2016 stereo wiring diagram
Discussion in '3rd Gen. Tacomas (2016+)' started by ccviernes808, Apr 28, 2016.
  1. Mar 22, 2017 at 2:39 PM
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    Does anyone have any experience with this plug and play harness?? I got it all hookup and my subwoofer isn't getting any signal... I plugged everything into the back of the head unit but no signal.... any help would be greatly appreciated. Thanks!
    http://*********.com/product/plug-play-add-subwoofer-harness/
  2. Mar 22, 2017 at 3:06 PM
    JonWon
    JonWon Well-Known Member
    AZ
    2017 DCSB OR 4x4
    Im getting ready to use this harness as well....so basically you unplug factory harness from head unit and plug this in, then plug factory harness back into the end of this right? There is a middle section that runs to the amp or loc correct? I would definitely say reach out to ********* they seem to know Toyota stereos pretty well and should be able to help trouble shoot.
    I wont know how mine works until this Saturday...
    goose443 likes this.
  3. Mar 22, 2017 at 4:06 PM
    hightechcoonass
    hightechcoonass Living the dream
    Ritchie
    land of the swamps LA
    2017 SR5 4x4 super white
    TRD Offroad wheels and decal set.
    Only a fool would pull the door panel on a brand new truck for a simple powered sub addition.... I soldered in a splice parallel to the wire, wrapped the exposed splice in silicone tape (AKA rescue tape), left slack it the splice so it lays flat and ran the wires back thru the rubber boot , then routed inside the pillar down to the floor. Done.... easy... the hard part was to identify the wires. So I posted the pic so others here don't have to "suffer thru looking for how to wire "
  4. Mar 22, 2017 at 4:24 PM
    goose443
    Austin
    Texas
    I've called several times still no response. About to pull it all out and just leave it stock
  5. Mar 23, 2017 at 3:22 PM
    JonWon
    AZ
    2017 DCSB OR 4x4
    Dang man...well like I said I'm giving it a go on Saturday and will let ya know how it goes I got the exact same harness so. You do have the option of not using that harness but then you have to splice into rear speaker wire...another option though.
  6. Mar 23, 2017 at 6:36 PM
    Gus Gorilla
    Gus Gorilla Well-Known Member
    2016 White TRD OffRoad
    None...yet
    I'm trying to use the ********* harness right now. But for all 4 doors and a sub. The problem I hit is that since it feeds back out to the speakers, you'll still have to cut either the car or the ezq harness to feed an amplified signal to the doors without causing a feedback loop. Naturally, ********* is unresponsive.
  7. Mar 23, 2017 at 7:02 PM
    JonWon
    AZ
    2017 DCSB OR 4x4
    The harness I have is just for the sub and amp and isn't made to include door speakers to the amp..I don't think anyways. It just let's you avoid splicing into the rear speakers.
    This harness:
  8. Mar 23, 2017 at 7:59 PM
    Gus Gorilla
    None...yet
    Yup. That has wires for the rear door speakers only. In a setup not trying to amplify all door speakers, you can use that to run rear door signal to an amp and sub/s. Probably benefit from a low pass filter too.
    JonWon likes this.
  9. Mar 25, 2017 at 2:20 PM
    JonWon
    AZ
    2017 DCSB OR 4x4
  10. Mar 30, 2017 at 2:04 PM
    JonWon
    AZ
    2017 DCSB OR 4x4
    Hey man did you ever get this working? Did my install and it worked fine. I may have put the remote wire in the wrong place but that's a different story.
  11. Mar 30, 2017 at 2:44 PM
    goose443
    Austin
    Texas
    No, I just pulled it all out and sent the subwoofer back. I didn't use a line converter but rather wired the wires straight into the amplifier because it is supposed to detect the signal and turn on automatically without needing a remote wire. Oh well haha ********* customer support is horrible
  12. Mar 30, 2017 at 2:47 PM
    JonWon
    AZ
    2017 DCSB OR 4x4
    Bummer...the amp I went with said auto detect but I still used the remote wire and a line converter.
  13. Mar 30, 2017 at 2:52 PM
    goose443
    Austin
    Texas
    That's probably what I should have done...
  14. Mar 30, 2017 at 2:55 PM
    goose443
    Austin
    Texas
    what did you put in your truck?
  15. Mar 30, 2017 at 2:56 PM
    #35
    JonWon
    AZ
    2017 DCSB OR 4x4
    Ya man it took us a little to see exactly what was going on but once we got it figured out it was pretty straight forward. Let me know if you decide to give it another shot sometime.
  16. Mar 30, 2017 at 2:58 PM
    #36
    JonWon
    AZ
    2017 DCSB OR 4x4
  17. Mar 30, 2017 at 2:59 PM
    #37
    goose443
    Austin
    Texas
    Did you put it under the seat?? Thanks for your help! I should have waited and tried again, but I just decided to send it back lol
  18. Mar 30, 2017 at 3:00 PM
    #38
    JonWon
    AZ
    2017 DCSB OR 4x4
    A
    Amp is under seat with line converter sitting right next to it just used velcro for bottom of amp I didn't want to drill/bolt it down.
  19. Mar 30, 2017 at 3:01 PM
    #39
    JonWon
    AZ
    2017 DCSB OR 4x4
    Also....all the stuff is cheap on jet if you bundle it all up. The box ended up being like $36 sub was under a $100 and amp is under a $100
  20. Mar 30, 2017 at 3:06 PM
    #40
    goose443
    Austin
    Texas
    How does it sound?
