2016 shell pics?
Discussion in 'Tonneau Covers, Caps and Shells' started by Tocame, Nov 3, 2015.
  1. Feb 9, 2016 at 11:54 AM
    #161
    SlickDuck
    SlickDuck Well-Known Member
    Greg
    Southern WV
    09 DC MGM TRD Offroad
    My brother got his HD series a couple of weeks ago, ARE rep said it was the first one they have completed. It is rated to hold 500 lbs., but the internal frame looked beefy enough to hold much more. The shell had been molded for some time, but the internal tool boxes delayed delivery by several weeks.
  2. Feb 9, 2016 at 12:13 PM
    #162
    Livinserene
    Livinserene Thejerkyguy
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    There are some pretty kick ass stickers other than standard trd ones ,, I think there's a guy on TW that makes them,, thought I read that somewheres
  3. Feb 9, 2016 at 1:32 PM
    #163
    edummann
    edummann Well-Known Member
    Eric
    Bend, Oregon
  4. Feb 9, 2016 at 2:07 PM
    #164
    Livinserene
    Kevin
    Nova Scotia
    18 sport mt Ovtuned
    OV TUNED MOFOS
    edummann[QUOTED] likes this.
  5. Feb 9, 2016 at 4:32 PM
    #165
    Liquidmantis
    Liquidmantis Well-Known Member
    2016 MGM 4R TEP w/KDSS
    Does it seem like the internal frame eats cargo space?
  6. Feb 10, 2016 at 5:20 AM
    #166
    SlickDuck
    Greg
    Southern WV
    It may if you didn't have the internal toolboxes. I really didn't notice an issue with them hanging inside.
  7. Feb 10, 2016 at 5:37 PM
    #167
    funflyer26
    funflyer26 Active Member
    Phoenix Arizona
    2016 Inferno DCSB TRD OR MT
    Got my snugtop Rebel installed today. I like it so far! Windoors, lock keyed to the truck lock, sportsmans 500lb rating, fold down front window, etc. My stickers appear to be a bit high, so I'll have to pull them, oh well.
    dmc1, Quicksandman, Mtn Mike and 2 others like this.
  8. Feb 10, 2016 at 5:45 PM
    #168
    Vietguy
    Vietguy Well-Known Member
    Terence
    Arlington, VA
    2013 Tacoma
    @funflyer26 is your truck Inferno or Barcelona Red?
  9. Feb 10, 2016 at 5:47 PM
    #169
    funflyer26
    Phoenix Arizona
    @Vietguy its Inferno Orange, but due to its freaking amazing color and the current cloud cover it looks a little reddish. Wait till the sun comes out and it shifts again :)
    Vietguy likes this.
  10. Feb 10, 2016 at 5:56 PM
    #170
    Vietguy
    Terence
    Arlington, VA
    2013 Tacoma
    Any interior pics @funflyer26? How does the front shell window match up with rear cab window?
  11. Feb 10, 2016 at 6:27 PM
    #171
    YotaLife406
    YotaLife406 Well-Known Member
    16 DCSB OR M/T
    Great looking topper!! They did an awesome job matching the color! I still am partial to the look of the recessed windoors on the leer 100xr.
  12. Feb 10, 2016 at 8:36 PM
    #172
    funflyer26
    Phoenix Arizona
    I don't have any interior pictures handy, I'll try and get some tomorrow before I go out of town for the weekend. It does line up well though.
    I also like the more recessed doors of the Leer version, but I wanted the 500lb capacity so opted for the Snugtop.
  13. Feb 10, 2016 at 10:07 PM
    #173
    HalfWayThere
    HalfWayThere Well-Known Member
    SLO, CA
    2016 DCSB TRDOR 4x4
    It sounds like we got the same options and I'm pretty happy with it. I got the power lock on the rear hatch and did not bother getting it keyed to the truck. If I were to do it again, I would consider NOT getting the ventilation sliders on the windoors just because it looks like a lot of potential water leaks someday. But it seems like the best solution for dogs.
    If you are out taking pictures, can you take a close-up shot of how the nuts and washers are mounted on inside of the windoor handles/latches? Mine had split washers in a bad location so they were really stiff and sticky and inconsistent to use. I replaced the split washer with a flat washer and now it's great. I'm just wondering if they were all like that or something was done wrong on mine.
    Starting at the window, mine was assembled:
    Cast spacer cup -> split washer (which gouged into the spacer) -> plain hex nut -> latch tab -> nylock nut
    I kept the same assembly order, but just replaced the split washer with a flat washer and dialed in the spacing. (shown is the as-delivered setup)
    Also, I found the return spring and driver's side latch actuation cable on the rear handle was dragging on the cover. I trimmed the cover for clearance, but wondered if this was normal.
  14. Feb 11, 2016 at 8:17 AM
    #174
    funflyer26
    Phoenix Arizona
    I didn't notice the spring or cable dragging, so that might have been unique to your installation. My windoor latch looks just like your picture, but they are flat washers like your replacement, not split lock washers. lock washers definitely make no sense, why would they even have that in a parts bin? The installation guy told me that Snugtop gets their windoors from someone else, and they just install them which makes sense since the quality does seem to be a bit lower on the doors than the rest of the canopy. I had a miss drilled drain hole where they partially drilled out in the wrong spot and tried to cover it with goop, but its being replaced under warranty since the installer agreed that it was fine but shouldn't be that way from the factory.
    Sorry for the pictures being dark, a downfall of going to work at o-dark-thirty.
    Inside:
    Inside window:
    Windoor latch:
    Slider window from the truck side. They line up, but you loose about an inch or so since the canopy window is a bit higher.
    Vietguy likes this.
  15. Feb 11, 2016 at 9:26 AM
    #175
    HalfWayThere
    SLO, CA
    2016 DCSB TRDOR 4x4
  16. Feb 11, 2016 at 6:54 PM
    #176
    netboy27
    netboy27 Well-Known Member
    NJ - Southern
    '16 TRD OR 4x4 DCLB
    2006 Lund with a 60 hp Merc 4 stroke
    This is what I currently have on my 2006....love it. Going for a repeat on my newly ordered mgm DCLB!
    Tacoguy9200 likes this.
  17. Feb 11, 2016 at 7:10 PM
    #177
    netboy27
    NJ - Southern
    '16 TRD OR 4x4 DCLB
    My vote will be Leer...primarily for customer service. My cap developed cracks right above the hinges, eventually a little 1" triangle fell out. I was PO'd. Went to my local LEER guy as it was at 4 years 11 months on a 5 year warranty. He said it was definitely wrong, took the cap off right then and there, and sent it back to LEER. A couple of weeks later, I had a new shell. A good experience. FYI: 5 years into the replacement shell, no issues whatsoever.
    Dean724[QUOTED] likes this.
  18. Feb 12, 2016 at 9:01 AM
    #178
    sorgon82
    sorgon82 wanna go for a rip bud
    Ont. Canada
    2016 Grey Tacoma sport dc long bed
    That 5 yr warranty wasnt standard was is?
  19. Feb 12, 2016 at 3:38 PM
    #179
    netboy27
    NJ - Southern
    '16 TRD OR 4x4 DCLB
    Yup, standard.
    I haven't checked if they still have the same warranty nowadays. I guess I'll find out when I buy my new leer for my new truck
  20. Feb 12, 2016 at 4:28 PM
    #180
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    Lifetime. At least that's what I was told when I put the deposit down on a 100XR earlier this week.
