2016 2017 Tacoma SR5 4x4 4cyl differential oil question
Discussion in '3rd Gen. Tacomas (2016+)' started by Sixrabbit, Nov 28, 2017.
  1. Nov 28, 2017 at 5:30 PM
    Sixrabbit
    Sixrabbit [OP] Member
    2016 Tacoma SR5 4x4 4cyl A/T
    Hello, I am trying to find the oil capacity for the front and rear differentials and transfer case, what viscosity and should it be synthetic or conventional? I also want to use some LiquiMoly gear oil additives if they're compatible. Thank you
  2. Nov 28, 2017 at 5:47 PM
    Vbpiper
    Vbpiper Well-Known Member
    2016 BBP SR5 DCSB 4x4
    AVS Bugflector II, WeatherTech mud flaps, Gentex Homelink/compass mirror, OEM bed mat, SolidFold 2 tonneau
    I don't have the information handy, but it is all in your owner's manual, except the LiquiMoly part. No idea about that. Check the sticker on your driver's door frame for information on your specific differential. I think it is listed there.
    FWIW, I used Mobil 1 75W-90 in my differentials, and will only use the specified Toyota fluid in the transfer case.
    Also, all of the required drain and fill plug gaskets can be bought in a kit from Amazon.
  3. Nov 28, 2017 at 5:53 PM
    Sixrabbit
    Thanks. I don't seem to have the owners manual. I am the second owner, I bought the car from a VW dealer.
  4. Nov 28, 2017 at 5:55 PM
    Vbpiper
  5. Nov 28, 2017 at 5:56 PM
    Sixrabbit
    I see I did not think of that. Thank you
    Vbpiper likes this.
  6. Nov 28, 2017 at 5:57 PM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Vbpiper likes this.
  7. Nov 28, 2017 at 6:00 PM
    Vbpiper
    And welcome to TW! Lots of good information here, just ignore the trolls and enjoy your new truck!
    daddy_o likes this.
  8. Nov 28, 2017 at 6:22 PM
    Sixrabbit
  9. Nov 29, 2017 at 4:07 AM
    tibadoe
    tibadoe Well-Known Member
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    My '17 SR manual states:
    Differential:
    Front: (4WD models) 1.6 qt. (1.5 L, 1.3 Imp.qt.)
    Rear:
    Vehicles with an automatic transmission
    3.1 qt. (2.9 L, 2.6 Imp.qt.)*2
    3.22 qt. (3.05 L, 2.68 Imp.qt.)*3
    4.0 qt. (3.8 L, 3.3 Imp.qt.)*4
    4.2 qt. (4.0 L, 3.5 Imp.qt.)*5
    Vehicles with a manual transmission
    Oil type and viscosity*1:
    Toyota Genuine Differential Gear Oil
    LT 75W-85 GL-5 or equivalent
    Transfer (4WD models):
    Oil capacity: 1.1 qt. (1.0 L, 0.9 Imp.qt.)
    Oil type*: Toyota Genuine Transfer gear oil LF or equivalent
    Recommended oil viscosity: SAE 75W
    For each *note: reference owners manual page 576.
  10. Dec 2, 2017 at 9:59 PM
    Sixrabbit
    And the engine oil change interval is 5,000 or 10,000 miles? Thanks
  11. Dec 3, 2017 at 8:42 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    My manual recommends 10k changes but also says something like heavy or severe use to change every 5k
  12. Dec 3, 2017 at 8:45 AM
    tibadoe
    Joe
    Gladys, VA
    17 Tacoma SR 4X4
    10k for regular light duty and 5k for severe. I do the 5k max on the SR just because -- and it's nowhere near severe duty requirements. Figure out what works for you and go for it. As long as you go the the OM as a minimum - you'll be OK.
    shakerhood likes this.
  13. Oct 11, 2018 at 1:34 PM
    rltco
    rltco Active Member
    2017 SR 4X4 5spd.
    Does anyone sample and test oil anymore? I'm curious what a lab would say about oil after 5 and 10,000 miles. I'll never run 10,000 miles between changes, but mine gets used harder than most - both hauling and pulling trailer.
  14. Oct 11, 2018 at 2:05 PM
    Vbpiper
    I use Blackstone Labs and everything looked great after a 5000 mile change. I have only done the one analysis so far, but will do another with a 10,000 mile interval. One member here posts his results.
    https://www.tacomaworld.com/threads/oil-test-results-from-30k-oil-change-update-50k.505428/
