2016 noise update
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Strech, Dec 9, 2015.
  1. Dec 18, 2015 at 4:14 AM
    Oldbugr
    Oldbugr Active Member
    2019 DCSB TRD Offroad
    Yes, please post the service bulletin numbers, my hood has the problem as well.
    Suxdsmdmr likes this.
  2. Dec 18, 2015 at 5:54 AM
    3dBdown
    3dBdown Well-Known Member
    2016 DCLB BBP 4x4 Sport
    Let us know if it stays that way. I never felt like mine had anything but aero linked to it regardless that it happened at the exact speeds and sound that the "driveline harmonics" happens. In fact, with a ~15mph headwind it happened at 15mph less. Looking forward to an actual service bulletin # or anything.
  3. Dec 18, 2015 at 8:59 AM
    joew
    joew Member
    joe
    2016 trd sport loaded pricing
    What's the problem you are having ih the hood?
  4. Dec 18, 2015 at 9:15 AM
    joew
    joew Member
    joe
    I must of missed something, what is the problem people are having with trd sport hood scoops?
  5. Dec 18, 2015 at 9:24 AM
    3dBdown
    Assuming he went in for the adhesive separation issue, and they adjusted the door while he was there. The two are unrelated.
  6. Dec 18, 2015 at 10:08 AM
    txags92
    txags92 Well-Known Member
    2016 DCLB TRD OR 4x4 BBP
    Sounds like you and the OP are describing different problems then, since his was happening while sitting still. Can't be driveline noise if the truck isn't moving.
  7. Dec 18, 2015 at 10:14 AM
    pop639
    pop639 Well-Known Member
    Western PA
    16 SR5 DCSB 4x4
    I just turn on my recirc and the rear vents will close...it gets more quiet
  8. Dec 18, 2015 at 10:17 AM
    tacotacoandburrito
    tacotacoandburrito Member
    Dave
    SBOR no noise issues so far, 600+ miles, half highway half country roads.
  9. Dec 18, 2015 at 2:18 PM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    Already talked to you Bob. Mine's still quiet and problem free.
    G.
  10. Dec 18, 2015 at 3:49 PM
    Oldbugr
    Sorry, I was referring to the hood skin separating from the cross members, lots of talk about it.
  11. Dec 28, 2015 at 10:33 PM
    jeff_taco_4x4
    jeff_taco_4x4 Well-Known Member
    jeff
    16' 4x4 Sport DCSB w JBL, MGM
    I have had no noise issue
  12. Dec 29, 2015 at 3:40 AM
    kerrdog
    kerrdog Well-Known Member
    2016 trdor mgm
    I have a TRDOR with 3500 miles on it. I havent had the wind noise problem until yesterday. I was driving into a 25 to 30 mph headwind for approx.a 3 mile stretch and it made the howling sound 2 times. Each time it howled sounded like blowing in a coke bottle. Each howl lasted about a second.
    iancaz likes this.
  13. Dec 29, 2015 at 5:00 AM
    Garyji
    Gary
    Well John, it sounds like that cannot be "driveline harmonics". Mine's quiet too, but I don't think I've been in 30 mph crosswinds.
    You reading this, Bob?
    G.
  14. Dec 31, 2015 at 8:03 AM
    fmac112
    fmac112 Active Member
    2016 Tacoma TRD Off Road
    I have a 2016 TRDOR and I experience two negative sound issues. I get the kazoo sounding whistle INSIDE the cab at high speed or during wind. Sounds like it's coming from driver side windshield or left most air vent. I also hear the Coke bottle whistle from the outside sporadically, but this seems to be outside the cab. I plan to visit the dealership to have the first issue fixed. Anyone know the service number from Toyota?
    tacogeorge and iancaz like this.
  15. Dec 31, 2015 at 8:41 AM
    #35
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    I'm pursuing seals and molding as the source of my WIND noise. The upper seal on the rear window is horrible.
  16. Dec 31, 2015 at 11:27 AM
    #36
    Futral
    Futral Member
    Dan
    Pocatello, Idaho
    2014 double cab Tacoma
    K&N, flow master 40 series, 265 MT tires, 28" led lightbar
    Not sure if anyone has said this yet but this is a known problem by Toyota. They recommend adjusting the doors to their spec (dealership has that) and if that doesn't work, they are working an a firmer seal. Mine does the same thing. Sounds like a kazoo when I get a crosswind. My dealership said it will likely turn into a recall that will cover everyone but they haven't found a fix for sure yet.
  17. Dec 31, 2015 at 11:29 AM
    #37
    splitbolt
    NW Arkansas
    Just got back from the dealer; new passenger upper window seals on the way. :fingerscrossed:
  18. Dec 31, 2015 at 11:32 AM
    #38
    Futral
    Futral Member
    Dan
    Pocatello, Idaho
    Is your consistent or is it a sometimes thing? I can't ever get mine to replicate the issue since it seems to only do it when I have a crosswind. Since the dealership can't replicate it, they can only do what Toyota is authorizing them to do and that was the door adjustment
  19. Dec 31, 2015 at 11:55 AM
    #39
    splitbolt
    NW Arkansas
    It's a sometimes thing.
    Changes with; speed, moisture, and temperature.
    In calm wind and dry conditions it comes on around 35-40mph.
    Cold and moisture make it 'louder'.
    Headwinds and crosswinds will make the speed vary; I've noticed it as low as 15 mph.
    Most of the time it's the coke bottle howl.
    If I get up above 70 with crosswind, I get high pitched whistles.
    I swear I once heard it sitting in the driveway during heavy winds.
    iancaz likes this.
  20. Dec 31, 2015 at 10:27 PM
    #40
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
