2016 SR - CFP GSD build
Discussion in '3rd Gen. Builds (2016-2023)' started by Caliph420, Mar 15, 2016.
  1. Jan 14, 2017 at 2:06 PM
    #41
    Caliph420
    Caliph420 [OP] Well-Known Member
    Washington
    2012 SR5 2.7 AC 4x4 Manual
    How the Taco sits today... took off the back half of the rack till I buy a jon boat / fishing canoe. Looks too work truck-ish to keep that on all the time.
  2. Jan 17, 2017 at 4:40 PM
    #42
    Caliph420
    Washington
  3. Jan 20, 2017 at 2:46 PM
    #43
    Caliph420
    Washington
    #43
    Wallbright likes this.
  4. Jan 25, 2017 at 6:43 PM
    #44
    Caliph420
    Washington
    Lil side project today getting my welding machine loaded up on a tray with some casters and all my welding junking loaded in the drawers. Should be a lot easier to wheel out weld then store now.
  5. Jan 30, 2017 at 1:10 PM
    #45
    Phistry815
    Phistry815 Member
    David
    2011 Tacoma DCSB 4x4 SR5 Black
    I have a few questions about these wheel covers. Do you have to take the center caps off to install these? Is the center of the black covers flat or curved and what would the diameter be if you wanted to put a sticker or a center cap emblem in there? Looks good btw, are you happy with the covers so far?
    #45
  6. Jan 30, 2017 at 1:26 PM
    #46
    Caliph420
    Washington
    Nope center caps are covered dont need to be removed. Center is flat and inset slightly (very slightly) and I've totally thought about adding a sticker or emblem, Super happy with them for what they are, cheap easy way to go black on the steel rim color and 0 issues with removability at a future date (Plasti dip is a huge bitch to peel on rims once it gets old and cracked/dried out). Ill get measurements of center circle... one sec
    Phistry815[QUOTED] likes this.
  7. Jan 30, 2017 at 1:30 PM
    #47
    Caliph420
    Washington
    Caps are 2.5 and 1/8 diameter
  8. Jan 30, 2017 at 1:31 PM
    #48
    Phistry815
    Phistry815 Member
    David
    So they actually dip in a little bit or basically flat? I was looking at a center cap metal stick on but it has a little bit of a curve to it like the factory center caps do.
  9. Jan 30, 2017 at 1:31 PM
    #49
    Caliph420
    Washington
    The one thing I dont like is how my tires look compared to the piano black shiny covers, but thats just a motivator to keep my tires clean. Not a huge deal
  10. Jan 30, 2017 at 1:34 PM
    #50
    Phistry815
    Phistry815 Member
    David
    Ok, thanks man.
  11. Jan 30, 2017 at 1:35 PM
    #51
    Caliph420
    Washington
    Untitled.jpg pretty flat but inset interior circle
    Greenbean and Phistry815[QUOTED] like this.
  12. Jan 30, 2017 at 1:36 PM
    #52
    Caliph420
    Washington
    NP, watch out when you put them on if you buy them they only fit 1 of 6 ways you can try to put it on, tripped me out when I tried to put them on at first thought I had wrong kind or something
  13. Jan 30, 2017 at 4:20 PM
    #53
    Caliph420
    Washington
    #53
    blkNtan likes this.
  14. Jan 31, 2017 at 8:44 PM
    #54
    Caliph420
    Washington
    Now I'm thinking of going with a cross between these two in square tube with diamond plate sides, going towards sports bar away from headache rack
  15. Jan 31, 2017 at 8:44 PM
    #55
    Caliph420
    Washington
    16426219_1567047186653974_2411943393079313250_n.jpg16463220_1567054679986558_1209393028819256558_o.jpg
  16. Feb 7, 2017 at 11:48 AM
    #56
    Phistry815
    Phistry815 Member
    David
    Caliph420[QUOTED][OP] likes this.
  17. Feb 7, 2017 at 11:55 AM
    #57
    Caliph420
    Washington
    What did you end up using for emblems? link? those look cool
  18. Feb 7, 2017 at 11:58 AM
    #58
    Phistry815
    Phistry815 Member
    David
    #58
  19. Feb 7, 2017 at 12:00 PM
    #59
    Caliph420
    Washington
    Ty, I've grown to like these covers a lot over the options of painting/dipping. Changes the whole look of the truck cheap and quick (In an ideal world I'd be buying 4Runner Pro rims and AT tires but this works for now)
    #59
  20. Apr 3, 2017 at 6:21 PM
    #60
    Caliph420
    Washington
    Fabbed up some drop brackets for my shovel and got plugs for the old holes where it used to be mounted
