2016-2018 (3rd Gen) Intermittent Wiper Mod!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by moe2o4, Oct 27, 2015.
  1. Dec 7, 2015 at 9:36 AM
    moe2o4
    moe2o4 [OP] Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Your welcome man. That's strange that it was on the sticker!
  2. Dec 7, 2015 at 9:49 AM
    cohiker
    cohiker Well-Known Member
    2016 DCSB SW V6 4X4 Tacoma
    For what it's worth, it was on my sticker as well. Was surprised when it wasn't in the truck... but $90 and 15 minutes of my time wasn't worth making a big deal out of it.
    moe2o4[OP] likes this.
  3. Dec 7, 2015 at 10:14 AM
    moe2o4
    Corey
    Pittsburgh PA
    True!!!
  4. Dec 24, 2015 at 6:55 AM
    macknepa
    macknepa Active Member
    NE PA
    2017 DCOR Manual
    FYI, tried stalk from 14 Corolla and did not fit. I'm sure there are other models that will work, but a 14 LE Corolla model will not.
  5. Feb 25, 2016 at 4:28 PM
    evilfij
    evilfij Well-Known Member
    2016 ACLB SR 4x4 MT Utility Package Black
    TRDOR wheels, sheepskin seat, cruise and intermittent wipers, curt hitch
    12 minutes start to finish in the dark.
    Thanks for the support!
    One note: step 8 the "three prong plug" only has two prongs in it.
    Also there is a white clip on the door side which you need to align if the bottom is not going on correctly. I tried to get a pic but largely failed. It is under on the bottom.
    I got the switch off Amazon by searching the part number. The member here did not have any in stock when I checked.
    moe2o4[OP] and James_Bond like this.
  6. Feb 25, 2016 at 5:23 PM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    great write up, If I didn't have this switch already I would probably do this mod. I'm more interested in the old-fashion ignition mod you got going on there :welder:
  7. Feb 25, 2016 at 6:30 PM
    moe2o4
    Corey
    Pittsburgh PA
    Thanks man, glad I could help you out!!!
    That's for my viper remote start, they haven't released a bypass module yet so I got a key in a black box under the dash and that ring reads the key!
  8. Apr 4, 2016 at 8:23 PM
    STi and Taco
    STi and Taco Not a Super Hero
    Steven
    Georgia
    '16 Tacoma SR 4x4 Access Cab Black, 2012 Subaru STi Hatchback Black, 1995 Acura Legend L Gold (RIP), 2020 Corolla Hatchback
    Diode Dynamics LED Inerior Lighting https://www.diodedynamics.com/by-vehicle.html?no_cache=1&find=2016-toyota-tacoma-115242 Hella Supertone Horns Some Joe Schmuckitelli Keyless Entry Intermittent Wiper Mod - Thanks to @moe2o4 Cruise Control Mod - Thanks to @moe2o4, again Anytime Back-up and Front Mount Camera Mod - Courtesy of @Logistics91 (amazing customer service helping me get it just the way I wanted it set up) Drawtite Class IV trailer hitch with 7/4 pin connector and P3 Tekonsha Brake Controller RokBlokz Mud Flaps Access Cab Rear Seat Storage Mod - Thanks to @Cagedodger for the original idea. Just modified it to fit my needs. https://www.tacomaworld.com/threads/access-cab-storage-organization.453774/page-4#post-17877877 Method 701 Black Wheels 265-70r17 Nitto Ridge Grapplers Fumoto Drain Valve Weather Tech Floor Liners and Side Window Deflecors Tuxedo TruXport Bed Cover Access Cover Motion LED Light Strip. Mounted 2 in the bed. Air Dam Delete Demello Off-Road Overlander Aluminum Winch Bumper with Baja Hoop and Squadron Sport LED Spots Warn M8000 Winch Silex center console organizer and tray Full Bed and Under Hood LED Lighting A/C Condensation Drain Relocation Rostra Front Heated Seats aFe Power 51-82722 Magnum FORCE Stage-2 Si Pro DRY S Cold Air Intake System (Part #51-82722) Prolightz clear LED fog lights w/ lamin-x overlay Red line Hood struts Diode Dynamics Hi/Low beam HID conversion kit MesoJDM 4 switch cubby panel, 7 switch Center panel and Center console Coin Holder @mesojdm Carhart Gray Front Seat Covers Curtis Class IV receiver B&W Tri-ball hitch King 2.5 Front Coilover/Rear Shock 25001-119/25001-121 Coming Soon: Differential Breather Relocation Mod New tires, can't decide
    Knocked mine out today. Since I had done it on my old 2013, this one was a piece of cake. Decided to time myself. 4 minutes 19 seconds.
