2016 6-cylinder 6-speed automatic erratic shifting and drivability problems?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ben91z28, Nov 16, 2015.
  1. Jun 20, 2016 at 6:50 PM
    #321
    moab4x432
    moab4x432 Well-Known Member
    Tacoma wa
    2016 4Runner trd pro quicksand
    It's going through customs right now so hopefully this weekend
    deergetr likes this.
  2. Jun 20, 2016 at 7:57 PM
    #322
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    Thought you might find this interesting.
    It's the A750 pdf.
    Flex lockup strategy with and without AI.
    Uphill/downhill shift strategy with and without AI.
    See pages 29, 33, & 34
    http://www.toyotatundraforum.com/pdf/A750E.pdf
  3. Jun 20, 2016 at 8:19 PM
    #323
    topdec
    topdec Well-Known Member
    OK...So going to S5 does make a difference...
    - eliminating flex lock-up when decelerating at 3rd and lower gears
    - canceling AI-shift at elevation changes....
    So when AI-shift is canceled, is the standard shift pattern based on driver intention + rpm?
  4. Jun 20, 2016 at 10:13 PM
    #324
    dman100
    dman100 Well-Known Member
    Central Coast, California
    2016 TRD OR DCSB
    I've driven mine over 6K miles and I have to say I'm getting used to it. Around town, or on level roads, I just put it in D. In the mountains (I'm in California, lots of local hills up to 2-3K ft, plus frequent drives to the Sierra from sea level to 9K) I've tried ECT but finally just started using S mode. Honestly, that works fine. 3rd, 4th or 5th depending on grade and speed. At worst, it kicks down occasionally. If it downshifts too often, I click it down to a lower gear. I've started driving it like a clutch-less manual (i.e., assume I'm smarter than the trans after 45 years of driving) and I'm pretty happy with it. Gassed up in Lake Tahoe, over Spooner Summit to 395, a few miles of dirt roads, back over Ebbetts Pass and Pacific Grade Summits (over 3k feet climb) and back to sea level, averaged 23 mpg, with a roof top tent on the roof. DCSB 4wd.
  5. Jun 21, 2016 at 4:15 AM
    #325
    splitbolt
    NW Arkansas
    I don't think there's a standard pattern; just the one best suited to all the input.
    AI cancels driver intention support and road condition support.
  6. Jun 26, 2016 at 7:46 AM
    #326
    punch57
    punch57 Member
    The problem I have is after down shifting from 6th gear for an overpass when the road flattens out it will settle in 5th gear and stay there till the next overpass !!! If I rap the gas pedal it will up shift to 6th gear. Also when using the cruise if I disengage let the vehicle slow down 5 to 15 mph (while running 60-70 mph) the transmission will down shift and rev the engine to 4500 rpm.
    Anyone else have these problems ?¿?
    2016 Tacoma SR5 TSS 4X4
  7. Jun 26, 2016 at 11:54 AM
    #327
    oldschoolczar
    oldschoolczar Well-Known Member
    '16 DCSB TRD OR
    S mode makes all the difference in the mountains. I was disappointed when I first drive this thing west from Denver on I-70. After taking it out and playing with it a few more times it runs fine in the mountains when in S Mode, mainly because I can prevent it from upshifting. My problem when in D is that I'll be going up a steep sustained grade in 4th and if I have to let off the gas slightly due to traffic or something it'll upshift to 5th and basically downshift seconds later.
  8. Jun 26, 2016 at 4:17 PM
    #328
    dman100
    2016 TRD OR DCSB
    +1 for S mode. ECT is better than nothing in some conditions, but in the mountains, freeway or 2 lane, uphill or down, S mode lets you put it in the gear you should be in, or at worst one gear higher. Cruise control is really only suitable for level roads and speeds which keep you in one gear. Take control and drive this truck like you're in charge of the gears and speeds, and it does OK!
    jsinnard likes this.
  9. Jun 27, 2016 at 12:01 PM
    #329
    16tacoma1972
    16tacoma1972 Member
    2016 Tacoma TRD Off Road
    I finally had time to take it into the dealership today. Quart low on transmission fluid.
