2016 and 2017 Shift Flare is Declared Characteristic
Discussion in '3rd Gen. Tacomas (2016-2023)' started by bradwhitenikki, Nov 13, 2016.
  1. Nov 13, 2016 at 1:31 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    That little rpm rise? Really? That's what has you all up in arms?
    3dBdown, Hank Heel and Aussiek2000 like this.
  2. Nov 13, 2016 at 1:36 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    where have you been? figured you moved on to another vehicle.
  3. Nov 13, 2016 at 1:39 PM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    You should know by now that these guys spent a whopping $35k on a Tacoma. It should compare to a $250k+ rolls Royce
  4. Nov 13, 2016 at 1:42 PM
    BuckeyeTom
    BuckeyeTom Active Member
    16 DCSB 4x4
    If you had this problem I'm sure you would be like wtf.
    If I don't let off the gas it will slip over 2k rpms.
    bradwhitenikki[OP] likes this.
  5. Nov 13, 2016 at 1:43 PM
    boynoyce
    boynoyce .
    16SR5AC4X4V6QS
    not a mechanic and wondering this also- why is the shift flair so important- especially if Toyota dismisses it as characteristic of the transmission?
    Taco16LB likes this.
  6. Nov 13, 2016 at 1:46 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Up to to 2krpms from what, 1600? Does it go away after the truck warms up?
    I don't have the symptom but I know the 2nd gens suffer from it along with alot of other car and truck brands that use Aisin automatic transmissions. Anyone know of it escalating to a direct transmission failure in a Toyota?
  7. Nov 13, 2016 at 1:50 PM
    Clearwater Bill
    Billy
    Largo Florida
    Must be using the same attorney firms that politicians use, as denial is always the first step.
  8. Nov 13, 2016 at 1:54 PM
    BuckeyeTom
    16 DCSB 4x4
    Between 1600 and 1800 rpm. It goes away but comes back after sitting for a hour or so.
    Fluid has been checked, TSB installed. Told the same as others here from corporate that it is characteristic of the transmission.
  9. Nov 13, 2016 at 2:01 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Unless the aftermarket releases a kit for the 3rd gen to install like Sonnax did for the 2nd gen you will probably continue to have the symptom.
    Like I asked earlier, I know some of you don't like the symptom but does anyone know of it leading to an actual transmission failure in a Toyota?
    Or will it just be an annoyance you'll have to learn to live with. If it doesn't expedite a failure I wouldn't expect Toyota to really push Aisin to correct it.
    boynoyce likes this.
  10. Nov 13, 2016 at 2:26 PM
    bradwhitenikki
    bradwhitenikki [OP] Well-Known Member
    Brad
    2016 Tacoma Trd Off Road 6sp Auto
    Correct.
  11. Nov 13, 2016 at 2:28 PM
    bradwhitenikki
    Brad
    Yes. The fluid was checked manually. You are right. This is not a normal behavior for a correctly designed transmission.
  12. Nov 13, 2016 at 2:30 PM
    bradwhitenikki
    Brad
    Good question JS. The transmission can out in 2016. We will know the answer after the waranty runs out.
  13. Nov 13, 2016 at 2:31 PM
    bradwhitenikki
    Brad
    Yes gear head, really. The Toyota engineers agree as well.
  14. Nov 13, 2016 at 2:32 PM
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Plenty of shift flaring 2nd gens running around, anyone know of them failing?
  15. Nov 13, 2016 at 2:35 PM
    #35
    bradwhitenikki
    Brad
    True. Hopefully we will have the same luck.
  16. Nov 13, 2016 at 2:35 PM
    #36
    scornwel
    scornwel Well-Known Member
    Fort Worth
    2016 White TRD OR 4x4
    None
    The shift flare started after they applied the TSB - on my truck.
    busticator[QUOTED] likes this.
  17. Nov 13, 2016 at 2:36 PM
    #37
    BuckeyeTom
    16 DCSB 4x4
    I am being patient with the hope a fix comes out. I really like the truck, even tried out a manual on Friday. Dealer even offered me to take it for the weekend. I'll give it a few more months.
  18. Nov 13, 2016 at 2:40 PM
    #38
    scornwel
    Fort Worth
    None
    I actually agree with you. I have the 3-4 flare and only on the first drive in the morning. It flares but does shift smoothly so it could be a harmless characteristic.
    But the trans does not shift like I'm used to. Perhaps this is the new normal. I sure hope not.
  19. Nov 13, 2016 at 2:46 PM
    #39
    TRD493
    TRD493 Well-Known Member
    Dave
    Texas (DFW)
    17 TRD Sport DCLB 4x4 / 01 4x4 V6 Extra Cab TRD SR5
    Yep, but not very often.
    Edit: it's happened maybe 3-4 times since I've had it. Currently at 2600 miles
  20. Nov 13, 2016 at 2:52 PM
    #40
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    How long from since you had the TSB performed?
    I also expect with temps dropping and trans fluid temps being cooler the flare might become more pronounced. Whether it hurts the truck or not I don't know but we'll likely see a rash of more reports as more trucks are on the road, weather is getting colder and now readers are going to be hyper - sensitive now to reporting it.
