2016 3rd Gen Rust Prevention
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TVC, Oct 1, 2016.
  1. Oct 2, 2016 at 6:49 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    fuck what the dealer says, they push you to rust proof with their overpriced garbage
    get it done aftermarket or do it yourself.
    Worth it. Its a toyota, they don't have a good rust reputation.
    On a side note everyone says use fluid film. I must add if you have not used it it stinks like actual cow shit.
    I used it to lubricate one of my leatherman's and couldn't get over the fuckin stench it has.
  2. Oct 2, 2016 at 6:56 PM
    TVC
    TVC [OP] Member
    2016 Tacoma SR5
    Tri fold tonneau Aluminum running boards
    Thanks Lawfarin, I appreciate the pics
    Lawfarin[QUOTED] likes this.
  3. Oct 3, 2016 at 3:30 AM
    backroadsvt
    backroadsvt Active Member
    Cabot VT
    2017 Tacoma TRD Off Road M/T
    SR grill
    I live in VT and have used the whole line up, started off with chainsaw oil. I am now using a product https://corrosionfree.com/ . I have the gun with attachments and wands that get inside all the rocker holes, frame rails and so on. I oil my truck/cars twice a year. I just sold a 1995 Dodge(cummins)with 285k miles... no rust. Don't use the rubber coatings, it will crack or peel and the brine will get behind it.
    Just wash the truck down, spray the crap out of it (I use about a gal on my Tacoma) and drive on some dirt roads if you can. It will get a nice coating. Don't worry about the smell it will burn off after a few hundred miles.
    Good luck and cheers
    TVC[QUOTED][OP] likes this.
  4. Oct 3, 2016 at 6:08 AM
    Spare Parts
    Spare Parts Well-Known Member
    Southern Maine
    2022 Off Road Premium 4Runner Lunar Rock
    Why drive on dirt roads? Do you want it covered in dirt?
  5. Oct 3, 2016 at 7:01 PM
    backroadsvt
    Cabot VT
    SR grill
    Yes, a good coating of dirt is what you want.
  6. Oct 3, 2016 at 9:33 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    While dirt will act as an insulator. It also absorbs and holds water and moisture. Not to mention dries out/decreases the oil based products faster. Dirt is actually a bad thing in that scenario in my opinion.
  7. Oct 3, 2016 at 9:47 PM
    Spare Parts
    Southern Maine
    Why?
  8. Oct 4, 2016 at 5:13 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
    I think the theory is that the dirt coats and thickens the oil which helps to keep it in place.
    I've been using Fluid Film and I live on a dirt road. It does hold a small amount of dirt but really not very much.
  9. Oct 4, 2016 at 5:45 AM
    Spare Parts
    Southern Maine
    Any one applied this themselves on their tarred driveway? Does it hurt the driveway? I know certain kinds of oils will breakdown tar.
  10. Oct 4, 2016 at 6:22 AM
    Searles
    Searles Well-Known Member
    16 AC TRD OR
    Adjusted Seat
    I had Corrosion Free applied at the Chickasaw Garage in Chickasaw Ohio. No odor. No drips. About a 50 mile drive from where I live. It's supposed to last 18 months, and time will tell as winter is in the offing and they use a lot of salt in western Ohio. If your truck is less than 3 years old, and you keep up with the treatments, you have a life-time warranty through Corrosion Free. I picked Corrosion Free over Fluid Film based on what I read on this site. Apparently Fluid Film drips for a few days afterwards, messing up your garage floor, has a chemical odor, and lasts 12 months. Cost $170 for the Corrosion Free application. Take a good book as there isn't a lot to do in Chickasaw once you've walked around town and it takes about 1 1/2 hours for them to do the work. Several of the hard plastic plugs in the frame broke during removal and I asked them to save them so I could get matching replacements.
  11. Oct 4, 2016 at 7:08 AM
    HV_Taco
    HV_Taco Well-Known Member
    MJ
    Copeland Forest, Canada
    2016 Inferno TRD
    Still Stock but working on changing that fast
    I went with Corrosion Free as well based on research and talking to a few folks on TW. All-in-all, what it really comes down to is how it is applied. I believe all products are pretty much about equal, it's the installation that matters. Research and find someone you know and can trust to do a good and thorough job installing the product.
