2016 shell pics?
Discussion in 'Tonneau Covers, Caps and Shells' started by Tocame, Nov 3, 2015.
  1. Dec 26, 2016 at 7:46 PM
    #1141
    NY Taco
    NY Taco Well-Known Member
    Rochester, New York
    2017 Inferno Sport DCLB
    Leer 180 Cap, Beat Sonic Navi By-Pass
    It's useless, get good lighting in your cap.
    Marbleyard and 0210 like this.
  2. Dec 26, 2016 at 9:46 PM
    #1142
    fredgoodsell
    fredgoodsell Well-Known Member
    Salt Lake, UT
    2017 DC TRD OR
    I figured...oh well
  3. Dec 26, 2016 at 10:18 PM
    #1143
    TRDJEREMY
    TRDJEREMY Active Member
    Birmingham, AL
    2016 TRD OFF-ROAD
    With my Cx series it shines through just enough to see at the very front of the bed. Definitely need dedicated shell lighting.
  4. Dec 27, 2016 at 3:31 PM
    #1144
    aaen
    aaen Well-Known Member
    Northern Alberta
    2016 DCLB 4x4 TRD Sport BBP
    Kings, ARB Summit Bumper, SMittybilt Winch, vagabond Drifter, Prinsu Cabrac, Crusinoffroad slidersand rear bumper
    I think the LED one in my overland canopy works great. I'm not looking to light up the world, just enough to see where my gear is.
  5. Dec 27, 2016 at 3:51 PM
    #1145
    NY Taco
    Rochester, New York
    He was asking about the cargo light on the rear of the cab, not the one in the canopy.
  6. Dec 27, 2016 at 4:04 PM
    #1146
    fredgoodsell
    Salt Lake, UT
    2017 DC TRD OR
    Yeah this. I've only had my truck a couple days now, and have been pleased at how well the cab light works. Sounds like it's separate interior lighting for the future shell though.
  7. Dec 27, 2016 at 4:07 PM
    #1147
    NY Taco
    Rochester, New York
    My cap came with a decent light in it, but it is right above the door, so I'm thinking I might cast some bad shadows climbing in to grab things out of the back. I am planning on adding some type of rope lights along each side to fully light it up.
  8. Dec 28, 2016 at 11:49 AM
    #1148
    aaen
    Northern Alberta
    Gotcha, misread what he was asking for.
  9. Dec 28, 2016 at 11:59 AM
    #1149
    aaen
    Northern Alberta
    This was my concern as well, and why I was looking for an aftermarket solution to the lighting in the shell. When I thought about it and saw how much light the interior light produced, I do not think, I will need anything more as I won't be crawling in and out of the cap to get my gear/etc, I barely fit in the shell as it is, kidding, but I won't be up in there crawling around. I plan on installing a drawer/slide system into the bed of the truck for my diving gear and camping gear, and to carry everything else I have jammed into the cab. I'm that guy on a job site when you need some rare tool, I have it. I learned a long time ago to be prepared thanks to a good solid up bringing by the old man, although, I may have taken it a little to far though.
    Anyways with regards to the LED strips, you should easily be able to wire this directly into the dome light on the canopy. You can buy the LED strip lighting at most hardware stores for relatively cheap, cut to the size required, and wire it in. The ones we had here ran off of 12v, so it was basically just connect it to witch in the overhead light and voila, or as others suggested to me get the ones with a USB connector and connect it to battery bank. Velcro in place and you have another switched source for lighting. I'd look at the luminoodles (Amazon), slightly more expensive, but are so much more robust, then the standard LED strips.
  10. Dec 28, 2016 at 8:43 PM
    #1150
    Thunder Road
    Thunder Road one hand waving free
    16 DCSB TRD/OR
    Can the badging on the rear windows of an ARE be removed?
  11. Dec 28, 2016 at 9:47 PM
    #1151
    USDashCamera
    USDashCamera Put it in H
    2017 Quicksand TRD OR
    yes, its just some regular vinyl, mine came off super easy. there was a bit of residue but it came off with some glass cleaner.
