2016 Tacoma 6” suspension AND body lift?!?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DapperDave123, Dec 12, 2017.
  1. Dec 14, 2017 at 10:18 AM
    #41
    5678ta
    5678ta Well-Known Member
    Hogan
    Henderson, NV
    '18 ECLB Colorado ZR2
    6" lift, heavier trimming (not surgery) and CMC should clear 35's. No body lift needed. Shit, people manage 35's on a 3" lift.
    If you want 37's, you will need to look into fiberglass fenders and bedsides. The wheel arches will barely handle a 35, as is.
    I run 1" wheel spacers. I'm not doing over 80mph or jumping but I let get nasty when she wants. No issues in 4 months. Just make it a habit to pull the wheels and check lugs.
    And don't listen to these people saying 6" DB lifts ride terrible. I've driven 2.5-3" lifted OME, toytech, fox 2.5" dsc, and icon stage 5. I prefer my 6" RCD DB lift on Bilstein 5100's over all those. The owners of those other lifts have driven my truck and love it. They just don't like the added height and "loss of ground clearance". I was the only one to NOT scrape frame on Hell's Revenge in Moab.
  2. Dec 14, 2017 at 10:24 AM
    #42
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    I don't think there's any loss of ground clearance, just no gain in ground clearance with a DB lift. That's why I want to do just a 1" body lift to clear the tires without raising the CG more. Also, it's already hard for my 5'2" wife to get into the truck as is lol.
    DapperDave123[OP] likes this.
  3. Dec 14, 2017 at 10:29 AM
    #43
    5678ta
    Hogan
    Henderson, NV
    Technically speaking, between the front wheels, the drop bracket hangs about 4" lower than stock. 3" lift without drop bracket vs my 6" db lift nets 1" lower cross member as she sits. But I do gain 3" on approach, high center and exit.
    rlx02[QUOTED] likes this.
  4. Dec 14, 2017 at 10:31 AM
    #44
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    I'm just here for the pictures of a 6" + 3" body lift.
    OP- do you wheel your truck? How have your 20s held up? Have you thought about getting smaller wheels for more sidewall? Slap some 37s on 16s and look like a monster truck lol
    DapperDave123[OP] and ChadsPride like this.
  5. Dec 14, 2017 at 10:39 AM
    #45
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    If your goal is 37" tires than a 2"+ long travel kit will clear on a 3" lift with proper back spacing and cmc. Plenty of people hardcore off road with that set up. Adding any body lift will NOT help you with clearing 37" since you would have to cut the entire body mount and relocate it back ~2" and probably tub the foot well. This process has been completed on 2nd gens on 3" lifts and 37" tires.
    Jibbs likes this.
  6. Dec 14, 2017 at 10:45 AM
    #46
    Jibbs
    Josh
    Cincinnati
    Whoooooooshchchch
    How does a long travel kit help 37s not rub on UCAs/fenders/cab mounts/etc. Doesn't it just get you more downtravel?
    (Am noob, plz bear with me)
    ChadsPride likes this.
  7. Dec 14, 2017 at 11:04 AM
    #47
    TacoRD16
    Houston, TX
    You shift your wheel turning radius out rather than increasing your wheel turning radius like with spacers. Fenders would have to be trimmed or glass would be needed and a CMC would most likely have to be done. Sorry I just assume everyone cuts fenders and CMC since its so easy. If people are willing to cut frame to install a drop bracket then trimming and CMC is nothing.
    The long travel is only to clear the body mount if not it would require cutting the entire mount and relocating it back. Its the hardest thing to work around when moving to 37" tires.
  8. Dec 14, 2017 at 11:16 AM
    #48
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    Thanks for the clarification.
    5678ta[QUOTED] likes this.
  9. Dec 14, 2017 at 12:50 PM
    #49
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    There's a dude who works at marlincrawlers who fit and wheeled his 3rd gen with 37s; saw the fender and bumper were trimmed but didn't see him posting about moving the entire body mount back or tubbing the wheels.
  10. Dec 14, 2017 at 1:21 PM
    #50
    TacoRD16
    Houston, TX
    Yeah I followed his build. That taco is crazy! But he is running All Pro 3"+ Long travel to push his turning radius out. So turn the wheel in your truck where the outside edge of the tire is closes to the body mount ~1/2 turn then measure out 3" then thats how much more clearance you have with long travel.
    rlx02[QUOTED] and ChadsPride like this.
