2016 2.7 struggling going uphill
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sy92, May 5, 2021.
  1. May 6, 2021 at 7:52 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    Sounds like you had it floored and the trans chose2nd gear.
    I did a calculation for you. 70mph in 3rd gear (1.49 gear ratio) with stock tire size is about 5000rpms. Sounds normal to me. You can try manually shifting up and it might hold a higher gear but it sounds to me like you are flooring and the trans drops to 3rd for that speed. If it is taking a while to shift up again after cresting a hill, try letting off the throttle and see if the trans responds quicker.
    Sy92[QUOTED][OP] and shakerhood like this.
  2. May 6, 2021 at 8:22 PM
    Tigris99
    Tigris99 Well-Known Member
    St Louis
    2021 AG Trail edition
    Partly wife got pissed when I threatened a manual and partly cause I couldn't find on that checked the few required boxes I had when I was shopping.
  3. May 7, 2021 at 5:47 AM
    BRBNNEAT
    BRBNNEAT Well-Known Member
    Madison, WI
    2021 TRD Offroad-6 speed
    MBE350 with 3.5L V6 compared to this 2.7 I4 - yeah, the 2.7 doesn't have the power and perhaps the torque as the E350, plus it may weigh a little bit more.
    Chew likes this.
