2016 Formula 1 Season Paddock
Discussion in 'Sports, Hobbies & Interests' started by OZ-T, Dec 1, 2015.
  1. Mar 2, 2016 at 3:07 PM
    #381
    wdb
    wdb intolerance intolerant
    Dave
    the perimeter
    plain jane
    Hella 4000 eurobeams, Amp Bed Step, IamMrYo mirror riser, Wet Okoles, HomerTaco satoshi, retrofit intermittent wipers & backup camera
    You did until I scrolled down. :devil:
  2. Mar 2, 2016 at 3:17 PM
    #382
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    DOH!! That's an artifact from the post I quoted. Will fix that right away.
  3. Mar 2, 2016 at 5:33 PM
    #383
    OZ-T
    OZ-T [OP] I hate my neighbour
    Peter North
    British Columbia
  4. Mar 2, 2016 at 5:34 PM
    #384
    OZ-T
    Peter North
    British Columbia
  5. Mar 2, 2016 at 5:35 PM
    #385
    OZ-T
    Peter North
    British Columbia
  6. Mar 2, 2016 at 5:37 PM
    #386
    OZ-T
    Peter North
    British Columbia
  7. Mar 2, 2016 at 6:27 PM
    #387
    OZ-T
    Peter North
    British Columbia
  8. Mar 3, 2016 at 5:21 AM
    #388
    speedydave
    speedydave Well-Known Member
    Dave
    Hickory, Nc
    Mustang GT
  9. Mar 3, 2016 at 6:14 AM
    #389
    smugly
    smugly Well-Known Member
    Doug
    2005/2009/2016 4x4 TRD double cab taco, and now a 2024 Trailhunter
    some and more and more and more and
    I'm with you. what if they had to get out in a hurry? I don't think it would have done any good for Bianchi either. His decelerating G forces alone, were off the charts. On the plus note , It wood definitely help with the fly overs witch seams to happen a lot.
  10. Mar 3, 2016 at 6:20 AM
    #390
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Yeah it's kinda hard not to fly over with that spatula front end scooping you up. As far as the halo I think that I would rather see the closed cockpit. Although if the halo is on a hinge of some sort then getting out would be as easy pulling a pin and pushing your way out.
  11. Mar 3, 2016 at 7:22 AM
    #391
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    But it's cute
  12. Mar 3, 2016 at 7:33 AM
    #392
    daggs81
    daggs81 Well-Known Member
    CT Shoreline
    2017 TRD Sport
  13. Mar 3, 2016 at 7:39 AM
    #393
    Cativelense
    Cativelense Well-Known Member
    Nuno
    CT
    2014 DCSB Black 4x4 TRD Sport
    -TRD oil cap -TRD radiator cap -TRD shift knob -2015 Entune system with Nav, -OEM roof rack -Front windows tinted to match back (20%) -BPK Skid Plate -Non clock hazard switch assembly -WeatherTech floor mats -AFE Stage II Pro Dry Intake -AVS Vent Shades -AMP Research bed extender -Horn relocation mod -Bob's Mirror -Redline hood struts -UltraGauge MX 1.3 -Debadged -Reverse LEDs & shifter bezel LED -Black steering wheel controls, black shifter bezel, black AC vent panel -Black gauge cluster rings + black tweeter rings -Morimoto XB LED fog lights -Anzo tail lights -Hilux 4x4 lighted switch -Bed mat -Hondo Garage radio knobs -OKLED 20" light bar mounted on BAMF behind the grill mount -CH4X4 LED light bar switch w/add-a-fuse -nd4spdbh fog light anytime mod (HUGE thanks to @tgriff) -Debadged bed -Secondary air pump filter -Retros (Morimoto Mini H1's and Morimoto Panamera shrouds with dual intensity LED DRL's & 5000k bulbs) -Tailgate Anti-Theft Device by @scleaf -OEM TRD Sport 17" wheels painted black w/Bridgestone Blizzak DM-V1 tires (Winter wheels) -Pro Comp Extreme 17" wheels w/Firestone Destination LE2 tires (Spring/Summer/Fall wheels) -Anzo blacked out third break light -HomerTaco Tacoma Ghost Raptor Insert -Rear diff breather mod (HUGE thanks to @jc11taco89) -Fumoto Valve -LEER 100R -Salex center console and glove box organizers -Power Pop N Lock -Mobtown Tailgate Skin -TRD Pro suspension with HS Progressive AAL (overload leaf in) -ECGS replacement bearing -Dust caps on rear drums to match front -Me-So Customs "The Gasshole" -ACEkraut license plate bracket -mesojdm's 2nd Gen Ultimate LED Dome and Map lights -Seat spacers from olecoot -Bullaculla Trailer Harness Relocation Bracket
  14. Mar 3, 2016 at 8:14 AM
    #394
    OZ-T
    Peter North
    British Columbia
    The Halo on Raikkonen's car was just a mock up to test visibility issues .
  15. Mar 3, 2016 at 8:15 AM
    #395
    Cativelense
    Nuno
    CT
    AH! Understood. There go my 2 cents out the window.
  16. Mar 3, 2016 at 8:21 AM
    #396
    speedydave
    Dave
    Hickory, Nc
    Mustang GT
    I'm with you. Some kind of a half or 3/4 windshield canopy thing. Not full fighter jet, but open on the top.
  17. Mar 3, 2016 at 8:24 AM
    #397
    OZ-T
    Peter North
    British Columbia
    After Massa's accident the FIA introduced a new set of helmet requirements including the introduction of a " brow " reinforcment above the visor that is designed to withstand the same velocity of impact that Massa suffered in hit accident .
    The Halo is designed to allow driver extraction and aid to a driver trapped in a vehicle while protecting the head from large debris like tires and wings and for other cars climbing on top
    The concerns with a full bubble canopy was with not having access to a driver in an overturned car for example , fire , and to a lesser extent rain and a glare effect
  18. Mar 3, 2016 at 8:26 AM
    #398
    OZ-T
    Peter North
    British Columbia
    It would have to be taller than the driver's head and would likely need a metal or reinforced top edge if it was to provide protection from vertical loads so you would end up with the same look as the Halo but without the front leg no ?
  19. Mar 3, 2016 at 8:32 AM
    #399
    speedydave
    Dave
    Hickory, Nc
    Mustang GT
    I don't think it would need to be reinforced with today's materials and technology.
    I was thinking more like this:[​IMG]
    14489 likes this.
  20. Mar 3, 2016 at 8:37 AM
    #400
    OZ-T
    Peter North
    British Columbia
    In both of those pictures the glass would have to be taller to protect the driver's head from a tire or similar large debris
    And it may be OK without a top edge IDK , I guess it depends on what the test loads are , plus as I was saying previously there was a concern with a glass concept because of rain and glare , especially in the lighted or light to night races
