2016 Tacoma 4 cylinder buyers remorse?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Edgargoyle, Apr 8, 2017.
  1. Apr 10, 2017 at 6:43 PM
    #101
    JeffreyB
    JeffreyB Well-Known Member
    Jeff
    2015 Access Cab 2.7 5 Speed 4X4
    Exactly. Value per dollar is absolutely insane. Which is funny to me because the opposite end of the Tacoma spectrum is some of the worst value per dollar in the automotive world in my opinion. They top out at what, $45k? For a mid size pickup. That is the same as a very nicely equipped half ton of any brand you like.
    Diablo169 likes this.
  2. Apr 11, 2017 at 8:42 AM
    #102
    75z28
    75z28 Well-Known Member
    Homer
    2017 OR 4x4 DCLB SSM
    I have a camper as well, along with around 300 pounds of junk(100 pounds of sand bags right now).
    Honestly they do get trash mileage, but if you're looking at more power... You need a sports car or a full size.
    I had around 2500 pounds worth of junk in my trunk coming from California to Alaska and got around 22mpg, again I have a stick so it might help quite a bit.
  3. Apr 11, 2017 at 11:31 AM
    #103
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Another 4banger guy here checking in, I actually just got done driving mine across the country, Philadelphia to Phoenix.
    Mine is a 4x2 with the 6 speed automatic. Absolutely no regrets power wise, except for when I was at about 6,000 feet and it was getting a little wheezy. The LCE header is an immense help, it's really the only I/H/E mod that is worth the money, in my opinion.
    Best mileage I've seen in it was 26.7, and I think that's damn impressive for a slushbox truck. On average though, I hover between 20/21 doing 80% around town with a modest lift and beefier tires.
    MPG is EXTREMELY dependent on the speed you decide to go and how you anticipate upcoming hills. On this cross country road trip I chilled out at about 65, basically not wandering too far past the 60-70 marks. It was in 6th most of the time turning about 1800 RPM, kicking down into 5th for some hills, 4th for the really aggressive ones. My friend helped me drive part of the way and he wanted to go ~75 or more, it was frantically hunting 5-4-5-4-5-4-5-4-5-4 (occasionally even screaming into 3rd) and getting 19 MPG. The truck is trying to tell you something at that point. It's also very important that you anticipate the bigger hills and give it a little kick before your speed rapidly drops to the point where 4th (1:1 ratio BTW) won't give you that pulling power you need simply because you're now going too slow to take advantage of the gearing.
    My final word on power... I switched to this truck from a ~300 HP WRX, I use this as my metaphor:
    When you "give it the beans"
    The Tacoma counts out exactly how many you need and hands them to you
    The WRX backs a full dump truck up to you, and dumps them all over your face.:rofl:
  4. Apr 11, 2017 at 2:13 PM
    #104
    Optimaltaco
    Optimaltaco Well-Known Member
    Dave
    Cochrane, AB
    '17 Tacoma DCSB TRD Off-Road
    TRD Pro - Grill and Rear Tail-Lights OEM Roof Rack FN overland 17x8.5” -6 BFG KO2 Morimoto 2 stroke LED headlights 30” auxbeam light bar Custom built Canopy Readylift 3" spacer kit Deaver 1.5-2" AAL Amber hazard strobe lighting
    I have the V6 so I can't say much about the I4 but I know in Canada it's usually not worth getting the I4 from a price point IMG_7100.jpg$1655 to go to a V6 on the SR5 Access cab. And to go to the TRD OR Access cab is an extra $1855. So you can go from a I4 SR5 Access cab to a V6 TRD OR Access cab for $3510
    *edit* if you go manual Access cab up here, It's only available in either I4 SR5 5M or V6 TRD OR 6M which is $5245 price difference
  5. Apr 11, 2017 at 2:16 PM
    #105
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Do you leave the cruise control on and let the engine drop a gear going up a hill? I cannot stand hearing the engine revving high when it drops a gear going up a hill so I cancel my cruise control.
  6. Apr 11, 2017 at 2:38 PM
    #106
    usadaytrader
    usadaytrader Well-Known Member
    I have 2nd gen 2tr-fe and 3rd gen V6. I love both trucks, but the v6 is much better to drive around socal, where there are a variety of terrain.
