2016+ Backup Camera Anytime *Mod*
Discussion in '3rd Gen. Tacomas (2016+)' started by CanyonRunner, Oct 26, 2016.
  1. Oct 26, 2016 at 11:23 AM
    CanyonRunner
    CanyonRunner [OP] Well-Known Member
    2016 TRD Sport 4X4 DoubleCab
    $$$ Too Many....
    This allows you to use the backup camera anytime, not just while in reverse. With the switch off, it still comes on in R just like factory. Hope this helps some people!
    Locate the Reverse 12+ signal input
    (the pic shown is looking down at the back of the head-unit while installed)
    Cut wire and install a diode on the wire connecting the two again (band/cathode side closest to head unit wire harness) with a lead wire coming out of the side closest to head unit. (you must use a diode to prevent the reverse lights from coming on when triggered)
    Run that wire to a on/off switch with a 12v+ ignition source on the other side of switch, Done!
    All this is almost as the same as the Tundra, just different color wires.
    Other good info here --> http://www.tundratalk.net/forums/interior-mods/269225-2014-backup-camera-anytime.html
  2. Oct 26, 2016 at 11:25 AM
    CanyonRunner
    $$$ Too Many....
    For the Nav in-motion lock-out override, just cut the SSW wire and run both leads to a switch. Then flip switch to use features, vehicle thinks you are stopped.
  3. Oct 26, 2016 at 12:12 PM
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    The first photo is not showing - probably because it's not public in your Google account.
  4. Oct 26, 2016 at 12:14 PM
    Vancouver, BC
    Now that would be super useful. I'm assuming the vehicle will show speed as 0 when the switch is disconnected? Any other downsides to running disconnected all the time?
  5. Oct 26, 2016 at 12:22 PM
    CanyonRunner
    $$$ Too Many....
    Yea, that would help maybe, fixed it.
    Yes shows 0, switch to make changes, then switch back after finished so location/speed is accurate data.
  6. Oct 26, 2016 at 12:24 PM
    Vancouver, BC
    Works now.
    Cool. Almost certainly going to do the navi hack. Thanks for the details!
    CanyonRunner likes this.
  7. Oct 26, 2016 at 12:29 PM
    Siblue
    Siblue Well-Known Member
    So Cal
    2016 TRD Sport MGM
    Vote for STICKY. Good work.
    Sndtrper, 0210 and CanyonRunner like this.
  8. Oct 26, 2016 at 12:39 PM
    CanyonRunner
    $$$ Too Many....
    The camera mod comes in very handy for those with a canopy or big high load to see out the back. Also to check on trailer when in tow or see how close that car is you think bumped you at the light. Offroad is very handy as well, or just looking at the person behind you picking their nose at the drive-thru. Nav-mod is nice not have to be stopped to make changes in route or see whats close by to eat while still moving.
  9. Oct 26, 2016 at 1:21 PM
    MilkTeacoma
    MilkTeacoma @MilkTeacoma (IG)
    Bernie
    Moorpark, CA
    3rd Gen Toyota Tacoma (2016) TRD Off-road 4x4 Quicksand Dbl Cab Shortbed Automatic
    View my profile for modification list to our 3rd Gen Tacoma. - Speedometer Calibrator by Hypertech - 1.5" Front Wheel Adapters by The Suspension Source - 1.25" Front Wheel Adapters by The Suspension Source - Open Country A/T 285/75R16 Tires by Toyo Tires - Front 2.5" Lift Spacer by Maxtrac Suspension - Rear 1" Lift Block by Maxtrac Suspension - Air Deflator by VIAIR - Organizer Tray by Salex Organizer - Vehicle OCD by Salex Organizer - Digital Video Recorder by NSV Auto - USB Charger by NSV Auto - Painted Front Grill Emblem - A/C Drain Mod - Easy-Out Awning with Brackets by Front Runner Outfitters - Cargo Roller by Front Runner Outfitters - Titanium Shackle by Front Runner Outfitters - CB-Way Radio by Midland - "LED Bar" Light Switch & Wiring Harness by MIC Tuning - Matte