2016-2019 Toyota Tacoma Fog Light Mod! (Step by Step Picture Heavy)
Discussion in '3rd Gen. Tacomas (2016-2023)' started by moe2o4, Dec 2, 2015.
  1. Mar 2, 2019 at 7:27 AM
    #221
    dfish90
    dfish90 New Member
    2017 Tacoma SR
    Hey there Moe and everyone. Just recently helped a friend yesterday work on this install on his 2017 SR. He purchased all the newest parts that you have listed on the first page. Although, we hit a major wall at step 10-12. The kit we were working with is shown in the picture as well a below dash picture. We were unable to find the wires, both on the kit and in the truck, that you were referencing. You'll notice in the picture we have a white wire coming from the fuse, a (very short) red wire, the relay, and the green plug for the switch. Notably, we couldn't find the single black/white ground wire you mentioned in step 11, under the dash. Any thoughts as to what we are missing, are we blind? Thanks a lot!
  2. Sep 15, 2019 at 9:30 AM
    #222
    Redtaco43
    Redtaco43 Active Member
    Thank you for the write up. I’m doing this install right now!
  3. Jan 9, 2020 at 9:21 AM
    #223
    Sr.Tacoma
    Sr.Tacoma Bryan
    Bryan
    Olathe/Overland Park Kansas
    2019 Tacoma SR 4X4 V6 DCSB
    Led Light Bulbs (High-Low Beams) Reverse Led Bulbs Body Armor 4x4 Rear Bumper Level8 MK6 Wheels Yokohama Geolander G003 Interior Led Lights OEM Roof Rack AVS Rain Guards AVS Bug Deflector OEM Foglights
    What kind of fog light kit was used? Im looking online and i want to find a kit with an oem light switch. The ones ive seen have either dark orange or lime green.
  4. Mar 11, 2020 at 5:58 PM
    #224
    Sr.Tacoma
    Sr.Tacoma Bryan
    Bryan
    I got some auto wiki foglights for my sr. And love them. But one of the fogs is collecting moisture so i saw this as a good opportunity to get caliraised led fog lights. It was like 50 bucks so im not too upset at all. Will the led fog lights be compatible with the wire harness that came with the original fog lights? Heres the picture of the fog light kit
  5. Mar 11, 2020 at 5:59 PM
    #225
    Sr.Tacoma
    Sr.Tacoma Bryan
    Bryan
    Heres e fog
  6. Nov 21, 2020 at 9:15 AM
    #226
    RedbirdsTaco
    RedbirdsTaco Well-Known Member
    Tyler
    SW MO
    2016 MGM SR AC MT
    Black Reflective Vinyl Tailgate Inserts Intermittent Wiper Mod Inferno Vinyl Glove Box Inserts SR LED Fog Light Mod Custom St. Louis Cardinals Bedside Decal Clazzio Leather Seat Covers
    So I’ve run in to an issue with this mod a couple of years after doing it. My button broke and I’m looking for a new one. I figured no problem I’ve got the thread bookmarked so I’ll just use the same link and buy another one...but for some reason their buttons aren’t the same as they used to be and it didn’t fit. I’ve ordered another one from Amazon that allegedly fit as well and it doesn’t either. Does anyone know of a button that will work for a MT button slot to the left of the clutch start cancel button? Even if it’s a different button from another trim level that just fits that slot that I could repurpose for my lights?
  7. Nov 21, 2020 at 9:57 AM
    #227
    davidstacoma
    davidstacoma Friendly Curmudgeon
    David
    NC
    2019 Tacoma SR Access cab - Utility
    *OEM Mods: Intermittent wipers, Fogs, Keyless Entry, Lomax
    My 3rd gen has slots for the small form factor switch and the large form factor, the last one I got was the larger fog light switch from CH4X4. Prior to that I had a Mictuning (from Amazon) small one. Both have blue LEDs. Which do you need small or large? Do you have a link to the one that doesn’t fit on Amazon? Or a pic of the slot you want to use? I have an auto so can’t compare.
  8. Nov 21, 2020 at 10:31 AM
    #228
    RedbirdsTaco
    Tyler
    SW MO
    2016 MGM SR AC MT
    So it’s smaller than the clutch start cancel button and appears to be the same size as the blank spots I have on the other side of the dash under the A/C dials. But I have no buttons there either to just use one of those and repurpose it for the open spot I need to fill. And as far as links I used the one for the button used in the OP for the first try at a replacement. It looks like the Amazon one was the CH4X4 one you mentioned.
