2016 aftermarket tow hitch / wiring mounting installation question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Caliph420, Mar 8, 2016.
  1. Mar 11, 2016 at 10:15 AM
    snefo
    snefo Well-Known Member
    Yes! Yes! Yes. You sir are my hero. The 2016 Tacoma uses the Tundra style 7/4 pin plug in the bumper, so this will snap into our bumper. Slick. No need to solder as Hopkins sells a plug for the forward half of our new bumper receptacle. So after the 4 pin connector is cut off the T harness and wired to the new receptacle pigtail, we can now plug either a 7 pin or a 4 pin into our bumper and have trailer lights. Plugging in a 7 pin will not give you brakes though unless you use the unused wires to install a brake controller. This is the information I was hoping for. Thank you NEAScott. Did I get this correct?
    duece5811 and Claudiomartinof like this.
  2. Mar 11, 2016 at 1:43 PM
    snefo
    Okay, so I did some research on the e-trailer website. If you go to part number HM40985 and down to Q&A, the tech answers a question about installing the factory style 7/4 pin bumper receptacle (PN HM40975) and the pigtail (HM40985) on a 2016 Tacoma, along with instructions and part recommendations for installing a brake controller. There is a video of them installing a flat 4 three wire to 2 wire converter. They basically show every wire. I may go this route rather than waiting for a plug and play because you have to tap into the reverse light wire anyway if you want reverse lights on your trailer. It's about $85 for everything to have a 7/4 plug in your bumper wired and ready to go. Add another $170 if you want the fancy P2 Prodigy brake controller wires and circuit breakers.
  3. Mar 12, 2016 at 9:35 AM
    simarr24
    simarr24 New Member
    http://www.curtmfg.com/part/56282#tab=vehicles
    Saw this today. Kind of excited. I like the idea of using HM40975 with this curt like the schematic mentioned earlier. I don't think I'll need 7-pin to work anytime soon. So I was wondering if the 4-pin connection on the HM40975 would work if you only wired the needed connections for the 4-pin connection?
    Claudiomartinof likes this.
  4. Jul 6, 2016 at 4:32 PM
    eodhands
    eodhands Member
    Eglin AFB, FL
    2016 Magnetic Grey Tacoma SR5
    American Covers Tri-fold Soft Tonneau Cover
    Where do you connect the Hopkins #33355? Etrailer website says it is a confirmed fit however it does not connect behind the tail lights.
  5. Jul 6, 2016 at 4:42 PM
    ExplorHer
    ExplorHer Question Authority
    Near Pittsburgh
    2016 4cyl, 5MT, 4x4, 2 seats, dents, & rust
  6. Jul 6, 2016 at 5:18 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Those converters aren't sealed very well. If you live in the north east expect to replace it in 2-3 years other place without the salt it'll last longer but they aren't water proof either
  7. Jul 6, 2016 at 11:05 PM
    evilfij
    evilfij Well-Known Member
    2016 ACLB SR 4x4 MT Utility Package Black
    TRDOR wheels, sheepskin seat, cruise and intermittent wipers, curt hitch
    The install is appalling. No loom, a crimp connector on a power wire at the rear of the vehicle!
    There must be a better option. How much is the genuine Toyota harness?
  8. Jul 6, 2016 at 11:42 PM
    axisofoil
    axisofoil Rocket Surgeon
    Gilbert, AZ
    2016 TRD OR Dcsb 4x2
    It's almost like they wanted to make it just hard enough that people would pay Toyota to include a tow package on their truck.
  9. Jul 7, 2016 at 12:50 AM
    evilfij
    I would have happily forked over $650 for a tow package, but it is not available on 4 cylinder tacos.
  10. Jul 7, 2016 at 7:17 AM
    axisofoil
    Gilbert, AZ
    That sounds almost like they wanted people to fork over at few more thousand for the v6, too.
    I bet there are lots of people that spent thousands on higher trim levels for a single feature, and got dozens that they didn't need or want instead. I wanted dual zone ac... So that means I have a sunroof and heated seats that I didn't want. And a big hole in my pocket where my premium/tech money lived.
  11. Jul 7, 2016 at 5:27 PM
    evilfij
    The Curt hitch is a pain in the neck to install. The captive plates and bolts and incredibly frustrating. Wasted 20 minutes trying to get one to work (yes tilting the plate etc.) and then gave up as it was too hot.
    Someone needs to sell me a factory hitch and factory wiring. I don't care about the cost this aftermarket stuff is garbage.
  12. Oct 29, 2016 at 8:47 AM
    TSC
    TSC New Member
    Trudie
    2007 Black Toyota Tacoma
    Hi I am inquiring how to install a Hopkins wiring kit #47185 to my 2007 Tacoma? Obviously the hopkins wiring is different and i need to know the wiring diagram from my truck and what colors do what to match with my hopkins wiring???
  13. Oct 29, 2016 at 7:04 PM
    Caliph420
    Caliph420 [OP] Well-Known Member
    Washington
    2012 SR5 2.7 AC 4x4 Manual
    I ended up scrapping those plates it came with and just tightening the bolts without them
  14. Dec 28, 2016 at 8:07 AM
    7r41lbr34k3r
    7r41lbr34k3r Practitioner of the mechanical arts.
    Houston, TX
    '21 Tundra 1794 OR
    Thank you very much!
  15. Dec 28, 2016 at 8:15 AM
    #35
    Shadowray
    Shadowray 3rd Gen back to 2nd Gen...
    Arkansas
    2012 Tacoma TRD Sport
    Did this Curt setup and bought the oval plug connector and everything looks and worked great. Didn't read all the threads but if anyone needs info PM me.
    7r41lbr34k3r likes this.
  16. Dec 28, 2016 at 8:37 AM
    #36
    7r41lbr34k3r
    Houston, TX
    '21 Tundra 1794 OR
  17. Dec 28, 2016 at 8:43 AM
    #37
    Shadowray
    Arkansas
  18. Apr 21, 2017 at 1:20 PM
    #38
    Peanut83
    Peanut83 Member
    Joe
    Your truck is better
    I have tires
    I have a factory hitch if anyone wants it, looking for $200 and it's yours. Pickup in Las Vegas.
  19. Jun 7, 2017 at 3:55 PM
    #39
    Toronto Tacoma
    Toronto Tacoma Well-Known Member
    Blair
    Toronto Canada
    2019 TRD Offroad
    None,
    agreed,
    I am having my dealer install a hitch and harness next week
    duece5811 likes this.
  20. Jun 7, 2017 at 4:17 PM
    #40
    L3TT3RS
    L3TT3RS Well-Known Member
    Taylor
    Longview, Texas
    2019 Tundra-> Fox/Total Chaos/Coachbuilder
    I think you would be much happier going with oem
