2016 exhaust
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dorag, Dec 26, 2015.
  1. Dec 27, 2015 at 6:07 AM
    #41
    gsxxr
    gsxxr Well-Known Member
    2016 tacoma trd sport
    3" lift, goodyear wrangler duratracs 285/70r17, k&n filter, bakflip vp tonneau and tint.
    You and others can assume what ever you like.
    When you have engine air flow coming through the intake system with open tp. You create an air stream. When the tb butterfly closes the air hits the butterfly and causes turbulence in the intake system causing air with vapors travel back to the filter.
    This is why you also have the big damper/ resonator on the intake pipe.
  2. Dec 27, 2015 at 6:09 AM
    #42
    gsxxr
    Also the map sensor is directly attached the the intake. It does see oil vapors from the pcv. It has little are moving in and out of it. But they do get dirty and clogged at times.
  3. Dec 27, 2015 at 6:13 AM
    #43
    gsxxr
  4. Dec 27, 2015 at 6:14 AM
    #44
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    You are wrong on all "theories". Have fun, I'll be sure to laugh when you make a thread in a few thousand miles about ruck not running/shifting correctly.
  5. Dec 27, 2015 at 6:15 AM
    #45
    gsxxr
    Don't count on it. Look where the pcv tube is. Do you know why?
  6. Dec 27, 2015 at 6:16 AM
    #46
    gsxxr
    It's a shame guys like you won't listen and learn and you just keep passing poor information along.
  7. Dec 27, 2015 at 6:20 AM
    #47
    gsxxr
    You want to eliminate oil vapors into the I take or minimize them to help keep sensor clean. Use a pvc catch can
  8. Dec 27, 2015 at 6:32 AM
    #48
    Farmcat
    Farmcat Well-Known Member
    Super White DCSB Off Road 4wd
    :popcorn:
    Justus likes this.
  9. Dec 27, 2015 at 6:40 AM
    #49
    Aussiek2000
    2016 Offroad AC
    That's the fresh air feed port for the engine. The engine relies on a flow of air through the crankcase. The oily/dirty output is plumbed directly into the intake manifold. It never sees the MAF
    Justus likes this.
  10. Dec 27, 2015 at 6:42 AM
    #50
    Aussiek2000
    2016 Offroad AC
    Got you covered. This is my other car.
  11. Dec 27, 2015 at 6:45 AM
    #51
    Aussiek2000
    2016 Offroad AC
    And it has real exhaust. Not some rice ass sounding Tacoma with flow masters
    10174793_10155411331895232_1805665948381_1cd39433e3b82d53eeb409d28bb820ca8ec08845.jpg
  12. Dec 27, 2015 at 7:16 AM
    #52
    gsxxr
    We are like brothers lol
  13. Dec 27, 2015 at 9:58 AM
    #53
    Blazingbluesport
    Blazingbluesport Well-Known Member
    The OC!
    2016 TRD Sport 4x4 double cab.
    So is the oil in the TRD filter different from the K&N? Totota approves the TRD filter for ECU and emissions. Or is the issue K&N uses to much oil? I would venture to say not much difference between a K&N and a TRD filter. Probably made by the same company. I doubt TRD has its own air filter factory. I think this is just dealerships unhappy that they can't charge you for a new air filter and they send out bulletins to there techs telling them to put the blame on the aftermarket filter to avoid cost of replacing a defective component, and Auto manufacturers unhappy with the sizable aftermarket industry taking away from their sizable profits. I respect your opinions but encourage reading from other sources. There is to date no confirmed instance of a MAF being clogged and inoperative because of the oil particles from an aftermarket filter. Maybe start by reading the Magnuson-Moss warranty act. The number one contaminate found to have caused problems in defective MAFs is silicon, traced to the sensors housing. Unlike oil it does not burn off. Now all that being said unless you run your engine at full throttle 50% of the time or more your horsepower and fuel consumption improvement will be negligible. It's more about the cost savings to replace paper filters.
  14. Dec 27, 2015 at 9:59 AM
    #54
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    We're pretty much triplets....
  15. Dec 27, 2015 at 4:16 PM
    #55
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    Catch can?...lmmfao
  16. Dec 27, 2015 at 7:50 PM
    #56
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    ? Not sure teh funny
    Aussiek2000 likes this.
  17. Dec 28, 2015 at 5:16 AM
    #57
    Dorag
    Dorag [OP] Do Rag
    TRD off road 4x4
    It amazes me all the hub bub over one small idea. I won't debate the filter issue, just to say I have used K&N filters for over a 100k miles with no issue. I think a lot of folks do not understand that engine is just a fancy air pump. It sucks air in and blows it out, with horse power and torque as a by product. An engine can only pump so much air based on it's cubic inches and rpm. The engines of today have all these sensors to help mix air and fuel to the benifit of out put. So in GENERAL if you make it easy for the engine to breathe in and out, you ease the stress on the engine and it works more effectively.
    smugly likes this.
  18. Dec 28, 2015 at 5:42 AM
    #58
    jmaack
    jmaack Well-Known Member
    Justin
    Helena Alabama
    Skewped hood silver 4runner
    Ome, Sqeak free dakars, arms, skids, sliders.
    Overoiled and under oiled you will have issues. I had almost 100k on a nissan ka24e engine and no issues or dirty maf etc.
    Same with my dodge.
    I plan on running one on my tacoma when time comes to change.
    Changing shifts though. I think it's the butt dyno showing it's results.
  19. Dec 28, 2015 at 5:49 AM
    #59
    jmaack
    Justin
    Helena Alabama
    Where do you work? Just curious.
  20. Dec 28, 2015 at 6:20 AM
    #60
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    not on toyota they don't