    That being said. The odometer on my 2005 Taco 4cylinder
    FHC, ExplorHer, SOSC and 5 others like this.
  7. Apr 11, 2017 at 2:57 PM
    #107
    Nitori
    Maricopa AZ
    2021 T4R SR5
    I have the utility package so no cruise for me. (I know I can add it.) I'm one of those non-cruise freaks who never uses it, even on a car that has it, because I'm a bit of a loon.
    Dropping a gear from 6-5 at 65 or so is the difference between 1800 and maybe 2200 so that's probably not the gear drop you are feeling. 5th or 6th into 4th is a big bump up into the powerband, about 3000+ RPM, I'm thinking that's what you are hearing/feeling. It's the jump between insanely deep overdrive and a 1:1 pulling gear.
    I don't think cruise is gonna be very good for anything but flat lands. Because the truck can't anticipate hills, it will insist on staying in 6th (because EPA!) drop speed rapidly, go into "oh shit!" mode and kick down hard into 4th.
    CusterFan[QUOTED] likes this.
  8. Apr 11, 2017 at 2:57 PM
    #108
    bob87
    bob87 Well-Known Member
    2019 cav blue access cab SR5, 4x4 Tacoma 3.5L
    I bought a 2012, 2.7L that was available with low mileage and a good price. It was intended as a second car and I don't tow anything. I got good mileage per gallon out of it and was quite satisfied overall; but it proved a lemon and major mechanical failures accumulated under warranty.
    So, I traded it in for 2016 year model of the same. Now, fuel consumption is higher and about equivalent to that of the 3.5L. So, given a better resale value , I would now opt for the V6, even if it costs about $2,000CAD more.
    I don't complain about acceleration and it's pretty fast if you rev over 3,000rpm. 6 speed auto is not great on the highway and it will downshift at the least incline. Works well in town though or on backroads.
    :canada:
    CusterFan and Optimaltaco like this.
  9. Apr 11, 2017 at 3:08 PM
    #109
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    In 2004 I had a bonus burning a hole in my pocket and decided I wanted a Mustang and drove a yellow V6 5-speed convertible off a dealers lot--for about 1/4 mile before I turned around and came back. The salesman wanted to know if there was a problem. I told him that if I bought that car I'd spend the rest of the time I owned it saying "Wow, I could have had a V8!"...
  10. Apr 11, 2017 at 3:13 PM
    #110
    Tunngavik
    Tunngavik Well-Known Member
    Alberta, Canada
    2018 TRD Off-Road Access Cab 6 speed manual
    KC-HiLites Fog Lamps, Kicker speaker and tweeter upgrade, USB in center console, Power tailgate lock, Soundproofing, 32" lightbar
    I own a 2010 2.7 with 5 speed. I don't tow but I do haul.
    At the time I bought my truck, compared to the 4.0l 6 speed, there was a significant difference in fuel economy so that's one big reason I went with the 2.7. Also when I bought the truck I lived in the middle of the prairies (i.e. no big hills) so power was not a big issue. I've since moved closer to the Rockies and have to climb some much bigger hills.
    If I were to buy a 3rd gen I would definitely upgrade to the manual 6 speed 6 cylinder. No real difference in fuel economy and the extra power would be welcome on the highways when climbing big hills/mountains.
    Edgargoyle[OP] likes this.
  11. Apr 11, 2017 at 3:42 PM
    #111
    CusterFan
    It drops a gear in a 10mph head wind on cruise also. I don't even have it on driving into the wind anymore. Tailwind is sweet though, get right at 28mpg on the 2.7
  12. Apr 11, 2017 at 4:50 PM
    #112
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    Another reason why I decided to purchase my 2016 2.7L was because I wanted the truck for reliability, not mpg or hp, it's a truck. If I wanted to go fast I would have purchased a sports car! The 2.7L engine has been around since 05 and the thing is Bulletproof, I got 28,2XX miles on the truck without one single issue. Shortly going to be ordering some gear oil and transmission fluid to flush the front differential, rear differential, transfer case and a transmission flush all at 30k. I see so many new posts from people complaining about all the 6 speed automatic transmissions and all kinds of other issues with the new V6. I'd rather settle for a aweosme motor with less power instead of visiting the dealership for TSBs and other issues all the time! :burnrubber:
    TheCookieMonster and Paul631 like this.