    They also aligned the box to the cab.
  10. Jun 27, 2016 at 12:05 PM
    #330
    splitbolt
    NW Arkansas
    I gave up only D(AI)...
    Have you tried S- mode?
    Try S5 If you haven't.
  11. Jun 27, 2016 at 12:10 PM
    #331
    Pportera
    Pportera Well-Known Member
    3rd gen.
    Why did they aligned the box to cab?
  12. Jun 27, 2016 at 12:23 PM
    #332
    16tacoma1972
    16tacoma1972 Member
    The box was shifted to the passenger side by 3/4 inch
  13. Jun 27, 2016 at 12:26 PM
    #333
    16tacoma1972
    16tacoma1972 Member
    I have used S5 and it is better. The service writer said that there is an update for the transmission coming soon. Hopefully that is true.
  14. Jun 27, 2016 at 12:45 PM
    #334
    splitbolt
    NW Arkansas
    :fingerscrossed:
  15. Jun 27, 2016 at 1:06 PM
    #335
    Pportera
    3rd gen.
    I think the update is already out at some dealers. Like i said after my 5k service the transmission is completely different. No slipping, no delay, holds gears longer before dumping it in 6th and downshifts to the correct gear on its first try. Its like the way its supost to be. mpg seem to have increased aswell.
  16. Jun 27, 2016 at 1:13 PM
    #336
    Pportera
    3rd gen.
    Hoover Toyota did the service on it here in AL. They changed oil, rotated tires, checked alignment, lubed and they said downloaded all the latest updates from Toyota. I thought they were reffering to the stereo system updates.... but transmission issues all seem a thing of the past.
    16tacoma1972 likes this.
  17. Jun 27, 2016 at 2:25 PM
    #337
    Okanagan55
    Okanagan55 Orange is the New Black
    Duncan
    British Columbia, Canada
    2016 Inferno TRD Sport
    I have tried to stay out of this conversation because at first I wasn't seeing most of the issues. That being said I was only doing local drives around town and no real highway driving. Other than the issue of up shifting to 6th gear going uphill at 50kph I really had nothing to complain about. This last few weeks however we took the truck for a nice long drive with all kinds of different terrain and the hills were turning me into a swearing aggressive driver who was hell bound to blow the motor and tranny out of this truck. It's crazy that you build a truck in 2016 that has a transmission that behaves this way. Feels like I was driving an old chev..... Lol. Anyway I found that driving in S mode and keeping it limited to 5th gear seems to help, limiting 6th gear for long flat drives with no head wind.
    To me it now just seems like a 4 speed transmission with an overdrive on an overdrive.
    To keep a motor that has no power in low rpm constantly in that range seems crazy.
  18. Jun 27, 2016 at 2:26 PM
    #338
    fshams
    fshams Well-Known Member
    Columbus, OH
    2012 Tacoma V6 4x4 TRD/TX PRO - DCSB
    I hope so. I just emailed my dealer here in Columbus, and waiting to hear back.
  19. Jul 6, 2016 at 6:23 AM
    #339
    mikey4x4
    mikey4x4 Well-Known Member
    Fred
    2017 TRD Sport DC 4X4 3.5 - 6 speed auto.
    none
    mikey4x4 , Birmingham. Would love to talk to PPortera. proud four time owner of Tacoma DCSB double cabs V6 auto trans., until my special ordered three month wait 2016 same configuration. The words dismayed, disappointed , baffled ownership does not describe the experience. will not elaborate for 16 Tacoma owners know full well our plight. Toyota , time to address the issues, correct issues (numerous) , and stop hiding behind the hallowed T crest.word is out with Tacoma owners, twins are building a potential take over, and with all that is going on with Tacoma, Frontier is building steam, why could be related to Toyota turning deaf ears to the loyal Tacoma owners...... May and June Tacoma sales down.....go figure
    moab4x432 likes this.
  20. Jul 6, 2016 at 9:41 AM
    #340
    moab4x432
    Tacoma wa
    TacoJonn, smitty99, JayDubya and 3 others like this.
