2016 SR 2.7L towing
Discussion in '4 Cylinder' started by sopranojam85, Jul 30, 2018.
  1. Aug 21, 2018 at 2:50 PM
    rblalliance
    rblalliance let the wookie win
    08 TRD OR DCSB 4X4
    Wow, that's a good price. I just got the Goodyear Wrangler All Terrain Kevlar (265/70/16) and I like them, will keep these in mind the next time I need tires.
  2. Aug 21, 2018 at 4:44 PM
    stomachbuzz
    stomachbuzz Well-Known Member
    Silver Spring, MD
    2005 V6 6spd!
    Why so much disdain to save money for the same product? It's literally just a few wires. That's the equivalent of refusing to chuck the Toyota OEM radio for an aftermarket headhunt.
    There absolutely is. And it's about $50.
    I helped a friend add a Curt in-line trailer harness to his 2005 2.7L Tacoma. He snagged a used tow hitch off a v6 truck for $40, and bought the Curt harness off RockAuto for $50.
    Beautiful harness. Literally clips into your taillight harness. No cutting or modifying wires. The only issue is the ground wire. The instructions provided by Curt say to "find a ground nearby" or "drill a hole in your frame". Uhh...No thanks on the drilling hombre. Not on these cotton candy frames. So we ran a ground wire all the way up to the battery and wired tied it along the way.
  3. Aug 22, 2018 at 3:52 PM
    BAMA-256
    BAMA-256 Well-Known Member
    Rex
    Huntsville Alabama
    2017 SR 4x4 5 speed manual Past-2016 TRD Offroad 4x4
    I would imagine you could have used any bolt that was already bolted to the frame, like rear shock mount, etc
  4. Aug 22, 2018 at 4:27 PM
    stomachbuzz
    Silver Spring, MD
    2005 V6 6spd!
    In theory, you are probably correct. I am a little nervous of chassis grounds in general though. Between my best friend and I, we have wired in many aftermarket radios, amplifiers, speakers, etc. We frequently run into interference, hissing, buzzing, etc that is from an improperly/non-ideally mounted ground wire.
    Almost every vehicle I've had has some sort of ground interference between the cigarette lighter and the aftermarket radio. Whenever I plug my phone into charge the radio goes "zzzzzzzzzzz". So annoying. Likely solved by simply running one of the grounds straight to the battery...
  5. Aug 9, 2020 at 9:03 AM
    thaiandAn88
    thaiandAn88 Well-Known Member
    Anna
    2018 Toyota tacoma
    Oh my god I just installed my hitch the other day by myself on ground level and I must say it took my 3 hours I was so pissed off how heavy this crap was I was so annoyed so I figure i install one of the bolt on the driver side and surprise the hitch was so fked up cricket and tilted to the wrong way finally I use a heavy duty ground jack and got it to mount correctly then today I checked and forgot the wiring it wasn’t installed -.-
