2016 stereo wiring diagram
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ccviernes808, Apr 28, 2016.
  1. Mar 30, 2017 at 3:11 PM
    #41
    JonWon
    JonWon Well-Known Member
    AZ
    2017 DCSB OR 4x4
    I think it sounds real good man. I just wanted more lows and the 10" definitely delivered. Wasn't looking for pounding cruise the block to pick up honeys type of bass..little old for that. Radio station doesn't sound the greatest like classic rock bass lines hit weird but thats pretty normal lol.
    goose443[QUOTED] likes this.
  2. Mar 30, 2017 at 3:14 PM
    #42
    JonWon
    AZ
    2017 DCSB OR 4x4
    It just really stinks Toyota didn't put an out on the head unit....I didn't want to swap out my brand new stock head unit for aftermarket stuff just to get a sub. I was curious if the upgraded JBL head unit had a sub out since the JBL package comes with a sub but I couldn't find a rear diagram for the JBL unit.
  3. Mar 30, 2017 at 5:29 PM
    #43
    goose443
    goose443 Well-Known Member
    Austin
    Texas
    2016 Tacoma TRD Off Road 4x4
    I'm highly doubt the JBL head unit has RCA outs either
  4. Mar 30, 2017 at 5:30 PM
    #44
    JonWon
    AZ
    2017 DCSB OR 4x4
    Probably right sure it's just a different harness to add the sub.
    goose443 likes this.
  5. Mar 30, 2017 at 6:21 PM
    #45
    solscooter
    solscooter Sh!t Outta Luck
    Brian
    Minnesota
    2016 TRD OR DCSB 4x4
    Glad you got it worked out!
    JonWon[QUOTED] likes this.
  6. Mar 30, 2017 at 8:35 PM
    #46
    JonWon
    AZ
    2017 DCSB OR 4x4
    Thanks man ya pretty much worked out.. Have this weird feedback problem now hopefully it's just a matter of moving the amp remote wire. You happen to remember what you tapped into for the remote wire? I started a thread on the issue...my air was staying on for about 5 seconds after the ignition is off.
  7. Apr 4, 2017 at 2:09 PM
    #47
    JonWon
    AZ
    2017 DCSB OR 4x4
    I ran into more problems with this sub and amp install than I ever have.
    1st problem after having everything hooked up was feedback. My air was staying on for about 5 seconds after turning the truck off. Found out it was the remote wire the amp was actually powering the air system for 5 seconds after the truck was turned off...the amp I used has auto sensing so I disconnected the remote wire and problem solved.
    2nd problem no left rear door speaker. After fixing the feedback issue I noticed that my left rear door speaker was no longer working. Fix was pulling apart the taco tunes harness to find a bad wire in the harness. For anyone thinking of dumping the $40 on the harness I wouldnt. The point of the harness is to not splice into the rear speaker cables to get the audio signal for the sub....its probably easier to just splice into the rear speaker wire like most the other forum members are doing..or better yet make your own harness. The harness simply doubles the rear speaker wire connections.
    I emailed and tried calling ********* numerous times and heard nothing....unfortunately I will not buy anything else from this company.
    All in all I am very happy with the sub, amp and box though. Sounds better than I had hoped for and that's always a good thing!
  8. Apr 4, 2017 at 3:10 PM
    #48
    goose443
    Austin
    Texas
    I agree. ********* has HORRIBLE customer service and i will not be buying anything from them again. Glad you got everything figured out!
  9. Apr 18, 2017 at 6:02 PM
    #49
    4x4engr
    4x4engr Well-Known Member
    Pete
    2017 Quicksand TRDOR 4x4
    So if I'm looking at this diagram correctly, to tap into the front speakers is the R30 harness. Id splice 1 and 5 for right; 2 and 6 for left?
  10. May 8, 2017 at 6:55 PM
    #50
    Snowtrooper17
    Snowtrooper17 Well-Known Member
    Colorado
    '17 White TRD OFFRD V6 4x4 ACLB
    Where were you able to find this information (internet, repair manual, toyota service dept., etc) ?
  11. May 8, 2017 at 9:56 PM
    #51
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  12. Jun 5, 2017 at 6:36 PM
    #52
    Lvl8hacker
    Lvl8hacker New Member
    Larry
    Pinehurst, NC.
    2017 Tacoma TRD Off road 4x4
    Just thought I would post the wiring I used to install my system. Its spot on as far as describing what each wire is.
  13. Jun 25, 2017 at 11:52 PM
    #53
    tacogeorge
    tacogeorge Well-Known Member
    George
    So you never ended up connecting the right side? I was wondering about this myself. Seems much easier to just tap into the left and be done with it. The only impact I can imagine is if I ever mess with the balance and balance way right I'd start losing bass. I never mess with the balance though so its a non-issue, right?
  14. Jun 26, 2017 at 6:43 PM
    #54
    tacogeorge
    George
    Alright.. I got a kicker hideaway powered sub today. Hooked everything up and nothing happened. I don't have the remote line hooked up but I do have it set to DC offset which is supposed to sense power through the input and power on by that signal. I have 12v and a good ground at the harness as well as 6 volts at the input line. If I run 12 volts to the blue remote line it powers on and works. Seems to me like the auto on feature isn't working. Any ideas?
  15. Sep 22, 2017 at 6:10 PM
    #55
    remgu2000
    remgu2000 Keepin' on keepin' on.
    Ray
    Roswell, GA
    Used to have a 2017 Barcelona Red TRD Off-Road DCSB 4x4
    Ever get the auto on feature working? I'm getting ready to install my Hideaway tomorrow.
    Also, where did you tap onto the speaker wire? I'm thinking to do it from the grommet area by the door hinge.
    Lastly, do you recall the rear speaker wire colors? I noticed the right rear are green and blue but I forgot to pay attention to the right rear. The beginning of this thread (wire colors) is somewhat confusing to me.
  16. Sep 22, 2017 at 6:37 PM
    #56
    remgu2000
    Ray
    Roswell, GA
    What wire did you end up using for the ignition switch (auto-on feature)? I'm getting ready to install my sub tomorrow.
  17. Jul 3, 2018 at 1:54 AM
    #57
    serpico
    serpico New Member
    serpico
    To splitbolt
    Have all the Terminals of ecu .pdf
    Thank you
  18. Sep 30, 2018 at 6:30 PM
    #58
    a1dookie
    a1dookie Member
    2018 trd off road
    Do you have a PDF of these i can download please and thank you.
  19. Dec 19, 2018 at 4:32 PM
    #59
    Smoothmove
    Smoothmove Well-Known Member
    Stan
    Dallas TX
    2020 TRD OR CEMENT
    MesoCustoms
    Does anyone know what the plug in the top row in between the two large connectors is for? I don't have a connection in my truck for it. I am trying to upgrade my SR radio and am missing that one. 00j0j_k4SRDTP75tR_1200x900.jpg
  20. Dec 19, 2018 at 5:00 PM
    #60
    Smoothmove
    Stan
    Dallas TX
    2020 TRD OR CEMENT
    MesoCustoms
