2016 Tacoma Curt Tow hitch 13264 Class 3
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Caliph420, Jan 21, 2016.
  1. May 16, 2016 at 7:59 AM
    #61
    moe2o4
    moe2o4 Well-Known Member
    Corey
    Pittsburgh PA
    2016 SR Silver 2.7L 5 Speed
    OME 3" Lift, 32" Tires, Lots of Mods!
    You wire up both into the same 4 wires so you can hook up either a 4 or a 7, the only three wires you leave go is the blue, black and yellow. Those are for a brake controller which I doubt either of us will ever need so I just taped those off!
  2. May 16, 2016 at 9:12 AM
    #62
    SR Peter
    SR Peter Member
    Peter
    2016 SR 4x4
    Intermittent Wiper
    Hello same parts here, when you wired the cut off 4 way to the 7 way did you wire exact color for color or is it 4 way yellow to the 7 way red on pig tail? Also any one having problems with those two bolts on curt hitch the trick is to poke a screw driver in the hole and tilt that metal tab sideways. I had the same problems until I saw E trailers vid.
    Wallbright, moe2o4 and joshjuniorr like this.
  3. May 17, 2016 at 6:50 PM
    #63
    moe2o4
    Corey
    Pittsburgh PA
    Red goes to yellow and all the others match!
  4. May 17, 2016 at 8:05 PM
    #64
    moe2o4
    Corey
    Pittsburgh PA
  5. May 21, 2016 at 4:04 AM
    #65
    joshjuniorr
    joshjuniorr Well-Known Member
    Josh
    Mississippi
    Got everything on last night other than the power wire. Ran outta daylight after work
    Sent from a beer can using string
  6. May 21, 2016 at 5:28 AM
    #66
    moe2o4
    Corey
    Pittsburgh PA
    Figures lol
  7. May 21, 2016 at 11:09 AM
    #67
    t3mpo
    t3mpo Well-Known Member
    Jose
    2016 Tacoma SR
  8. May 21, 2016 at 2:55 PM
    #68
    Caliph420
    Caliph420 [OP] Well-Known Member
    Washington
    2012 SR5 2.7 AC 4x4 Manual
    Haven't gotten around to the wiring yet, got side tracked with other projects on the truck
  9. May 21, 2016 at 3:38 PM
    #69
    t3mpo
    Jose
    2016 Tacoma SR
    I haven't ordered it. I was wondering if you had done it already.
  10. May 21, 2016 at 4:33 PM
    #70
    Caliph420
    Washington
    Nah, I looked into it but its not super high on my to do list so I haven't bought it yet.
    Wallbright likes this.
  11. Jan 3, 2017 at 9:12 AM
    #71
    Wallbright
    Wallbright Well-Known Member
    2017 MGM DCSB SR5
    Any updates on the wiring harness etc.?
  12. Apr 22, 2019 at 10:25 PM
    #72
    Monopod
    Monopod Well-Known Member
    2017 Silver sky tacoma SR I4 4x4
    plasti dip emblems, TRD off road wheels, pro clips cell phone mount. 20 percent tint.
  13. Apr 22, 2019 at 10:44 PM
    #73
    Monopod
  14. Apr 23, 2019 at 8:27 AM
    #74
    moe2o4
    Corey
    Pittsburgh PA
    $47.90 for the 4 to 7 pin connector & $64.95 for the T connector harness.
    Monopod[QUOTED] likes this.
  15. Apr 23, 2019 at 11:40 AM
    #75
    Monopod
    So all i would need is those 2 plus the receiver and hitch?
    moe2o4[QUOTED] likes this.
  16. Apr 23, 2019 at 11:50 AM
    #76
    moe2o4
    Corey
    Pittsburgh PA
    Correct, and just cut the 4 pin off of that T Connector harness and wire the 4/7 right to those 4 wires and put that in the stock location and you're ready to go. Looks just like factory!
  17. Apr 23, 2019 at 12:14 PM
    #77
    Monopod
    Thx. Did you purchase your stuff from etrailer or Amazon or both? Just want to make sure what part numbers i need before ordering.
  18. Apr 23, 2019 at 12:15 PM
    #78
    moe2o4
    Corey
    Pittsburgh PA
    Purchased them both off of e-trailer at the time but if their the same or cheaper on Amazon and you can get them quicker I'd go amazon!
  19. Apr 23, 2019 at 12:16 PM
    #79
    Monopod
    Do you mind telling me the part numbers? If thats ok.
  20. Apr 23, 2019 at 12:49 PM
    #80
    moe2o4
    Corey
    Pittsburgh PA
