2016 Tacoma Double Cab Audio Install Build
Discussion in 'Audio & Video' started by garyinok, Nov 23, 2015.
  1. Nov 25, 2015 at 11:30 AM
    garyinok
    garyinok [OP] Well-Known Member
    Gary
    That would be awesome. I'll PM you with my email. I don't have nearly that much time into this, and although I am pretty impressed with how it sounds I am not nearly there. With the guy I am looking to have Tune it he has been on the Mobile Electronics Top 50 installers list for like the last four years. I have not worked with him but he's got a pretty good reputation at least in the mid west. I am supposed to set-up with him after the holiday assuming I have the funds. My guess; very expensive. Anyway I would really appreciate the help and the files.
  2. Nov 25, 2015 at 1:02 PM
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    And this is exactly why i Do not suggest Processors to people. Some processors are nice to run still through passive for the other qualities but 90% of people do not have the time nor the skill to get it all setup correct in an active setup. They end up damaging their equipment and a ton of headaches compared to the basic EQ, phase and time alignment one can do with passive setups through a processor
  3. Nov 25, 2015 at 1:39 PM
    shaneckc
    shaneckc Fyntünd Designs Vendor
    Shane
    Thousand Oaks, CA
    2014 SR Package DCLB 4x4
    They are definitely not for everyone. But they are an absolute necessity for a certain type of people.
  4. Nov 25, 2015 at 9:00 PM
    kbeck72
    kbeck72 .............
    Kris
    Honolulu, Hawaii
    2016 Tacoma TRD OR
    Stock
    Do you by chance have all the measurements for this box and to the cut list??
    chealy86 likes this.
  5. Nov 30, 2015 at 2:06 PM
    WEXIE
    WEXIE Well-Known Member
    2016 Tacoma DCSB SR5 4x4
    @garyinok thanks for the thread man. First time tacoma owner here (2016 DCSB 4x4 SR5). Didn't get the JBL package. Bought some aftermarket speakers off of crutchfield over black friday and have not found instructions on removing the interior panels, wound you mind mentioning the screw(s) that need to be removed? I see one in the handle pocket, but not one at the actual lock/latch? Thanks for your help!
  6. Nov 30, 2015 at 2:39 PM
    garyinok
    Gary
    Sure; I have a sketch and instruction sheet that I got off the Toyota Site. Not sure how clear it came out, but I will try and post for you. If not PM me and I will figure out a way to send it to you.
    One word of caution, when you pull the wing trim off the little white clips tend to want to stay in the door. They can push through and drop so you will want to be careful not to push on them. Get a pair of pliers and grab them and then put them back on the trim piece. I learned the hard way. $5 each at Toyota.
    WEXIE likes this.
  7. Nov 30, 2015 at 4:59 PM
    jamesball21
    jamesball21 New Member
    jimmy
    2016 dcsb trd sport inferno
    Hopeful
    How's the sound quality from the stock h/u using the eq? Ive started down the same road and have a hard time seeing a clean signal coming from that unit as it sounds now. Thanks.
  8. Nov 30, 2015 at 5:53 PM
    garyinok
    Gary
    I finally got the subs broken in and had some tuning done and I am pretty happy with how it turned out. This is a system I had in my previous vehicle so I was somewhat familiar with how it could sound, but in the Tacoma I had a few compromises I had to make. One was keeping the head unit. So far I am very impressed with the stock unit, although without the BitOne I'm not really sure how it would do. There's a lot of factory equalizations that have to be dealt with. The other compromise was the tweeter location. Without making a mod of some kind I was stuck with the dash location. This turned out to be no issue at all, or at least not anything that couldn't be dealt with. I was committed to making this 100% stock, and completely invisible so nothing in the pillars or wings. Last compromise was no sound deadening. This was more a limitation I put on myself. I've deadened cars for years, and I just hate the stuff. This was probably the most surprising one of all. The guy tuning the system didn't know and kept commenting on how tight the doors sound. I finally told him at the end.
    So overall I am pretty impressed with the whole thing. The sundown 8's are truly amazing. The BitOne makes the most out of the pretty impressive head unit. I'm going to run it for a few weeks and see how it goes.
  9. Dec 1, 2015 at 4:35 AM
    ike3000
    ike3000 Well-Known Member
    If the windshield and dash are causing tweeter reflection issues, then you might want to look into getting a dashmat. I got one and it makes a huge difference with my tweeters in the a pillars. To see if it will make a difference try laying down a towel on your dash and do an A-B comparison on some songs. Some folks can use the reflections to their advantage while others just try to eliminate it. It's very vehicle and location specific, so definitely not a one size fits all sort of thing. Funny enough, I also found that putting closed cell foam (e.g., ensolite) on the back side of the rear view mirror made an improvement.
  10. Dec 1, 2015 at 12:06 PM
    garyinok
    Gary
    Actually this is not nearly the issue I was afraid it would be. With the 2016 the options are pretty limited, but IMHO it's really a non issue. I'm pretty blown away at how good this sounds.