  12. Dec 28, 2016 at 10:38 PM
    #1152
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz, CA
    99’ Bro-Coma’s Revenge 3RZ 345k+
    Stock
    Is anybody seeing an increase in mpg's. My local dealer said cab highs give 8% better fuel economy, and tonnoeau covers give 5%?
    I'm really liking the Leer XR's.
  13. Dec 28, 2016 at 11:18 PM
    #1153
    DesMed
    DesMed New Member
    2016 Tacoma Off-Road
  14. Dec 28, 2016 at 11:33 PM
    #1154
    phatso
    phatso Well-Known Member
    Eastern Washington
    2017 Cement Pro
    Leer 100R, pet screen was a must and headliner was free. I regretted not getting the Thule rack on my last cap...so far so good, no problems whatsoeverIMG_3354.jpg
    Dawnpatrol, Jessrin, TBV and 3 others like this.
  15. Dec 29, 2016 at 6:15 AM
    #1155
    aaen
    Northern Alberta
    Personally, I do not believe any of the dealers with regards to this. The increased weight of the cab on the truck would neglect any potential gains in aerodynamic efficiency, of which I believe there is zero if you look at how the air flows over and around a pickup, same with Tonneau covers as the air actually flows over the back of the pickup. Although they like to claim there is a fuel efficiency boost, I have yet to find any actual scientific proof, not sponsored by the canopy manufactures of this being the case. More then likely it will hurt your fuel efficiency around town and be negligible on the hwys.
    AdventureKid and bigmw like this.
  16. Dec 29, 2016 at 7:09 AM
    #1156
    Thunder Road
    16 DCSB TRD/OR
    I heard it said that Toyota was required to deliver X percentage of Tacomas w/ OEM tonneau covers in order to realize a certain fuel efficiency standard for the model.
    srdoublecab2.7 likes this.
  17. Dec 29, 2016 at 7:23 AM
    #1157
    aaen
    Northern Alberta
    Interesting, I'd like to see more information on that. I've only found that in comments in articles regarding fuel economy, never anything solid. That being said, if it is true, I would like to see the test results they have on it.
    Regardless, having a tonneau/canopy is almost necessary when using a truck.
  18. Dec 29, 2016 at 10:40 AM
    #1158
    djadonis206
    djadonis206 Well-Known Member
    2016 Black Tacoma SR5
    Cool thread, awesome forum. I just put this shell on last weekend. Sorry the pics aren't so great. Took them on a cold morning in Skagit County, plus I've been snowboarding a lot so my truck's super dirty.
    Jessrin, Dawnpatrol, bigmw and 2 others like this.
  19. Dec 29, 2016 at 11:16 AM
    #1159
    srdoublecab2.7
    srdoublecab2.7 SRlifted&gifted
    Austin, Tx
    2017 DC SR 2.7 MGM
    Stock for a minute
    Getting my are v series put on right now
  20. Dec 29, 2016 at 12:14 PM
    #1160
    jhunter80
    jhunter80 Well-Known Member
    Southern California
    2017 TRD Off-Road Pre-runner
    A.R.E. Z Series Shell Clazzio Leather Seats Bilstein 6112 (2nd Notch/0.75" lift) Bilstein 5100 (Rear) SCS F5 Wheels (16x8/4.5 Backspacing) Goodyear Duratrac 265/75R16 (C Load Range)
    Great customer service and experience with SoCal Truck Accessories in Santee, CA. They ordered and installed my new A.R.E. Z Series shell yesterday and I love it! If you are in the San Diego area and looking for a shell, I would highly recommend both the A.R.E. Z Series and install/service from SoCal Truck Accessories. Here are a couple of pictures. The paint match is PERFECT and even came with a small bottle of touch-up paint for minor scratches.
    Jere, surfingflo, bigmw and 2 others like this.
