2016 shell pics?
Discussion in 'Tonneau Covers, Caps and Shells' started by Tocame, Nov 3, 2015.
  1. Aug 24, 2016 at 6:51 AM
    #801
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    :cheers:
  2. Aug 24, 2016 at 7:23 AM
    #802
    DoktorStrangelove
    DoktorStrangelove Active Member
    2016 TRD Off-Road
    Also, YMMV, but in my area people are ALWAYS dumping rack parts and full kits on Craigslist in excellent to like-new condition for cheap. I'm like you and just ordered tracks on my Leer, and when it comes in I'm going to start combing CL for a deal. If you don't absolutely NEED the rack right away, I'd recommend you do the same. You'll probably find everything you need really quick...the only possible exception being the landing pads, you may have to wait a bit longer to find someone selling the exact config you need.
    Go to a Yakima or Thule dealer or get on their websites and configure your setup so you know the exact part numbers you need for everything, then you'll be good to go shop the secondary market.
    Marbleyard[QUOTED] likes this.
  3. Aug 25, 2016 at 11:54 AM
    #803
    Maineiak07
    Maineiak07 Well-Known Member
    Nick
    Pomfret, CT
    2016 Inferno Tacoma SR5 DC LB 4x4
    Clazzio Seat Covers, Interior/License Plate LEDs, Bugflector II, Predator Steps, AVS In-channel Vent Shades, removed stock front air dam, blacked out emblems and grill, Leer 100XR, Bilstein 5100s front and rear, OME 887 coils, Icon AAL (w/overload)
    Had my Leer 100XR installed yesterday. Flip down front slider, gray headliner, and tracks (only). I haven't decided on Thule or Yakima for the feet, towers and crossbars yet. image.jpgimage.jpg
    George1441, Dogg23 and Marbleyard like this.
  4. Aug 25, 2016 at 12:00 PM
    #804
    easye515
    easye515 Well-Known Member
    2016 Tacoma TRD Offroad 6 speed manual.
    I got my rack setup from ARE years go. but when I got my new tacoma I did the same thing with the z series. Just had them install the track, and then I re-installed my rack system. I did however need to get the over the cab setup for a canoe. I just went in to REI and checked their fit guide. You need the tower, landing pad (I got the gutter mount kind) and don't forget the round bar adapter if you are going that route. As mentioned, it wouldn't hurt to check craigslist. this stuff is expensive for what it is. but it does last a lifetime.
  5. Aug 25, 2016 at 1:08 PM
    #805
    hukster75
    hukster75 Member
    2017 Tacoma TRD
    Hi all,
    I am also planning on getting a leer 100xr but have a question in general regarding the ventilation in the camper shell. I was wondering what are most of you guys/gals are doing about ventilation for pets that are in the back camper shell?. Is the AC from the cabin good enough to keep the shell cool for your pets if both the rear window and camper shell front window is open?.
    Thank you for your time.
  6. Aug 25, 2016 at 2:33 PM
    #806
    easye515
    I've never had a sliding glass window on a topper before now. But I would find it hard to believe it would be enough to cool down the bed of the truck. seems like it would get wasted in between the two. I always just cracked the sliding windows and my furry ass golden retriever never seemed to mind. Would always bring a water bowl for when we might stop at a rest stop or something we would give him some water.
  7. Aug 25, 2016 at 3:42 PM
    #807
    0210
    0210 Well-Known Member
    Vancouver, BC
    2016 TRD Sport Upgrade DCLB
    Not in a million years.
    Crank up your AC to the max, and as soon as you open the rear window, you'll lose 95% of the AC's efficiency. Absolutely no cool air will reach the interior of the canopy.
    I strongly considered having my dog ride in the truck bed, under my own Leer 100XR. In addition to the open front slider and slid-open windoors, I planned on installing several 12V fans that would be mounted directly on the dog's kennel.
    Factors to consider:
    - even with the fans, that still won't be enough to maintain a reasonably cool temperature inside the canopy on hot summer days
    - opposite problem in the winter - no way to keep the bed warm
    - tons of dust gets in through the tailgate any time you're off-road
    - no way to hear/see the dog in case anything is wrong (motion sickness & throwing up / random pain / needs a washroom break)
    - tailgate is quite high to jump on / off (bad for the dog's joints) and it's not all that much fun lifting/lowering a large dog
    - the bed is a dangerous place to be in case of an accident; it is not made to "survive" an impact as the cabin is
    In the end, my dog rides in the cab and I put up with the bi-weekly vacuuming/cleaning.
    // edit
    Methods of transporting a dog, rated from safest to most dangerous (in my opinion):
    - gunner kennel, secured with tie downs in the rear of the cab
    - other quality kennel, secured with tie downs in the rear of the cab
    - proper dog harness secured to seat belt in the rear of the cab (make sure harness is rated/tested for dogs of similar size)
    - gunner kennel in the bed, secured with tie downs
    - dog loose in the rear seats
    - other quality kennel in the bed
    - dog loose in the front seat
    - dog loose in the bed
    Dr Dirt likes this.
  8. Aug 25, 2016 at 4:05 PM
    #808
    DRJ1014
    DRJ1014 Well-Known Member
    CA
    Make one of these and plug it in to the bed and strap it down
    For those that dont know, its red neck AC. There is Ice in the bottom of the bucket.
  9. Aug 25, 2016 at 4:50 PM
    #809
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    What did you pay?
