2016 Silver Tacoma TRD Off-road Lifted
Discussion in '3rd Gen. Tacomas (2016-2023)' started by JBnPIttsburgh, Nov 12, 2016.
  1. Nov 12, 2016 at 8:30 PM
    JBnPIttsburgh
    JBnPIttsburgh [OP] Member
    Pittsburgh, PA
    2016 Toyota Tacoma TRD Off Road
    Rough Country 3" front/2" rear block/shock lift, Stock wheels on Cooper ST MAXX 286/75/16, tinted windows, TRD hard rear cover.
    I will probably never have this truck off-road....so the spacer lift for me was sufficient....if you plan on doing some heavy duty off-roading you should invest in a better lift.....the kit came with rear shocks so that helped. Honestly it rides great....better than I thought it would. I had the stock tires on for a week before I got the ST Maxx and literally no difference in ride....
    Dhannah likes this.
  2. Nov 12, 2016 at 9:42 PM
    Clemons
    Clemons Well-Known Member
    Derek
    All of the Toyotas
    Would you mind measuring the height of those st maxx for me? They look fantastic! I have the same size in a K02 and they're small :(
  3. Nov 13, 2016 at 1:44 PM
    JBnPIttsburgh
    Pittsburgh, PA
    With 35lbs in each tire.... Just under 32"
  4. Nov 13, 2016 at 2:01 PM
    Clemons
    Derek
    All of the Toyotas
    Thanks man!
  5. Nov 13, 2016 at 3:22 PM
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    So the spacers are a worse alternative to adding 5100s instead?
  6. Nov 13, 2016 at 3:24 PM
    ZachMX
    ZachMX Well-Known Member
    00 AC, 08 DCSB, 11 AC,15 DCLB, 16 DCLB,17 DCSB
    yes and no, depends on what setting your going to run the 5100's at.
  7. Nov 13, 2016 at 3:47 PM
    facefirst
    Geoff
    Cleveland, OH
    I'd like a 3" lift. Not sure what setting that is on the 5100s
  8. Nov 13, 2016 at 3:48 PM
    ZachMX
    Then your going to want to pair it with a set of coils as well, like OME 887 or 888's not sure what everyone is running on the 3rd gens.
  9. Nov 13, 2016 at 3:56 PM
    TacoSharky
    TacoSharky Well-Known Member
    Socal
    Are you running 1.25 spidertrax spacers for all 4 wheels or just the fronts ?
  10. Nov 13, 2016 at 4:21 PM
    dhughins
    dhughins Well-Known Member
    Dave
    Skipperville AL
    2016 SR5 DCSB V6
    Looks good.
  11. Nov 13, 2016 at 5:30 PM
    JBnPIttsburgh
    Pittsburgh, PA
    I'm running 1.25" Spidertrax on all 4 with stock wheels.....
    Dhannah likes this.
  12. Nov 13, 2016 at 5:32 PM
    JBnPIttsburgh
    Pittsburgh, PA
    Yes I'm really running 1.25" on all 4 with stock wheels.
    TacoSharky[QUOTED] likes this.
  13. Nov 13, 2016 at 5:36 PM
    JBnPIttsburgh
    Pittsburgh, PA
    If your not planning on doing hardcore off-roading and want to keep your lift economical, take a look at the Rough Country lift. It's a spacer in the front and in the rear it's a spacer and a new shock....it's great for the money!
  14. Nov 13, 2016 at 5:36 PM
    JBnPIttsburgh
    Pittsburgh, PA
    The OME lifts are $$$$.
  15. Nov 13, 2016 at 5:41 PM
    #35
    Clemons
    Derek
    All of the Toyotas
    I'm less then $800 in my OME setup. I did use a block for the rear since I didn't want to lift that much.
    ZachMX likes this.
  16. Nov 13, 2016 at 5:44 PM
    #36
    JBnPIttsburgh
    Pittsburgh, PA
    I'm in $250.00 with my setup....and $200.00 for Spidertrax 1.25" wheel spacers....and $1100.00 for Cooper STMaxx 285/75/16.
  17. Nov 13, 2016 at 6:14 PM
    #37
    ZachMX
    You get what you pay for...just saying. Also you could do 5100's with OME springs as I alluded to for less than $600.
  18. Nov 14, 2016 at 7:28 AM
    #38
    facefirst
    Geoff
    Cleveland, OH
    So that setup would give about a 3" lift?
  19. Nov 14, 2016 at 8:22 AM
    #39
    ZachMX
    5100s with 888 coils I believe
    facefirst[QUOTED] likes this.
  20. Nov 14, 2016 at 8:28 AM
    #40
    tacoma1
    tacoma1 Well-Known Member
    Greg
    Blossvale NY
    17 TRD PRO
    looks awesome!! Id like to do spacer in my new Pro. Nobody makes one yet for it. Sucks. I had one in my 2010 and had no issues at all. Rode great.
