2016 out, 2023 Pro in - INCOMING!!
Discussion in '3rd Gen. Builds (2016-2023)' started by Broheim, Jun 10, 2017.
  1. Aug 26, 2017 at 10:10 AM
    Broheim
    Broheim [OP] Well-Known Member
    San Antonio, TX
    2023 TRD Pro
    Measured from middle of hub to fender.
    And measured on the shaft from bottom thread to top thread.
    You may be a little high at first if they are brand new but they'll sag about .75 to 1"
  2. Aug 26, 2017 at 10:17 AM
    FStewart17
    FStewart17 Well-Known Member
    Atlanta, GA
    2017 DCLB TRD Sport
    Sorry I was referring to your coilovers.
  3. Aug 26, 2017 at 10:26 AM
    Broheim
    San Antonio, TX
    2023 TRD Pro
    ^ that's exactly right.
    FStewart17 likes this.
  4. Aug 26, 2017 at 6:39 PM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Thats some epic preload.
    Blacklodge, LostHusker and TXpro4X4 like this.
  5. Aug 28, 2017 at 8:13 AM
    FStewart17
    Atlanta, GA
    2017 DCLB TRD Sport
    @Broheim did you install the ECGS bushing as well?
  6. Aug 28, 2017 at 5:52 PM
    Broheim
    San Antonio, TX
    2023 TRD Pro
    No. No EMG bushing. So far so good.
    LostHusker likes this.
  7. Aug 28, 2017 at 6:21 PM
    Broheim
    San Antonio, TX
    2023 TRD Pro
    It ain't for babies.
    Blacklodge, LostHusker and FStewart17 like this.
  8. Aug 28, 2017 at 6:23 PM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    As long as it don't shear off your top hat or deform your coil buckets you should be alright.
  9. Aug 28, 2017 at 7:27 PM
    FStewart17
    Atlanta, GA
    2017 DCLB TRD Sport
    Spoke with Fox today. Said I should be good.
  10. Aug 29, 2017 at 4:44 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Sounds good, I know with Icon and king that they advertise that there are limitations to how much length of exposed thread is considered "safe" to run. I have a few buddies who push this threshold and wouldn't surprise me if things break for them in time. Good on you for confirming you wont be one of those guys as no one wants that.
    FStewart17[QUOTED] likes this.
  11. Nov 4, 2017 at 11:44 PM
    stevehipp
    stevehipp Member
    steve
    2012 Toyota Tacoma
    TRD Sport 4x4
    So you've got your C/Os jacked up all three inches and still get a good ride (on and off-road)? I want to get the same set up but everyone says they'll ride terribly if set all the way to three, so I was considering getting a 1 inch body lift with the C/Os set to two inches, but this is a lot of extra money, especially regarding install.
  12. Nov 5, 2017 at 1:00 AM
    Broheim
    San Antonio, TX
    2023 TRD Pro
    My ride is like a bit stiffer than the oem off road factory suspension. Very streetable and light Off road friendly. I haven't pushed it too much further but definitely satisfied so far.
  13. Nov 5, 2017 at 5:00 PM
    stevehipp
    stevehipp Member
    steve
    2012 Toyota Tacoma
    TRD Sport 4x4
    Hmm, good to know. I was stressing about this because the body lift itself is a lot of extra money. Will probably just go with these coilovers set to 3 and just see how it rides. I'm not going to be going offroading a ton either but I want something that will be able to perform decent too so I think this should be fine. Gotta do a CMC tho :/
    Coot83 likes this.
  14. Jan 12, 2018 at 11:23 AM
    Photocycler
    Photocycler Well-Known Member
    Pacific Northwest
    2017 Tacoma TRD OR DHSB MGM
    Nice build. Any pics of the rear? Are you mounting the rear resi to the shock body or on the frame? Also, any idea how much lift the rear AAL got you?
  15. Jan 12, 2018 at 11:34 AM
    #35
    Broheim
    San Antonio, TX
    2023 TRD Pro
    The res is mounted to the shock body by the bracket fox provides. Clean.
    I'm not sure how high it is but it's gotta be a full 2" or a bit more. Hasn't sagged at all since..very tight feel in the rear while on the road. Not overly stiff but just right. Impressed.
  16. Jan 19, 2018 at 6:14 AM
    #36
    TRDSPORT1990
    TRDSPORT1990 Well-Known Member
    Adam
    Connecticut
    16' TRD Sport DCSB
    Fox 2.5 Coilovers Fox 2.0 Rear Shocks Allpro AALs Allpro UCAs SCS sr8s 285/70/17 BF Goodrich ko2s
    @Broheim what lug nuts you running? they are sharp
  17. Jan 19, 2018 at 3:05 PM
    #37
    Broheim
    San Antonio, TX
    2023 TRD Pro
    They are Muteki lug nuts. SR48's I believe.
    They only come in packs of 20 so you'll need to buy the 4 pack of matching locks as well. They have all colors but I thought the neo-chrome was hot.
  18. Jan 19, 2018 at 4:28 PM
    #38
    TRDSPORT1990
    Adam
    Connecticut
    16' TRD Sport DCSB
    Thank you!! Love your ride as well. I’m running the same fox 2.5s love them myself!
  19. Jan 19, 2018 at 5:57 PM
    #39
    Broheim
    San Antonio, TX
    2023 TRD Pro
    :Thumbsup:
  20. Feb 14, 2018 at 9:32 PM
    #40
    mhshark
    mhshark Well-Known Member
    Bend, Or
    Hey man any sagging or complaints with this setup? I’m looking at pretty much the same setup.
    Also did 2.9” of threads settle to 2.5-2.75”? I’m looking to get around 2.75” after settling. Did you adjust to a lower setting then after settling crank up further?
