2016 Motor Failure
Discussion in '3rd Gen. Tacomas (2016-2023)' started by HMR06, Jul 22, 2021.
  1. Jul 23, 2021 at 9:40 AM
    #101
    TacoMTga
    TacoMTga Well-Known Member
    Brian
    I think the gearing and trans behind the 3.5 is what the real cause of the bad rap is from.
    The guys with the 6spd manual rate the engine a lot higher than the slushboxers
    Andale26 and gsubioguy like this.
  2. Jul 23, 2021 at 9:42 AM
    #102
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Engine in my taco was just fine with the stock tune. Lots of power and none of those “TW issues”.
    Tune just makes it so much more fun to drive.
    Mikeybuck, tacotoe and FL_TRD Sport like this.
  3. Jul 23, 2021 at 9:43 AM
    #103
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Cool.
    Lt. Dangle likes this.
  4. Jul 23, 2021 at 9:48 AM
    #104
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    OP, I see you had most all of the oil changes done by the dealer. How often did you check the oil level in between those changes? My thought here is that if you did not check it, it is possible they significantly overfilled or underfilled one or more, which could have caused some bearing damage. This is especially true in the mountains where you are changing the oil level on a grade while under load.
    Rockefelluh likes this.
  5. Jul 23, 2021 at 9:48 AM
    #105
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    opportunity for an upgrade. https://www.cummins.com/engines/repower
  6. Jul 23, 2021 at 9:50 AM
    #106
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I've been on multiple trips through the CO mountains with both 2nd and 1st genners along, all kinds of driving, carrying between 600-800 pounds of gear (maybe depends on how low on beer I am). I probably carry slightly more weight than the others, and they are in Access Cabs with the same size tires as me. I make it over the highway passes with ease and can go a lot further on a tank than any of the 2nd gens I am with. I generally have a quarter to an eighth of a tank more than they do at fillups, same size tank. Really the only difference I can tell between the 2nd and 3rd gen (I used to have a 2012 I would take up there) is that the 3rd gen shifts more and revs higher. Both work fine, and I actually think my 3rd gen makes it over the passes easier. That is my perception, and the actual HP and torque numbers align with that perception as well.
    Anyway, I just hope the OP gets a better answer.
    Grindstone and Junkhead like this.
  7. Jul 23, 2021 at 9:50 AM
    #107
    TRD-ED
    TRD-ED Well-Known Member
    Lenoir NC.
    2020 Army Green TRD PRO - 2023 Genesis GV70
    Stock FOX 275/65/18 At3w 18X9 Fuel Vapor's
    Never said the 3.5 was perfect just asked for facts over opinions. I was in my 4.0 Gen 2 for 8 years. Good solid truck with never any issues. But my Gen 3 has just a much power and more in the upper rpms. But that's the opinion of my butt dyno.
    But a fact sheet seems to collaborate that.
    Grindstone likes this.
  8. Jul 23, 2021 at 9:54 AM
    #108
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    ...and why would you bring this argument into a dick measuring contest?
  9. Jul 23, 2021 at 9:55 AM
    #109
    Toyko Joe
    Toyko Joe Here for the pictures
    :argue::annoyed: @MTgirl can we get a cleaning of this thread so we have more information about engine failure and not two people bickering about which engine is better? :angrygirl:
  10. Jul 23, 2021 at 9:56 AM
    #110
    Woodrow F Call
    Woodrow F Call Kindling crackles and the smoke curls up...
    Colorful Colorado
    16 DCSB SR5 4X4 "ikea furniture haulers" edition.
    It's probably the engine and will need replacing.
    I'd like to have checked the oil before you took it to the dealer. If someone screwed up the last oil change and oil leaked out over time because the oil filter housing was not installed correctly or the drain plug came out..... that would cause this.
  11. Jul 23, 2021 at 9:59 AM
    #111
    Woodrow F Call
    Colorful Colorado
    Oh, please keep us posted. I'm curious on the replacement cost.
  12. Jul 23, 2021 at 10:00 AM
    #112
    fourfourone
    fourfourone Well-Known Member
    2015 TRD sport(sold) 2023 Tacoma
    You asked me if my 2nd gen stays in 6th.... so I answered you.
    davidstacoma likes this.
  13. Jul 23, 2021 at 10:02 AM
    #113
    fourfourone
    That's great it makes better power higher up...Trucks need power down low. Its not a civic si
  14. Jul 23, 2021 at 10:06 AM
    #114
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Some Serious Tires
    Careful, don’t twist that frame with your torque monster 4.0;)
  15. Jul 23, 2021 at 10:07 AM
    #115
    jaxyaks
    jaxyaks Well-Known Member
    2020 Silver Tacoma TRD Off Road
    Nope...thats called trading it as is....Dealerships don't care what half the condition of the car they are taking in is, they just run it down the auction block. As long as it starts and the AC turns on they could care less.
  16. Jul 23, 2021 at 10:08 AM
    #116
    LarryDangerfield
    LarryDangerfield One Larry a day keeps the money away ™ Moderator
    Tyler
    Northern Wisconsin
    Black 2020 Nightshade Edition 4Runner
    Oh there will be some mods all right
  17. Jul 23, 2021 at 10:11 AM
    #117
    Vlady
    Issy, WA
    Before bringing "wont stay in 6th gear " argument, 1st -count gears, then look at the gears ratio for 2nd vs 3rd.
    Lt. Dangle and Junkhead like this.
  18. Jul 23, 2021 at 10:14 AM
    #118
    jaxyaks
    So does the Ridgeline....
  19. Jul 23, 2021 at 10:15 AM
    #119
    jaxyaks
    Its not designed to run in 6 gear on the highway with a load in it....There is a reason you tow haul with the overdrive gears locked out
    gsubioguy and Grindstone like this.
  20. Jul 23, 2021 at 10:17 AM
    #120
    jaxyaks
    And if you put the 3rd gen in S mode and lock out 6th gear...it will stay in 5th just fine with not problem as well...
    Lt. Dangle, gsubioguy and Grindstone like this.