Black Vinyl Roof & Hood by Vaderwerks - CD Slot Smartphone Car Mount Holder Cradle by Koomus Pro - GasPods by AeroHance - SR5 Grill - Slimline2 Roof Rack by Front Runner Outfitters - Pro Stainless Steel Camp Table w/under-rack Table Latch MKII by Front Runner Outfitters - 40" LED Light Bar w/rack mount brackets by Front Runner Outfitters - Rack Mounted Bottle Opener by Front Runner Outfitters - Pair of Stratchits by Front Runner Outfitters - Galvanized Tie Down Rings by Front Runner Outfitters - BF Xenon LED Headlights - Matte Black Vinyl Rear Bumper Caps by Vaderwerks - Matte Black Vinyl Rear Lower Tailgate by Vaderwerks - Black SR Grill with Factory Black Grill Trim - Black Inner Housing LED Fog Lights - Legacy Plate (on the way) - LED Cargo Bed Lights - Cargo Divider - Qi Wireless Charging Receiver - Power Tailgate Lock by Pop&Lock - Removed B-Pillar Black Vinyl - Mobtown Offroad Recovery Bumper - QuickLIFT Hood System by Redline Tuning - Automatic Smart Driving Assistant (OBD2) - Remove Factory Emblems & TRD Decals - Remove Dealer Decals & Plates - Broadway 400mm Rearview Mirror
    This is awesome. I wonder if you add another (front) camera and an another switch, and somewhat wire them the same, then you can toggle between the cameras?
    FreshMexicanTaco, smuckers and wtf like this.
  10. Oct 26, 2016 at 1:31 PM
    Woodrow F Call
    Woodrow F Call Well-Known Member
    Red Stick, Louisiana
    2016 DCSB SR5 Tacoma 4X4
    Cool mod. Thanks.
  11. Oct 26, 2016 at 1:36 PM
    Vancouver, BC
    There are quite a few threads on front-cameras. I already have one that's standalone, but plan to add a "proper" one that will display on the main dash unit. Switching between cameras should be quite doable.
    https://www.tacomaworld.com/threads/adding-a-front-camera.354084/
    MilkTeacoma likes this.
  12. Oct 26, 2016 at 4:06 PM
    bobrown14
    bobrown14 Well-Known Member
    Bob
    Philadelphia
    2016 Tacoma TRD Sport DC-SB M/T MGM
    Wheels tires sliders LED fogs VooDoo racks tail gate letters bed liner - suspension on the way....
    :thumbsup: Thanks OP awesome.. another vote for sticky.
    Come in handy at a red light when someone's right up my ass and I cant see them.....
  13. Nov 1, 2016 at 6:45 PM
    imtaconico
    imtaconico Well-Known Member
    Nicole
    SGV, Ca
    16 4x4 TRD Spt, DCLB, JBL
    Prinsu designs rack, Softopper, SCS Ray10 17"x 8.5", BFG KO2 265/70/17
  14. Nov 1, 2016 at 6:48 PM
    WHOISTYLER
    WHOISTYLER Well-Known Member
    Tyler
    Denver, CO
    2016 MGM TRD OR DCSB
  15. Nov 1, 2016 at 6:52 PM
    Furry
    Furry Well-Known Member
    Montana Mountains
    2016 TRD OR DCLB
    2.5" lift, 265/75R16s, UCAs
    Nice! I've been wanting to have that feature..... Now, just need to find someone to do that for me while I watch.:popcorn:
    JaCado likes this.
  16. Nov 2, 2016 at 9:03 AM
    medic49
    medic49 Well-Known Member
    Dfw
    2017 trd sport 4x4 quad
    I don't have a book on how the truck comes apart yet. How much of the dash has to come off to get that head unit out?
  17. Nov 2, 2016 at 9:26 AM
    medic49
    Dfw
    Also, what kind of diode did you use? I've never used one before but have found there are several types and different electrical ratings.
  18. Nov 2, 2016 at 11:19 AM
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    cool mod, I would do this if it was plug n play. I'm not big into cutting OEM harnesses.
    specter208, Tucktuck8 and Hank Heel like this.
  19. Nov 2, 2016 at 11:48 AM
    Danielnc06
    Danielnc06 Well-Known Member
    NC
    2016 TRD DCLB
    Just pop the colored trim off. unscrew four head unit screws
    medic49 likes this.
  20. Nov 3, 2016 at 5:35 PM
    ekimerpud
    ekimerpud Well-Known Member
    Fort Worth, TX
