2016 AC I4 SR review
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nv529, Sep 17, 2015.
  1. Sep 19, 2015 at 2:42 PM
    #81
    MQQSE
    MQQSE I take naps
    MooseMan
    Palmer, Alaska
    "Stitch" & "Sumbitch"
    You will be fine on P rated tires. I run LT tires in Summer to avoid cutting down a tire on the gravel roads I find myself using during fishing and hunting season. They do lend to a rougher ride and have to be aired up to between 40-50 lbs to avoid sucking down my MPGs. I'll likely go back to P rated when the current set wears down; I find I ride with my buddy in his Dodge 3500 dually more often than not on those trips any more.
  2. Sep 19, 2015 at 2:57 PM
    #82
    Eric5273
    Eric5273 Well-Known Member
    Eric
    New Jersey
    That is a very big difference. I have read that adding 1 lb unsprung weight is like adding 10 lbs of regular vehicle weight. So if you are adding 8 lbs unsprung weight per tire, that is 32 lbs total unsprung weight, or the equivalent to adding 320 lbs to your vehicle.
  3. Sep 19, 2015 at 3:22 PM
    #83
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Could be.
    The difference of my tire and yours maybe only a pound. So I'll be curious to see your results.
  4. Sep 19, 2015 at 3:50 PM
    #84
    BrennMan
    BrennMan Well-Known Member
    01 TRD Access Cab (current) 07 PreRunner TRD (sold)
    5100s, Weather Tech, Wet Okole, 1.25" spidertrax, pop-lock, Bestopper
    I couldn't agree more!
  5. Sep 19, 2015 at 5:14 PM
    #85
    tubesock
    tubesock Well-Known Member
    Tire weight is not as important as tread pattern/rolling resistance when it comes to fuel economy. It makes a much bigger difference in handling, especially at high speed, which doesn't matter on a truck.
    Here is a test http://www.tirerack.com/wheels/tech/techpage.jsp?techid=108
    In summary they compare a light tire/wheel combo of 38.5lbs to the same tire/tread pattern with a heaver wheel with a total of 48.5lbs. They did some 350 mile road course, I don't know the details. Fuel economy dropped from 21.5 to 21.1. So they added 10 lbs and experienced a 2-3% loss. This was a single test so take that for what it's worth.
    Assuming the single test result has any validity, switching from the stock LRR original equipment tires (combo weight 42.5lbs) to the lighter combo (38.5lbs) with a different tread pattern dropped from 22.8 to 21.5mpg, ~6%. The lighter tire combo had worse fuel economy.
    BMW 3 Series equipped with Original Equipment (16") Stock 38.7mph (avg) 22.8mpg
    BMW 3 Series equipped with Plus One (17") Lightweight 39.0mph (avg) 21.5mpg
    BMW 3 Series equipped with Plus One (17") Heavyweight 38.8mph (avg) 21.1mpg
    DVexile likes this.
  6. Sep 19, 2015 at 5:40 PM
    #86
    T4RFTMFW
    Eh. I would pay more attention to a test specifically to a 2.7 Tacoma.
  7. Sep 19, 2015 at 5:58 PM
    #87
    T4RFTMFW
    Good info for BMW 3 series owners though. ;)
  8. Sep 19, 2015 at 8:59 PM
    #88
    tubesock
    I'll bite anyway in case anyone is genuinely confused. Trying to estimate fuel economy losses based on weight differences of tires with different tread patterns is a bad plan. In the experiment in that article, changing the tread pattern made a much bigger difference than the weight of the tires. You can use a lighter tire with a different tread pattern and still drop MPGs. This is independent of vehicle type or engine.
    DVexile and 0uTkAsT like this.
  9. Sep 19, 2015 at 9:13 PM
    #89
    T4RFTMFW
    Sure. No doubting that.
    I meant more that I don't really care how tread type effects a BMW 3 series. I know that tread matters which is why I say I went from a 245/75 highway tire to a mild all terrain 265/75, but as far as how much the difference makes in numbers and percentages it doesn't really mean anything.
    The 2.7 chokes a lot easier than a 3 series. I would be curious to see how it would fare, judging by my result, and the result of others who are running a 265/75 very mild all terrain/highway tire like a Michelin LTX, they're not getting much less of a hit than I am. So a change in thread pattern is less of a problem in comparison, and weight is more of a problem.
  10. Sep 19, 2015 at 9:46 PM
    #90
    Eric5273
    Eric
    New Jersey
    Here's another picture of the base SR:
    nv529[OP], 0uTkAsT and Apd like this.
  11. Sep 19, 2015 at 9:49 PM
    #91
    T4RFTMFW
    Text the number for details. ;) :D
    Apd likes this.
  12. Sep 19, 2015 at 9:50 PM
    #92
    Apd
    Apd Well-Known Member
    707
    I bet it would look pretty sweet with the black alloys option.
  13. Sep 19, 2015 at 9:52 PM
    #93
    Eric5273
    Eric
    New Jersey
    0uTkAsT[QUOTED] and nv529[OP] like this.
  14. Sep 19, 2015 at 10:11 PM
    #94
    nv529
    nv529 [OP] Well-Known Member
    Nick
    Metro Detroit, Michigan
    2006 Long Travel Taco, 2010 FJC, 2018 F250 Alumiduty
    It looks great in MGM.
  15. Sep 19, 2015 at 10:17 PM
    #95
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    They brought back ECT power? I didn't know that until now, that should make a difference as well. I love that feature in my first gen, very handy for passing and towing trailers.
    0uTkAsT likes this.
  16. Sep 20, 2015 at 11:14 AM
    #96
    nv529
    Nick
    It looks good without flares. The photos don't do it justice, you have to see it in person. Also the factory wheel offset looks better without flares.
  17. Sep 20, 2015 at 11:17 AM
    #97
    Apd
    707
    With that said I'm guessing skinnier tires would look better without the flares. Maybe some 265/70/16s.
    nv529[QUOTED][OP] likes this.
  18. Sep 20, 2015 at 11:32 AM
    #98
    Apd
    707
    Not getting the black alloys?
  19. Sep 20, 2015 at 4:44 PM
    #99
    Jeffaz1
    Jeffaz1 Well-Known Member
    Phoenix, AZ
    2020 Tacoma TRD Pro MGM
    Same exact wheels I have on my 06 Prerunner minus the 2 center caps that fell off... kind of disappointing. When you claim everything is brand new except maybe a seatbelt bracket, don't put the same old wheels from 10 years ago on there.
  20. Sep 20, 2015 at 6:12 PM
    #100
    T4RFTMFW
    You think they should update cheap, bottom of the barrel steel wheels?
    0uTkAsT likes this.