  11. Dec 10, 2015 at 11:26 AM
    Alphafox21
    Alphafox21 New Member
    Andy
    2016 Tacoma Off-Road Double cab
    Hi Garyinok, THANK YOU for the posts and constant updates. I did a similar upgrade (minus the Audison bit 1) in my 2012 and it really made a difference. While waiting to take delivery of the 2016, I ordered all the components for the new build - adding in a bit 10 instead of the 1. Here's what I did:
    Stock Head Unit (w/o-JBL)
    Alpine PDX-F4 Amp
    Audison BitTen Signal Processor
    Alpine SPR-60c for the fronts
    Alpine SPR-60 for the rears
    Kenwood KSC-SW11 powered sub (I decided to go with the Kenwood sub as I don't like, need that much bass. I pulled it from the 2012 build and it did exactly what I wanted it to).
    NVX Sound deadening
    Ensolite IUO
    Well the 2016 has arrived and I only need to get a few final last items.
    Garyinok, when you mentioned the wire harnesses for the head unit, you listed two (the 70-1761 and 71-1761). I used the 70-1761 in my 2012 build and I was wondering if you needed parts off the 71-1761??
    Also - how did your tuning go with the Audison? I would love to see what you ended up with as the EQ settings go.
    Thanks again for all your hard work and posts - everyone.
  12. Dec 11, 2015 at 10:35 AM
    garyinok
    Gary
    On the wiring Harnesses. One is a reverse harness so I could plug it into the wires coming to the radio and plug the other end into the radio. Basically making a female to male adapter and but hooking the speakers into the bit one instead of our to the speakers. This way the original harness is left untouched. It worked like a charm except of the dimmer wire. I needed to move one of the male pins over a slot so the dimmer would be connected. There are a few threads on here about it. Easy to do and everything works just like it did from factory.
    On the tuning it went very well other than taking a long time. I figured it would be a couple of hours give or take, but it was an all day adventure. When I had this system in my Veloster I didn't invest in having the tuning done and had a local shop just run an RTA on it. I know now that was a mistake. This sounds way better than it ever did in the Veloster. It really made a lot of difference, but it was a bit pricey. Not to say it wasn't worth it, just not what I had in the budget. I haven't used the BitTen, so I don't really know what the differences are. I know Toyota has a ton of equalization built into the stock system that the BitOne took out. Not sure if the BitTen does that or not.
  13. Dec 16, 2015 at 4:32 AM
    Lucky Dragon
    Lucky Dragon Well-Known Member
    Thanks for sharing!
  14. Dec 17, 2015 at 11:05 AM
    Zac of all trades
    Zac of all trades FWP Fabrication Vendor
    Zac
    fwpfab.com
    2013 4x4 Locked DCLB
    886/5100s/AAL/UCAs/360 armor/RTT/295 17s
    Do those 8s beat hard? Ive never had a sub smaller than a 10".
  15. Dec 17, 2015 at 1:24 PM
    #35
    garyinok
    Gary
    Not sure how to define beats hard, but I guess it's all relative. I originally had a Focal 33KX which was a single 13". This was a massive speaker and when I got the Tacoma there was no way to get a driver this big in without making some major compromises. So with 1000W to work with I had to find a driver that would both fit (both physically and on box volume), and handle the power. The pair of eights was just a better combination than anything else I could find. Now that they are in and running it was absolutely the right choice. These blow the focal out of the water. Amazing response and depth. They go down every bit as low as the focal, but have better response in the upper ranges. Supplement my mid base drivers very well. So I guess yeah they hit hard.
    ratcityrain and TRULIFE like this.
  16. Jan 20, 2016 at 3:59 PM
    #36
    Reh4x4
    Reh4x4 New Member
    Robert
    16' DCSB TRD 4x4
    Hi Garyinok, great install. I actually showed yours to a local shop and they quoted over $1500 labor only to install a similar set up. They said $800 to install my Hertz high energy components, rear JL audio 6.5 inch, audiocontrol lc7i, alpine pdx-5 channel amp and my own sub box. I just had Mr. Marv make my adapters which are great. For that price I think I am going to tackle myself. My question is about how to tap into the speaker wires behind the HU to run 2 sets to the LOC. Not sure if I need the tweeter wire, front door speaker and full range rear door speaker to run. I wanted to mount the hertz tweeter with the surface angle mount on that black triangle by the outside mirror. Also should I run new wire, I know you said it was tough to get through the boot. Thanks for any info you can provide, I greatly appreciate it. Bob
  17. Jan 20, 2016 at 5:20 PM
    #37
    manethon
    manethon TTAS
    Steven
    Unknow
    Many
    Simply tap into the right wires for the loc or get the metra reverse kit
  18. Jan 20, 2016 at 5:55 PM
    #38
    garyinok
    Gary
    I would get the metra adapter and use it to tap into the speaker outs behind the deck. As far as the tweeters I was contemplating putting the tweets in the sails. My opinion a complete waste of time. The stock locations turned out to be awesome. I used the stock wires as well. Again no issues.
  19. Jan 20, 2016 at 6:11 PM
    #39
    Reh4x4
    Reh4x4 New Member
    Robert
    16' DCSB TRD 4x4
    Thanks for your input, should I get the ones you listed. Also would you mind sending me your Toyota front door removal pics. My email is sharonandbob2003@yahoo.com. Thanks again
  20. Jan 29, 2016 at 11:22 AM
    #40
    tombiosis
    tombiosis Well-Known Member
    T
    Ottawa Canada
    2023 TRD Sport DCLB, Super White
    N-Fab predator steps, Weathertech Floor mats, Tri-fold Tonneau Cover, TAG Tracking system
    great job!
    I like your approach to keeping everything ready to return to stock. Would like to do the same...
