2016 Fall Camp & Ride (Citrus & Redrock): Photos and Video
Discussion in 'Florida' started by Taco No Baka, Oct 14, 2016.
  1. Oct 14, 2016 at 3:08 AM
    Taco No Baka
    Taco No Baka [OP] Interco Tire Snob
    Lee
    Tampa, FL
    1998 SR5 Xtra Cab 4WD V6 Spartan Package
    OME 3" lift with Dakar rear leaves and 883 front coils. 36x12.50 Super Swamper TSL/SXs on Pro Comp Series 97 15x8 Steelies, Bud Built Front Skid, 4xI rock sliders, 4.88s and an Eaton True Trac LSD up front, 4.88s and a Detroit Locker in the rear, LED cab clearance lights, Sway Bar Delete, Rear Diff Breather Mod, Autometer Monster Tach, Cobra 25LTD Classic, Roof-mounted 3' Firestik Firefly, Garmin GPS, HiLift Jack, Flush-mount LED pod lights in rear bumper, 28" light bar in the front bumper, rear shock relocation (Ruff Stuff brackets), u-bolt flip with Ruff Stuff Anti-wrap perches, CBI rear frame reinforcements, 10" travel Bilstein 5125 rear shocks, heavy duty front crossmember made by Allenfab, Rear shock mounts/crossmember (for upper mounts), spring perches, frame plates, and front crossmember welded in by Allenfab, CBI Ditch Light Brackets, Ditch Light Pods. AllenFab Custom Hybrid front bumper and recovery points. Drivetrain lifted 2" in conjunction with a 2" BL. Modified Trail Gear transmission crossmember/skid. Warn Xeon 10K winch. Large left side body mod.
    This thread is for the photos and video taken during the 2016 Fall Camp & Ride event.
  2. Oct 14, 2016 at 3:39 AM
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  3. Oct 15, 2016 at 4:38 PM
    NABeast
    NABeast Un-Sub’d
    Paul
    Florida
    '08 4wD
    ImMrYo mirror bracket. A/C, P/W, Tilt, Cruise, AM/FM CD
    A couple to get started..
  4. Oct 15, 2016 at 4:45 PM
    JediScout
    JediScout Well-Known Member
    David
    Georgia
    2013 Tacoma 4x4 TRD Off Road
    Filters: K&N Air Filter Engine, Cabin Air Filters Uni Filter Mod 4.88 re-gear front and rear Yukon Gears Suspension: Rago Fabrication Leafpack Hangers Ironman 4x4 FOAM CELL PRO SUSPENSION LIFT KIT FOR TOYOTA TACOMA 2005-2023 Stage 2 Upper Control arms 2.5" Heavy Load Front springs and shocks Heavy load leaf pack Wheels: 17" RRW RR5-S x5 BFG K03 285/70/17 Brakes: Power Stop KC 137-36 Z36 Front Calipers/Rotors/Pads Power Stop KOE15389DK Rear Drum Brakes Electrical System and Accessories: Genesis Dual battery Kit: 201-TT2DBK x2 Full Throttle Group 34 Batteries: FT825-34 SPOD w/Bluetooth w/Custom OTRATTW Rocker Switch Panel Cali Raised Front Pillar Lights Cali Raised 42" Light Bar Auxbeam Rear Ditch Lights Procomp RGB Rock Lights (Bluetooth Enabled) CSI 52qt Fridge ~hardwired w/Anderson Plug Connections to main battery. CSI Fridge Sliding Tray 15 amp circuit breaker on CSI Smittybuilt Air compressor 2781 (Anderson Plug connector Mod) 50 amp circuit breaker w/Anderson Plug Connector Prinsu Roof Rack Plano case with all recovery gear CVT RTT Mt. Shasta w/Awning 23Zero 180* Awning Rago Fabrication bed bars Interior Mods: Installed quad USB charging ports in Dash Exterior Mods: ATH High Clearance Rear Bumper w/Swing Out Tire Carrier Installed Separate Dual Waterproof USB Charging Ports in Truck Bed Rago Fabrication Bed Stiffeners Communications: Midland MXT275 GMRS Radio Midland FRS handhelds BaoFeng UV5R HAM Radio Recovery Gear: Maxtrax (Red) Bunker Industry Mini Traction Boards (Great for Leveling, Red) Bubba Rope 20,000lbs Bubba Rope Soft shackles
    My son didn't stop talking about storm troopers and StarWars!
    Good meeting you fellas. Gotta get more of this action in while I'm stationed down here!
  5. Oct 15, 2016 at 7:59 PM
    WendyTaco
    WendyTaco Well-Known Member
    Kyler
    2017 TRD Off-Road
  6. Oct 16, 2016 at 9:23 AM
    Killowatt
    Killowatt Well-Known Member
    Citrus County Florida
    2013 4x4 TRD OFF ROAD
  7. Oct 16, 2016 at 10:42 AM
    michaelrussell
    michaelrussell Well-Known Member
    Michael
    belleview,FL
    09 prerunner sr5 2.7 / 5 speed
    lots of stuff done more to do
  8. Oct 16, 2016 at 11:11 AM
    WendyTaco
    Kyler
    2017 TRD Off-Road
    Some of the photos I took at Redrock
    vale46, NABeast, Soul Surfer and 7 others like this.
  9. Oct 16, 2016 at 11:31 AM
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    Wish I wasn't so hard on the truck so I cold go. Looks like fun but citrus caused enough damage
    Trident904 likes this.
  10. Oct 16, 2016 at 11:33 AM
    Timbo's Customs
    Timothy
    Lakeland FL
    Did lee make it up or the passenger wheel kick out. Looks tweaked
  11. Oct 16, 2016 at 12:07 PM
    nkeene
    nkeene Well-Known Member
    Nick
    Oviedo
    photo dump incoming
  12. Oct 16, 2016 at 12:20 PM
    nkeene
    Nick
    Oviedo
    haha jk my mac doesn't want to cooperate right now
    Timbo's Customs and WendyTaco like this.
  13. Oct 16, 2016 at 12:26 PM
    Killowatt
    I wanted to go, but by the time I removed my running boards and 3 flaps, I would have surely missed everyone leaving camp. If I hit that one just a little, it would have hit the cab, don't want that if I can avoid it. It was only 1/4 inch from the cab when I got home, with two destroyed brackets, only the rear was holding it on. Looks like a cool spot, hopefully next time. Now a new look after a rinse.
  14. Oct 16, 2016 at 12:30 PM
    WendyTaco
    Kyler
    2017 TRD Off-Road
    Frank had to pull him from behind. Brian tried first and broke the strap.
  15. Oct 16, 2016 at 12:36 PM
    WendyTaco
    Kyler
    2017 TRD Off-Road
    This clay has me digging the bronze and silver look that @NABeast had goin on:rolleyes:IMG_4559.jpg
  16. Oct 16, 2016 at 1:00 PM
    Timbo's Customs
    Timothy
    Lakeland FL
    Do it
  17. Oct 16, 2016 at 1:06 PM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Only ones off my phone lol, gopro stuff coming soon :D
    Red Rock
    Citrus
  18. Oct 16, 2016 at 1:07 PM
    beertimecontinuum
    Everett
  19. Oct 16, 2016 at 1:07 PM
    WendyTaco
    Kyler
    2017 TRD Off-Road
    Rock sliders are cooler than running boards anyway:thumbsup:
    Killowatt[QUOTED] likes this.
  20. Oct 16, 2016 at 1:09 PM
    WendyTaco
    Kyler
    2017 TRD Off-Road
    Thinking I might go with these
