2016 rack and pinion pop/ creaking
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Weirich, Oct 2, 2017.
  1. Oct 2, 2017 at 9:23 PM
    Ruggybuggy
    Ruggybuggy Well-Known Member
    NW ONT, CANADA
    2020 Tundra SX
    Hold the bolt head on the top with a wrench. I believe the bolt passes through the frame with the nut on the bottom.
  2. Oct 2, 2017 at 9:30 PM
    Weirich
    Weirich [OP] Drunk_taco
    Travis
    2016 Tacoma access cab TRD Offroad
    OvTuned 4.88 R&P Hypertech speedometer calibrator Rough country 6" lift Toyo open country 285/75R17(old) Cooper STT Pro 315/70r17 Archive garage shackle flip Tough country uni ball uppers Icon 2.5 6" front coil overs Icon 2.5 CDC 6" rear shocks OME cs047r rear leaf packs AllPro HD Sliders Tom woods double cardin single piece drive shaft Magnaflow exhaust Black rock D window rims(old) ICON 17x8.5 Rebound CBI T3 full guard front bumper Smittybilt x20 10k winch HEISS 20" single row light bar ARB on board air compressor
    Noted. Due to some troubleshooting we did I don't think it's that but worth a look
    Diablo169[QUOTED] likes this.
  3. Oct 2, 2017 at 9:31 PM
    Weirich
    Travis
    I took the nut off but the bolt gets caught on the compressor before it will come out
  4. Oct 3, 2017 at 3:44 AM
    Ruggybuggy
    NW ONT, CANADA
    2020 Tundra SX
    You could push the bolt up and cut off the head and then push it out the bottom. When reinstalling put the bolt in the opposite way with the nut on top.
  5. Oct 3, 2017 at 5:25 AM
    Weirich
    Travis
    Good idea but not eniugh room on the bottom either
  6. Oct 3, 2017 at 5:30 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This happens on the second gen racks as well. The solution is to cut off 1/2"-3/4" of the bottom of the bolt so there is juuuuust enough room to get it out.
  7. Oct 3, 2017 at 9:50 AM
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    I would've sprayed some WD-40 in that area around the bolts and bushings to make sure you're clicking and popping is coming from that rack. It's going to be a bummer if you do all that work and it didn't fix the noise.
  8. Oct 3, 2017 at 10:47 AM
    Weirich
    Travis
    i'm thinking i'm just going to pull the compressor out and get the bolt out that way.
  9. Oct 3, 2017 at 10:49 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That works too. When you put it back in, I'd reinstall it upside down with a little loctite for peace of mind. I had my frame replaced by Toyota, and my bolt was upside down. Made my life so much easier when doing my R&P swap.
  10. Oct 3, 2017 at 10:50 AM
    Weirich
    Travis
    well we loosened the bolt and turned the wheel back and forth and it didn't make any noise, so we sprayed some white lithium around the head of the bolt and the bushing. It helped with the popping a little bit. just going to take the compressor bolts out and move it out of the way of the rack bolt, then try and get the bushing out and put the new one in.
    Hiluxski[QUOTED] likes this.
  11. Oct 3, 2017 at 10:51 AM
    Weirich
    Travis
    The subframe drop bracket from my lift it in the way on the bottom so I really have no choice.
  12. Oct 3, 2017 at 10:52 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Whomp whomp. Good luck with the bushing swap. Replacing my rack and pinion was the biggest bitch I've had to deal with so far.
  13. Oct 3, 2017 at 11:25 AM
    Weirich
    Travis
    it cant be as bad as putting in the lift.
  14. Oct 3, 2017 at 11:26 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Can't say for sure because I've never installed a drop bracket lift. Your r&p should be smoother since you're a 2016, and not a rusty 2005.
  15. Oct 3, 2017 at 11:30 AM
    #35
    Weirich
    Travis
    I just don't want to pull any lines off of it. I've never really had any luck bleeding power steering.
  16. Oct 3, 2017 at 11:32 AM
    #36
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You'll 100% need to pull the lines off. Have you looked at any threads yet for replacing the bushings? People need air hammers and pickle forks to get the old ones out.
    When I was refilling my power steering, all I did was add fluid, fire up the truck, turn off the truck, and repeat. Once it was more full then I started turning the wheel back and forth to work the system. I haven't had any issues.
    Weirich[QUOTED][OP] likes this.
  17. Oct 3, 2017 at 11:32 AM
    #37
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    Is this easy to replace? I never had Taco lean but as of late I'm beginning to notice it on my 2011
  18. Oct 3, 2017 at 2:45 PM
    #38
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
  19. Oct 3, 2017 at 3:39 PM
    #39
    TireFire
    Olympic Peninsula
  20. Oct 6, 2017 at 8:25 PM
    #40
    Weirich
    Travis
    i haven't looked anything up so far, I guess it wouldn't be to hard to pull it and service the power steering. I need to replace a axle boot anyways so ill just do it all in one shot. With some help with a 30 rack of course!
