2016 exhaust
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dorag, Dec 26, 2015.
  1. Dec 28, 2015 at 6:23 AM
    #61
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    search taco world for a post I put up,
    where I have a link to testing of oem filters vs others, and yes
    absolutely OEM paper filters allow the least amount of silicates
  2. Dec 28, 2015 at 6:34 AM
    #62
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    Does the Tacoma use a paper or cotton-type filter?
  3. Dec 28, 2015 at 6:59 AM
    #63
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    toyota will not specify the fiber matrix they use
    The element has a series of different gauge meshes -
    coarse, medium and fine to trap every size particle. Other types of filters may only have one layer.
    Needle punched filter
    The Toyota Genuine Filter Element is needle-punched to allow for a smooth,
    efficient flow of filtered air to the combustion chamber for clean ignition of fuel.
    Its dust catching ability is up to 30% higher than a normal after-market type filter.
    Lesser quality air filters often use poorly constructed seals and filter elements which
    allow dust and impurities into the engine, causing problems such as poor engine idle,
    extra fuel consumption and unnecessary engine wear.
    *needle punched does not mean there are needle-sized holes air can whizz through
  4. Dec 28, 2015 at 7:33 AM
    #64
    ACKtrd30
    ACKtrd30 Nice Guys don't finish last. Boring guys do.
    Massachusetts
    2016 Desert Storm Trooper
    This
    More air in/out= more power. I learned a lot about this building a rocket 350 in a 70 Cutlass. Got into oversized valves, cam, headers, intake right down to valve guides and rockers to pump air more efficiently. 10.5:1 compression, milled heads, port and polish all helped to make big time power out of an olds 350. Things are different with computers and sensors controlling everything today, but an engine is nothing more than a fancy air pump.
  5. Dec 28, 2015 at 8:48 AM
    #65
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    TRUE but when you have a locked down factory ECU controlling engine management it is not as simple as opening
    up the intake.
  6. Dec 28, 2015 at 9:28 AM
    #66
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    For a new car dealer with 9 franchises.
  7. Dec 28, 2015 at 9:59 AM
    #67
    Ronin229
    Ronin229 Well-Known Member
    Clearwater, FL
    2016 Limited 4x4 Silver Sky
    Ceramic tint with Air Blue80 on front windshield and sunroof Nfab bars
    Isn't putting a "performance" air filter in a modern vehicle useless to begin with?
    I thought with modern ECU's it would just sense the excess air and adjust fuel/air mix to counter it. So in the end you don't really gain anything with the exception of sound.
  8. Dec 28, 2015 at 10:08 AM
    #68
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    this.
    you may see marketing babble that the TRD aftermarket CAI adds HP....~3-11hp
    only on a good day an donly at specific rpm ranges
    and no matter...that amount whatever it is, is not noticeable
    it is the noise which makes you arse-dyno think it does more than simply annoy those around you
  9. Dec 28, 2015 at 10:33 AM
    #69
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    He's a GM Tech... that should be enough
    Aussiek2000 likes this.
  10. Dec 28, 2015 at 11:14 AM
    #70
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    Wasn't this thread about exhaust ??????????
    Scottyd likes this.
  11. Dec 28, 2015 at 11:56 AM
    #71
    TacoThurs
    TacoThurs Active Member
    Terry
    2016 Tacoma TRD Sport
    Does anyone know if an exhuast mod like flowmaster 44's would void the warranty?
  12. Dec 28, 2015 at 12:15 PM
    #72
    TacoThurs
    Terry
    There's some pretty good sound clips on yt with the 44 and 40. Any recommendations? I have not seen any exhaust systems for 16 Tacomas yet.
  13. Dec 28, 2015 at 1:15 PM
    #73
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
  14. Jan 4, 2016 at 1:12 PM
    #74
    proven21
    proven21 Well-Known Member
    Sterling, VA ( Loudoun County)
    2016 Taco DCSBOR 4x4 - Super White
    OME 90021 Front Strut 2887 Coils & OME N182 Rear Shocks, Wheelers Progressive AAL Pack, TC UCA's, BFG TA KO2 285/70r17 w/ 17" Method Wheels, AVS Window Visors, CoverKing NeoSupreme Seat Covers (charcoal/black), Mobtown Offroad Sliders, Relentless Fab. Bed Rack.
    which magnaflow muffler would fit on the 2016?
  15. Jan 4, 2016 at 5:34 PM
    #75
    Bob259
    Bob259 Well-Known Member
    Arizona
    2016 Tacoma Limited DCSB 4x4 3.5 V6
    I've seen several articles that show a new/clean stock air filter works just as good as a K&N filter and as has been mentioned before oil screws up your MAF sensor, because everyone thinks a little more oil is better. The K&N was only marginally better at WOT and how many times are you running like that.
    smitty99 likes this.
  16. Jan 4, 2016 at 5:43 PM
    #76
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    eyebrows..... I knew they was the culprit
    0uTkAsT likes this.
  17. Jan 4, 2016 at 5:57 PM
    #77
    DB444
    DB444 Well-Known Member
    2016 Toyota Tacoma TRD Off road--2015 Toyota Tundra Pro
    I've used K&N air filters on almost every vehicle I've ever owned and have NEVER-EVER had a problem with a mass airflow sensor. I think there are those that like to cry Wolfe just to hear themselves cry. Don't be dumb your whole lives.
  18. Jan 4, 2016 at 5:58 PM
    #78
    unixadm
    unixadm Well-Known Member
    Super White 2015 DCSB 4x4 Off Road
    I was wondering what all of that hair was in my MAF. Didn't look like eyebrows though.........
    Justus[QUOTED] likes this.
  19. Jan 4, 2016 at 5:59 PM
    #79
    unixadm
    You would be surprised how many people have messed up their MAF sensors from oiled filters. It's not some urban myth. Hell I even know one of my ASE mechanic buddies who messed up his MAF on his 99 Taco because of an over oiled filter.
  20. Jan 4, 2016 at 6:00 PM
    #80
    Bob259
    Arizona
    lol love auto spell check ;)
