my vehicles anyways.
  5. Jul 31, 2015 at 11:30 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    It isn't stiff, it is tight and controlled and removing the overload actually makes the ride better. Your rear shocks have almost 1.5" longer drop than stock, so you should be find with the additional height in the back.
    Edit: I don't know why this link is being difficult, and redirected but copy and paste the whole link in your browser.
    http://toyteclifts.3dcartstores.com/ICON-15-inch-Progressive-AAL_p_970.html
  6. Jul 31, 2015 at 11:45 AM
    Voodoo Actual
    2015 TRD Pro
    Is this the unit you are talking about?
  7. Jul 31, 2015 at 12:13 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Yep. I'll post a write up on it soon, it is a pretty easy install. It will reduce sag when the bed is loaded, and being a 3 leaf progressive spring it provides a smother ride than the single leaf AAL.
    Edit: BTW, welcome to TW and congrats on the truck!
  8. Jul 31, 2015 at 12:15 PM
    Voodoo Actual
    2015 TRD Pro
    What is the overload?
  9. Jul 31, 2015 at 12:16 PM
    Voodoo Actual
    2015 TRD Pro
    Sweet.
    Are there other small boosts I should look at it is the going to be the best one that's the come compliant?
  10. Jul 31, 2015 at 12:32 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The overload is the flat inverted metal 'spring' at the bottom of the leaf pack. It prevents the springs from over compressing. If you are loading your truck to capacity or doing heavy towing, you should keep it. The AAL will give you additional spring capacity enough for most to remove the overload. You can also keep the overload when installing the AAL, but people report ride is better without it.
    It is the bottom spring pictured in this thread. I didn't need to do any bracket cutting mentioned in here:
    https://www.tacomaworld.com/threads/installing-icon-aal-on-the-stock-4-leaf-pack.315110/
    The other common 3 leaf AAL progressives are Toytec has their own brand version, as does Wheelers. I went with Icon because they are widely known to produce exceptional quality suspension components, and they are only a couple more dollars (literally) than Toytec.
  11. Jul 31, 2015 at 12:41 PM
    Lomez
    Lomez Well-Known Member
    Lomez
    AZ
    2015 Silver Sky DCSB 4WD
    I absolutely am not an expert on the suspension components of Tacoma trims, but huh? 5100s added to a Pro?
  12. Jul 31, 2015 at 12:44 PM
    Lomez
    Lomez
    AZ
    hah, yeah, I hope to buy those dudes' take offs to upgrade my base.
    but that will be another thread.
    /threadjack
  13. Jul 31, 2015 at 12:55 PM
    Voodoo Actual
    2015 TRD Pro
    Does anyone know what you need to do to get the fogs to run with the brights?
  14. Jul 31, 2015 at 1:21 PM
    Voodoo Actual
    2015 TRD Pro
    Do you have a link to this? What's needed to do this?
  15. Jul 31, 2015 at 1:24 PM
    Flowin
    Flowin Well-Known Member
    Acworth, Georgia
    2014 DCSB TRD OFF ROAD
    OME 3" lift, 265/75/16 KO2s, 35% tint
    your front is already 2" higher, if you insist on "spacers" I would just do a 1 or 1.5" block in the back which will get rid of the nose high look
  16. Jul 31, 2015 at 1:31 PM
    Voodoo Actual
    2015 TRD Pro
    I don't mind the nose high look and it gets over the washboards at high speed nicely. I don't want to change the dynamics of the suspension. I simply want to boost it a little so that it had preload which will keep me at the factory height of the truck when I'm loaded up. This would be like adjusting to the next preload ramp on adjustable coil overs.
  17. Jul 31, 2015 at 1:37 PM
    Voodoo Actual
    2015 TRD Pro
  18. Aug 1, 2015 at 7:53 AM
    Voodoo Actual
    2015 TRD Pro
    What are y'all's using for CB's in these trucks?
    I have a portable and an all in one unit that would need to be hard wired.
  19. Aug 2, 2015 at 11:38 PM
    Voodoo Actual
    2015 TRD Pro
    Just did the fog light mod. Works as advertised.
  20. Aug 4, 2015 at 2:59 PM
    RKCRUZA
    RKCRUZA Well-Known Member
    Bob
    Placerville, Ca
    2015 TRD Pro in the Garage!
    You might also read up on the Firestone Ride Rite Airbags. Lots of good info on this site about them. Put them on my Pro along with the Daystar Cradles and they work great. Have been running them on my 02 Tundra for a decade plus and like what they do in both cases.