  9. Nov 21, 2020 at 10:51 AM
    #229
    davidstacoma
    David
    NC
    Yes you need the small form factor switch.
    https://www.ch4x4.com/product/ch4x4-toyota-small-push-switch-fog-lights-symbol/
    I used the larger one and it’s on the same slot position as your clutch cancel switch.
    I do know Amazon has the small fog switch in other brands not sure if the CH4X4 small one is there.
    If you have trouble putting a small switch in the small slot, I have heard of some having to file a tab slot because the tabs didn’t match but I thought that was a second gen issue if I remember correctly.
    This is the Mictuning switch I used in the smaller slot originally. It fit and worked fine but I replaced with the larger one only because it was easier for me to find it at night by feel on that first large slot position.
    https://www.amazon.com/MICTUNING-Ba...a-569095558513&psc=1&ref=&adgrpid=62837065100
    RedbirdsTaco[QUOTED] likes this.
  10. Nov 21, 2020 at 11:53 AM
    #230
    RedbirdsTaco
    Tyler
    SW MO
    2016 MGM SR AC MT
    I really appreciate the help thank you!
    davidstacoma[QUOTED] likes this.
  11. Nov 21, 2020 at 1:07 PM
    #231
    davidstacoma
    David
    NC
    You’re welcome!
    For reference here’s the first Mictuning small form factor fog switch I installed (linked above, the small form factor CH4X4 switch I also linked should fit here as well):
    And here’s the larger form factor CH4X4 switch I later replaced it with:
    bbahunter likes this.
  12. Mar 16, 2021 at 10:25 AM
    #232
    TacoSRSX
    TacoSRSX Well-Known Member
    Martin
    Ventura County / San Fernando Valley - CA
    2021 MGM SR 2.7 2WD SX
    Ionic Pro 4" tube steps Desert Does-it Seat Jackers ECT PWR always on Kicker Tweeters replacement Tyger roll-up vinyl cover Bed mat
    What screws are you guys using to mount the fog lights to the truck?
    Each light takes 2 screws but not sure which ones to use.
  13. Mar 16, 2021 at 7:24 PM
    #233
    davidstacoma
    David
    NC
  14. Mar 17, 2021 at 6:08 AM
    #234
    TacoSRSX
    Martin
  15. Apr 14, 2021 at 7:20 AM
    #235
    tacoma543
    tacoma543 Member
    Curious- Did you ever figure out the answer to your question??? I'm in kinda the same boat, only different is my "long white wire" is red and the short one that seems to go nowhere is yellow. I believe the red/white wire should go to the battery, and the instructions say the yellow/ red wire should tap into an accessory light wire, but I cannot for the life of my find the wire I should tap into!! Also, even with everything else connected except the yellow/ red, I would assume the fog lights should still work, but mine are not working for some reason. I'm currently searching long and hard through these posts for an answer, but thought I'd check if you ever figured it out!
    Thanks!
  16. Sep 19, 2021 at 8:26 PM
    #236
    yotaDAWG
    yotaDAWG Member
    Slidell, LA
    2021 White Tacoma SR Access Cab V6 4x4
    I am looking at the exact same fogs, love the square look. Yes, does anyone know if these will hookup with the original kit harness?
  17. Mar 9, 2022 at 9:15 AM
    #237
    batcat420
    batcat420 I'm a Blue Ribbon man.
    Scott
    Atlanta
    2022 Lunar Rock SR5 Trail Edition
    Can you (or anyone) elaborate on this, please? I also have the 15a 'FOG FR' fuse in the engine box.
  18. Jun 20, 2022 at 12:22 PM
    #238
    Max301
    Max301 Member
    22 SR Tacoma
    Quick question, does the switch have to be powered for the lights to work or is for the light on the switch only? I’m asking because I am waiting on a add a circuit and the lights aren’t working everything else is hooked up..thanks for your help in advance
  19. Aug 10, 2022 at 8:57 AM
    #239
    SHADOWDRIFTER19
    SHADOWDRIFTER19 Well-Known Member
    RH
    2019 2.7L TSS OR
    Awesome and informative post- is this still deemed the best way for my 19 sr?
    moe2o4[QUOTED][OP] likes this.
  20. Aug 10, 2022 at 9:11 AM
    #240
    moe2o4
    moe2o4 [OP] Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Indeed it is!!!