  11. Dec 14, 2017 at 3:43 PM
    #51
    TacomaBlu
    TacomaBlu Well-Known Member
    2017 TRD Sport
    6in Procomp 35in Toyo M/T 18x9 Mamba M13
    I was running 37in Cooper STT, doubt 40s could have been done without the rubbing most get with bigger tires and no lift.
    Forgot to mention.. I did have an issue. Wasn't the lift it was the damn super swampers. Tore up both front wheel bearings, might have lost a filling or two.
  12. Dec 14, 2017 at 3:50 PM
    #52
    ScottyR
    ScottyR Well-Known Member
    Vancouver BC
    2016 DCLB TRD Sport
    Subbed for dirty sevens
  13. Dec 14, 2017 at 3:59 PM
    #53
    TacomaBlu
    2017 TRD Sport
    It has crossed my mind to do 37s again on my 17 but 2 things have kept me away. The 3.5L and the wife.
    No idea how the 3.5L with the current transmission coupled with a temperamental traction control would react with 37s.
    Miss the 4.0 setup!
  14. Dec 14, 2017 at 4:43 PM
    #54
    Zandroid
    Zandroid Well-Known Member
    Zander
    SoCal
    '16 TRD-OR DCSB 44
    King Ext Coilovers LR-UCAs BAMF Relocation w/ 12" 2.5 King Pelfreybilt Armor: Bumper, Skids, Sliders Prinsu Roofrack ARB Snorkel & Twin Compressor sPod
    Nope, that's not the quote you incorrectly replied to.
    There ya go.
  15. Jan 2, 2018 at 7:33 AM
    #55
    DapperDave123
    DapperDave123 [OP] Well-Known Member
    David
    West Palm Beach
    2016 Magnetic Grey Metallic Tacoma 4X4 Offroad
    6" Pro Comp Full Suspension Kit, 20" Fuel Rims Wrapped in 33" toyos, K&N Air intake, magnaflow exhaust, 8k hids, custom car grills, caliraised: led bar, ditch lights, and fog lights, avs taillight covers and window visors, Rhino lined rear bumper, plastidip emblems, nerf running boards, bed lights, all weather floor mats, Blacked out side headlight markers, white turn signal bulbs (blue when off), led bulbs: overhead, dome, vanity mirror, reverse and license plate.
    Im so sorry bro, can you ever forgive me??
  16. Jan 2, 2018 at 7:39 AM
    #56
    DapperDave123
    David
    West Palm Beach
    So I just had my 35s installed. They had to trim quite a bit off the body mount as you can see. I still have a small issue of it rubbing, but it’s only on the fender flares. So my main point of this whole thread was to figure out how people run 37s and up. Also, how do they accomplish that. So, that’s why I was asking if it was possible to add body lifts or other options to my 6” kit. I was just curious, never said I was going to do it and probably never will. But thanks for all the info, and hope it helps someone else one day!E5B9006B-667F-4CC3-A125-20A4EAC029F6.jpg 6A035034-D865-40C2-9E3F-700EF44683F2.jpg 982E6A9B-ECC8-49F3-BE3B-395AF6647FDD.jpg
    smw62891 and ChadsPride like this.
  17. Jan 2, 2018 at 8:13 AM
    #57
    HSmith_11
    HSmith_11 Tacoma Enthusiast
    Hunter
    Madison, Va
    2001 Ext Cab SR5 4x4 MT
    5100/OME 881s 1.5" Progressive AAL 33x12.50X15 KO2s
    Looks good. For some reason, I really really like that color with a big lift. Maybe it's the way it looks with the wheels. :thumbsup:
  18. Jan 2, 2018 at 8:19 AM
    #58
    DapperDave123
    David
    West Palm Beach
    Thanks! I love the color as well. I've wanted this truck for over 10 years, and now I finally have it lol.
  19. Jan 10, 2018 at 9:56 AM
    #59
    Zandroid
    Zander
    SoCal
    '16 TRD-OR DCSB 44
    I'll think about it.