    Thanks,
    SB
  10. Aug 25, 2016 at 6:12 PM
    #810
    Dogg23
    Dogg23 I like big tires
    Nate
    Rochester, NY
    16 DC OR MT 10 Sport MT & 16 4R Trail
    Big tires
    I have 3 dogs and that's the main reason I have a cap on my truck. Get the removable front window it helps a lot with ventilation on hot days. With just the front slider there is still plenty of fresh air entering the cap with rear widows open. I'm on my second leer XQ and the rear windows only open at the bottom and back of the window and still do just fine. Someone on here also sugested to put a inner tube between the the two sliders to help AC or heat to enter the back. I've used foam to do the same but will be finding a inner tube to use instead. It helps but if it's really hot I try to leave the dogs home. When it's really cold only the non husky rides in front sometimes.
    OTD $2400 w/ removable front window, carpeted and Thule tracks.
    Jessrin, ccallen, sethhawaii and 4 others like this.
  11. Aug 26, 2016 at 8:18 AM
    #811
    Marbleyard
    Marbleyard Thread killer
    Virginia
    2019 4Runner Pro
    SOLD 2016 taco: premium technology and tow package. OV Tune 1.05; A.R.E. V Camper Shell; BRO grille & Tails; OEM bed mat; Xenon Depot HID headlight conversion; reflective gray tailgate letter inserts; GoPro session; Hondo radio knobs; K&N cold air intake, quicksand painted dash bezels, Subaru dash speakers, Kicker CS 6x9 fronts and 6.5 rear speakers; All LED interior lights and LED high-beam headlights. Redline elite hood shock props. prinsu cab and camper rack with rough country 30" light bar; (2) 8" rear facing “F.U.”rough country black LED lights; prinsu cargo basket kit, (2) prinsu load racks; roadshower 4; ARB 2500 awning and room kit; weather tech floor mats; carhart seat covers; ckma12 ARB air compressor under the hood; blue ridge overland gear air tools bag, tool bag, driver's seat molle. Rack mounted TRED 800 recovery treds and plano case. Rotopax water and fuelpax fuel canisters; Pelican cased first aid kit in bed. rockblokz mud flaps. ARB rear dif. breather. Stand alone fuse block. SSO bumper with 10k smittybilt synthetic line winch and factor55 ultrahook. Pro Eagle 2-Ton “The Beast” jack. OME lift kit: 90000 front shocks and 886 OME coils, Camburg 310078 UCA, 60091 rear shocks with light duty Dakar leafs. Good Year duratracs 285/75R16. Black vinyl inlays on factory OR wheels; RCI Steel Front/Trans/Trans Case/Rear Diff Skids, Alum A-Arm; Mobtown bolt-on sliders with scorpion bed coating; pelfreybilt aluminum fuel tank skid; Cali-Raised full length Molle storage LH & RH bed sides; Caliraised bedside reinforcements; HELLA sharptone horns; Optima blue-top battery with AJT machined red tiedown bracket. AJT quicksand key fob. Overland Bound member #6996
    Got confirmation my shell will be in Wednesday :bananadance::dancingbacon::broccoli:. I asked my guy if there was anything I need to know about mounting it other than the obvious, because I am doing it myself with some coworkers, and he said some trucks come with a wire at the end of the frame rail put there just for wiring in a camper shell 3rd brake light. For those of you with your cap already, can you tell or know where your 3rd brake is wired into? I don't mind tapping into my left rear brake but I really like the idea of an existing wire possibly being there. I will look myself later but thought I'd ask then report :thumbsup:
  12. Aug 26, 2016 at 11:32 AM
    #812
    Marbleyard
    Virginia
    2019 4Runner Pro
    :tumbleweed: ...what happens when I enter a thread :bananadead:. All good, I'll check and report this weekend
  13. Aug 26, 2016 at 11:36 AM
    #813
    Farcedude
    Farcedude Well-Known Member
    Greg
    Westminster, CO
    ‘23 MGM DCSB OR
    As soon as I get mine, I'll let you know!
  14. Aug 26, 2016 at 12:03 PM
    #814
    xola3que
    xola3que Well-Known Member
    Long Valley, NJ
    2019 Tacoma Sport
    Any feedbacks on Jeraco shell? A local guy is selling one in my size my color, not sure if it's quality.
  15. Aug 26, 2016 at 12:42 PM
    #815
    Oiefisherman
    Oiefisherman Well-Known Member
    2014 Ram 3500
    Why does it need pipes out the side? Couldn't you just hole saw some holes in the side of the bucket?
  16. Aug 26, 2016 at 12:46 PM
    #816
    Marbleyard
    Virginia
    2019 4Runner Pro
    focus direction. think of it like blowing through a straw compared to just opening your mouth and trying to blow, make any sense?
    catseye and DRJ1014 like this.
  17. Aug 26, 2016 at 2:34 PM
    #817
    DRJ1014
    CA
    Mine looks to be tapped into the left rear brake light. Wires run directly to this location.
  18. Aug 26, 2016 at 9:23 PM
    #818
    Maineiak07
    Nick
    Pomfret, CT
    I have an SR5 (don't think it matters which trim level, though) and they tapped into the left rear light. The Leer dealer installed a wire disconnect (standard) between the tapped wires and the fuse box (mounted inside shell) to make removal super easy.
  19. Aug 27, 2016 at 6:10 AM
    #819
    Lucuss
    Lucuss New Member
    Anyone has pictures of a Leer 100 XR on a TRD Off Road access cab magnetic grey color please?
    baileybrandon likes this.
  20. Aug 29, 2016 at 9:15 PM
    #820
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I think it's more like bedliner than plastidip. Anyone with it on their shell who can tell us?