  9. Apr 14, 2016 at 6:56 PM
    guitarcarl
    guitarcarl Active Member
    Seattle, WA.
    A slow 2016 MGM Taco SR 4x4 2.7L 5 spd Manual
    OR Wheels, ATC LTD Cap, Intermittent Wiper Mod.
    I used a special hemostat to pull up on the tab. I was sweating that I would break it. This tool is usually used in surgery or dissection. It has little teeth that grabbed the tab and I could easily pull toward myself to release the stalk assemble. Thank you for the guidance on the install and proper part # to order.
  10. Apr 14, 2016 at 7:19 PM
    moe2o4
    Corey
    Pittsburgh PA
    Your welcome man, glad I could help ya out!
  11. May 21, 2016 at 4:17 AM
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    Awesome write up! Does anyone know the PN or the switch used on the Tacoma rather than the corolla? I want to do this mod but I would rather use the same switch that would have come in it from the factory.
  12. May 21, 2016 at 4:19 AM
    bblake00
    bblake00 Well-Known Member
    AA County, MD
    2016 Poverty Model (SR) DCSB V6 4x4
    Same switch. There are quite a few parts that are used across the Toyota lines. Cuts down on cost
  13. May 21, 2016 at 4:21 AM
    2016 Tacoma SR
    HOCO Maryland
    Makes sense, thank you. I just got my 16 SR on Wednesday. I got the convenience and appearance package with it which has everything I want but intermittent wipers weren't even a thought. Really just assumed that was a standard by now lol. $100 switch is well worth it to me, I can't wait to get this done!
  14. May 21, 2016 at 5:29 AM
    moe2o4
    Corey
    Pittsburgh PA
    Thanks man, glad I could help ya out!!!
  15. May 27, 2016 at 12:53 PM
    #35
    WestGa42
    WestGa42 Well-Known Member
    Eddie
    Georgia, USA
    2016 2wd SR5 access cab V6
    Nothing fancy, yet. Weathertech mats front/back + their mud guards, some reflective striping and custom carpets on the storage bin lids underneath the jump seats.
    Cool mod indeed!
    FWIW, I have an SR5 V6, which came with the intermittent wipers but not the keyless ignition.
  16. Jun 27, 2016 at 11:09 AM
    #36
    4RNR
    4RNR トヨタ
    Ge
    America
    16 Tundra 1UR-FE | 10 4Runner 1GR-FE | 16 2GR-FKS DCSB 4X4 - sold
    2016 Tundra crewmax
    Thanks a lot for writing this!!! Just got mine done and I love it!!!
    moe2o4[QUOTED][OP] likes this.
  17. Jun 27, 2016 at 11:18 AM
    #37
    moe2o4
    Corey
    Pittsburgh PA
    Your welcome man, glad I could help ya out!!!
  18. Jun 28, 2016 at 9:26 AM
    #38
    toyomaniac71
    toyomaniac71 Well-Known Member
    Dave
    Colorado
    16 DCSB Sport
    Toytec 2.0 Boss 2" lift; Fuel Boost 18"; Nitto G2 275/65/18; BAMF Grille
    Related topic, but slightly different.
    I noticed on mine that the interval wiper settings are reversed! I have a 4 runner and Lexus that have the proper settings and showed it to Toyota. The marking with the "narrowest" white mark is supposed to be faster than the "wide" white mark. More annoying than anything else that they missed this during the QC inspection. Dealership said they are aware but are not planning to do anything about it - unless more people complain about it. Guess this just goes with buying a new model. Disappointed that Toyota missed something like this.
  19. Aug 24, 2016 at 9:02 PM
    #39
    gmajor
    gmajor Well-Known Member
    Dude this and the cruise control mod (more the latter, but still) are why I bought an SR! Thanks again!
    ndoldman59 and moe2o4[OP] like this.
  20. Aug 25, 2016 at 3:43 AM
    #40
    moe2o4
    Corey
    Pittsburgh PA
    Your welcome man!