  13. Apr 15, 2017 at 2:23 AM
    #113
    Edgargoyle
    Edgargoyle [OP] Member
    Eddie
    2016 Tacoma sr5 I4
    Leer 100r camper with bedliner.
    When I'm driving with the wind going towards Coachella the highest I got was 28-3.. only happened twice though:notsure:
  14. Apr 15, 2017 at 9:33 AM
    #114
    Riksolo
    Riksolo Well-Known Member
    2017 Tacoma TRD Off-Road
    I get 20 mpg consistently on my v6
  15. Apr 15, 2017 at 10:19 AM
    #115
    Paul631
    Paul631 Well-Known Member
    2016 4x4 5-spd Utility Package
    Bilstein 6112/5160 Grabber X3's
    +1
    Mine was delivered nearly a month earlier than previously thought, at a dealership hours away from home, so it sat for 2+ weeks at the dealership prior to me picking it up.
    During that time, the dealership had numerous "I'll buy it today!" offers from people originally shopping for trd/sport models.
    Hiluxski[QUOTED] likes this.
  16. Apr 15, 2017 at 11:15 AM
    #116
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    Two 08 Highlanders, 11 Outback, 13 Outback
    In order of install: Tint all around Weathertech floormats Center console insert and tray 17x7.5 +15mm alloy FJ rims, painted black Morimoto 2stroke led low beams Toyota bed mat AVS in-channel vent visors Removed black stickers from doors Removed air dam Debadged JDM ASTAR reverse leds Door sill protectors Reflective black tailgate inserts Rear cam anytime Fabric console cover Extra coverage engine guards Rigid SAE fogs Kicker/Subaru in-dash speakers JBL GT7-96 front door speakers JBL GT7-6 rear door speakers Hushmat deadener and wave breakers in doors Noico deadener behind rear seats Timbren Tortun4L rear bumpstops Added Line-X'd OEM flares OEM mudflaps Skid from TRD OR Avid Off Road front bumper guard Fatmat hoodliner 2nd gen 5100's with 2885s Sway bar relocate Cut off exhaust behind spare Wet Okoles on front seats Wheelers Superbumps Wheelers 2” single AAL ATH corner tie-downs ATH bed stiffeners Line-X’d rear bumper end caps TRD Sport/OR tail lights OEM bed step TRD Pro grille Fortin remote start Leer 180 Sleeping platform in bed 265/70/17 Terra Grappler G2 BPF front recovery point OV Tune 1.04 87 Westin 30” hidden bumper light bar Rago hidden bumper brackets
    The 2.7 comes with such limited choices. To get a 2.7 with 4x4, all you can get is access cab with utility package.
    As for fuel economy, Fuelly shows V6 3rd gens averaging ~19 and I4 3rd gens ~21.
    Edgargoyle[OP], Paul631 and CusterFan like this.
  17. Apr 15, 2017 at 11:34 AM
    #117
    Hiluxski
    Hiluxski Well-Known Member
    Ventura California
    2022 Lime green TRD Pro
    Maybe i'm miss reading this but this is not true at all, you can get a 2.7 4x4 in automatic or manual, access cab or four-door . It comes in the SR or the SR5 trim levels you can have the convenience package or the utility package in SR or all the SR5 package upgrade stuff. You can't get this motor in TRD off-road, sports, Limited.
  18. Apr 15, 2017 at 11:38 AM
    #118
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
    That's not what the toyota configurator shows.
    Only SR5 Access Cab, SR DCSB and SR Access Cab allow 2.7 engine.
    Only SR Access Cab allows 2.7 with 4x4.
    Then you go to select transmission and it allows both MT and AT.
    Then for colors, it allows only White for MT and White or MGM for AT.
    Then you go to packages, and the only options are Utility Package or Utility Package with options (the only option being tonneau).
    CusterFan likes this.
  19. Apr 15, 2017 at 11:48 AM
    #119
    worthywads
    worthywads Well-Known Member
    Peoples Republic of Boulder
    05 5-lug access I4 Stick, 70 Challenger Vert
    SR5 Access cab can get 2.7 4x4 also
  20. Apr 15, 2017 at 11:54 AM
    #120
    gulzeb
    gulzeb G
    Gulzeb
    Fort Worth, TX