  12. Oct 4, 2016 at 8:23 AM
    tgear.shead
    tgear.shead Well-Known Member
    That thing about asphalt undercoating promoting rust only applies if the frame you are undercoating with it is ALREADY RUSTED. Done correctly, it needs to be applied to a CLEAN and NEW frame. It also needs to be MAINTAINED.
    EVERY year, go over the entire frame, and scrape/prime/paint any rust on the thing.
    EVERY TWO years, reapply asphalt undercoating.
    EVERY year, hose it down with as heavy of an oil as you are able to spray -- I use chainsaw bar oil, which is also waxy and sticks well to metals. This keeps the asphalt nice and supple, and seals any voids where water may otherwise get in.
    Pay attention to the inside of the frame up front. I don't know if they've made any changes on the 2016+ frame in this regard, but 2005-2015 have an "Achilles heel" hidden within the front cab body mounts! There is a big hole at the back of the mounts that exposes the inside of the frame, essentially, the cab mounts, which are right in the spray path for salt crud flying off the front wheels, are tunnels that direct all that crud right up and inside the frame! If the 2016+ have the same weakness, then I STRONGLY suggest sealing the cab mounts off as much as you can (but not the drain holes). Also seal off any other access points for water to penetrate in/around the front wheels.
  13. Oct 8, 2016 at 9:59 AM
    TSki
    TSki Well-Known Member
    Tyler
    Salmon, Idaho
    2017 Silver Sky TRD Off-Road, 4x4, DCSB MT
    https://www.tacomaworld.com/threads/my-silver-gsu-build.460083/
    Is this something thats easy to do in the driveway if I crawl under the truck? Or would I be better off paying the 5 dollars to rent the lift for two hours at the auto hobby shop?
  14. Oct 8, 2016 at 10:11 AM
    InSight Retrofits
    InSight Retrofits Closed
    I'm going with fluid film again. Only $74 for a gallon and the spray gun.
    undercoating flakes and traps moisture behind it if you don't clean it and reapply every year.
  15. Oct 8, 2016 at 10:13 AM
    #35
    TSki
    Tyler
    Salmon, Idaho
    Just to make sure I'm correct before purchasing, what size compressor is needed for running this? They salt the roads like crazy out here in Germany, so I have never done any salt prep before.
  16. Oct 8, 2016 at 10:18 AM
    #36
    InSight Retrofits
    Any decent size compressor should be fine. A little pancake harbor freight one wouldn't be able to do it but if you have a 5-10gallon compressor you should be fine
  17. Oct 8, 2016 at 10:20 AM
    #37
    TSki
    Tyler
    Salmon, Idaho
    I think I am going to use this as an excuse to buy me a compressor..
    Lawfarin and Spare Parts like this.
  18. Oct 9, 2016 at 5:35 PM
    #38
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    You sir are 100% on the money my good man... I've used Corrosion Free since it came out about 18 yrs ago...used Rust Check prior to that. Corrosion Free is THE best product I could find and it moves into every little crack and crevice and pushes out the water, then sits there to protect your investment. It is also VERY important to find a shop that has a guy who applies it who is VERY Anal... Look at his personal vehicle... that will tell you a lot right there. I'm lucky to have a guy that is very Anal and OCD about doing it right.
    Works for me.... But with the new Calcium Chloride (or whatever that new shit is)... It's way more nasty than salt...
    Corrosion Free seems to be real good.... OH, and by the way...you will have to clean the bottom of your doors every now and then as this stuff "creeps" out of the door drains and comes up the outside of the doors.... Great product..!!
  19. Oct 9, 2016 at 6:36 PM
    #39
    Barcared
    Barcared Well-Known Member
    Philadelphia, PA
    2016 Barcelona Red TRDOR RIP. 2020 MGM TRD OR.
    I saw some at Lowes this weekend, they had a whole shelf full of it for just under $10 a can. It was in the front of the store right next to the PB'laster and WD-40.
  20. Oct 9, 2016 at 6:42 PM
    #40
    1bad10tacoma
    1bad10tacoma Well-Known Member
    Mark
    Brewer Maine
    2025 dcsb Trd off-road
    tonneau,
    Thanks for the info, I will have to pick some up.
