2016 DCLB SR5 4x4 Transfer Case Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RoccoTaco, Feb 14, 2023.
  1. Feb 15, 2023 at 12:52 PM
    RoccoTaco
    RoccoTaco [OP] Active Member
    Rocco
    2016 Silver SR5 DCLB 4x4 Snugtop SS
    Stock for now...
    Yup, no codes on the dash… dealership says it’s normal for the front shaft to spin in 2wd. According to them so far… according tit he service manager.
    Now the service manager asked the shop guy and he said “some do, some don’t. Bring it in and we’ll diagnose it.”
    I’m hesitant to diagnose it at the dealer because if I do and it’s bad, it’s on file… Then I can’t punt it to carmax.
    new transfer case is $3500… then add labor.
  2. Feb 15, 2023 at 1:03 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Definitely not correct. Plenty of dealer workers don't know the ins and outs of the norms for each vehicle. There are many production 4WD vehicles where the front spins full time - but the Tacoma is not one.
    LeakyAC likes this.
  3. Feb 15, 2023 at 1:03 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Have you ruled out U-Joints? 2016 4x4s have 2 greasable Zerks on the front shaft and 3 on the rear.
    RustyGreen and petethemeat like this.
  4. Feb 15, 2023 at 1:07 PM
    BLtheP
    Plano, TX
    Transfer cases are not that complex of a device...I would think it could be fixed fairly cheaply at a place that isn't going to throw a whole new transfer case at it, i.e. the dealer. Usually some RTV to open it up and seal it back up, whatever's broken is likely one or two parts. Not saying you should necessarily get it repaired, but it would be a lot cheaper than $3500.
    You could also look at getting a used tcase off of eBay and just install it yourself. That's more around the $800 range.
    As for the some do, some don't comment, a Tacoma should not have the front driveshaft spin in 2WD, period. That is just simply how the design is. Something is for sure wrong if it is spinning.
    RoccoTaco[QUOTED][OP] likes this.
  5. Feb 15, 2023 at 1:13 PM
    RoccoTaco
    Rocco
    Stock for now...
    I greased them when all the noises started happening.
  6. Feb 15, 2023 at 1:42 PM
    petethemeat
    petethemeat Well-Known Member
    Pete
    Ontario
    2023 TRD OR AC MT
    Did you check the u joints? As in actually remove the shafts to see if the joints have play or are excessively loose when swiveling around. I've had a similar noise when driving with a bad u joint. It was a Chevy but only had like 30,000 miles on it.
  7. Feb 15, 2023 at 1:43 PM
    BLtheP
    Plano, TX
    U-joints won't cause the driveshaft to start spinning when it isn't supposed to.
  8. Feb 15, 2023 at 1:46 PM
    petethemeat
    Pete
    Ontario
    2023 TRD OR AC MT
    No but they will make noise. The front shaft could spin a bit through friction in the transfer case. There is nothing holding it back with the front diff disengaged. At least her can rule them out and test the transfer case further when the shafts aren't connected.
  9. Feb 15, 2023 at 1:58 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i would also go to a personally owned independent transmission shop that will rebuild a transfer case themselves and not send it out, and get their opinion and price. take your phone video with you and show it to them.
    there is not that much inside it having watched Ian rebuild them on the Four Wheeler TV show
  10. Feb 18, 2023 at 12:15 PM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    The transfer case oil pump runs off the planet carrier so it's pumping anytime the input shaft is spinning since the input gear (sun) is always in mesh with the planets.
    But the transfer case input to rear output relationship will always be 1:1 in HI range.
  11. Feb 18, 2023 at 12:20 PM
    ShimStack
    Ben
    NC
    The caveat with this is just under the right conditions in 2wd the front driveshaft *can* spin. Basically, if friction is low enough and oil is viscous enough you can get the front shaft to spin via the oil drag. The rate it spins will be a small fraction of the rear driveline speed and should no way be the cause of this noise. You can normally get this to happen by shifting from 4HI to 2HI at speed. I've noticed the front shaft will continue to slow rotate until you stop.
  12. Feb 18, 2023 at 1:59 PM
    RoccoTaco
    Rocco
    Stock for now...
    Okay I’ve got an update. I pulled the rear driveshaft entirely to get tot he bottom of this. I drove the truck around in 4 high and everything ran smooth as silk! I mean smoother than it’s ever been before. I took the driveshaft to the local machine shop and had him press in all new U joints despite them not feeling too bad. Driveshaft was out anyway so I figured why not. Popped the shaft back in and no more noise. Must have been a u joint that was getting close to bad.
    the bitch of it is, it started it’s usual shaky shakes at freeway speed again as soon as the driveshaft went back in. Sounds like I have an out of balance shaft or the trouble many of us long bed guys run into. The long driveshaft seems to cause lots of bad vibes. I’m looking into solutions… thank you all for the help.
  13. Feb 18, 2023 at 2:25 PM
    Canadian Caber
    Canadian Caber R.I.P Layne Staley 67-2002
    Les
    B.C. Canada, eh
    2020 TRD Sport DCLB 4X4 Super White
    Thanks for the update. Interesting thread. Great that you have it narrowed down to the drive shaft. I have a long box as well and no issues.
  14. Feb 19, 2023 at 5:50 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Progress :thumbsup:
    Call around and find out who builds driveshafts around you, try a heavy truck garage or NAPA store.
    The driveshaft shop can check for straightness, balance and make repairs as needed.
    You just bring them the shaft, not the whole truck. ;)
    Hold the U-Joint caps in place with electrical tape.
    Canadian Caber likes this.
