2016 Tacoma Dyno Time!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redbusket, Jan 15, 2016.
  1. Jan 19, 2016 at 3:20 PM
    #201
    DirtEater
    DirtEater Well-Known Member
    Surprise, AZ
    Oh boy, so if I hit 6000rpm, I can haul ass? Typical high revving car engine, but let them salivate nonetheless, cuzz TOYOTA!
  2. Jan 19, 2016 at 3:25 PM
    #202
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Gen 1 dyno chart from K&N. Stock and K&N charts.
  3. Jan 19, 2016 at 3:25 PM
    #203
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    Also note the worst the engine does/measures in output is 85.9% of max torque at 2250 RPM (201 ft lbs of 234 ft lbs). Not sure how that compares (percentage-wise) to any other engines....
  4. Jan 19, 2016 at 3:30 PM
    #204
    TacoJonn
    Jon
    Laramie, Wyoming
    Yeah the gen 3 isn't a fire-breather but coming from my gen 1 that seems like a lot of pull.
    jonnyozero3 likes this.
  5. Jan 19, 2016 at 3:34 PM
    #205
    crzycav86
    crzycav86 Well-Known Member
    Houston
    I'd be interested in hearing your explanation. I do know the ramp rate (acceleration rate) that you set on the dyno has an effect because some of the torque that you would have measured goes into accelerating the drivetrain, but that's why you set a reasonably low rate. Even steady-state load testing has drivetrain losses (bearing friction, gears, CV joint phasing, etc..)
    Heepspo likes this.
  6. Jan 19, 2016 at 3:35 PM
    #206
    Daytona Coupe
    Daytona Coupe Well-Known Member
    Visalia CA
    16 TRD Sport DCSB
    2015 F150 5.0L torque peak - 4000 - 4500rpm - 340lb/ft (wheel)
    2250rpm = approx 290lb/ft = 85% of peak.
    Ran the same numbers for the Mustang engine - 80% at 2250 - mainly because peak torque is higher than the F150. They were both about 290lb/ft at 2250.
    Different tests, but the Toyota is in the ballpark with the 5.0L Ford, which is a very good engine.
    Ford 5.0 - 58lb/ft per liter at 2250
    Toyota 3.5L - 65lb/ft per liter at 2250
  7. Jan 19, 2016 at 3:37 PM
    #207
    TacoJonn
    Jon
    Laramie, Wyoming
    Seems like a perfectly capable motor for a mid-size truck. For guys like me who tow 3500 lbs 5x a year I dont see the problem.
    Rick111 likes this.
  8. Jan 19, 2016 at 3:38 PM
    #208
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    Not bad at all. nice job. Curious what it is for the GMC/Chevy Duramax Diesel. (oh god, better grab popcorn and a flame suit!).
    jeff_taco_4x4 likes this.
  9. Jan 19, 2016 at 3:46 PM
    #209
    TacoJonn
    Jon
    Laramie, Wyoming
    The Tacoma may have a minivan motor, but the Colorado has a minivan motor and minivan offroad prowess. They can keep the HP crown. Toyota has never cared about being spec king in anything other than the Prius.
    nevadabugle likes this.
  10. Jan 19, 2016 at 3:48 PM
    #210
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    What most people don't realize is that HP is meaningless without good & smooth torque delivery. The torque curve on the dyno chart is what really matters not horsepower calculations.
  11. Jan 19, 2016 at 3:50 PM
    #211
    Ang graz
    Ang graz Active Member
    2016 DCLB SR5 4x4 BRM
    Well it really doesn't sound to impressive that's for sure, was someone revving a 1.8 corolla in the background? I hope so
  12. Jan 19, 2016 at 3:50 PM
    #212
    TacoJonn
    Jon
    Laramie, Wyoming
    Well the Colorado has 3 more torques than the Tacoma. The Frontier has some like 280 lb ft.
  13. Jan 19, 2016 at 3:51 PM
    #213
    cgalloni
    cgalloni Well-Known Member
    Do you mean The torque On The 2016 is not good ?
  14. Jan 19, 2016 at 3:58 PM
    #214
    Redbusket
    Redbusket [OP] Member
    2016 quicksand off-road mt
    Ask and you shall receive! Oh and I ran it in 4th gear because it's 1:1 and is typically the gear we run all vehicles in on this dyno.
    Rick111, Kevindust, nv529 and 7 others like this.
  15. Jan 19, 2016 at 4:00 PM
    #215
    tacitos
    16 TRDORDCLBJBL
    No, based on the chart the truck has good torque measurements, but the delivery over the power band looks inconsistent. Delivery of torque is more important the max torque output.
    Look at this chart from one of my motorcycles.. the red line represents the stock output, the blue is the result of remapping of fuel and drive by wire systems. The red line dips just after 4k rpms, then starts to spike after 5k rpms. When your leaned over a corner doing 80+mph on a tire contact patch the size of a credit card, the last thing you want is that dip in torque. The dip will upset your suspension and make the bike rock, this also applies to cars. In the blue line, we smoothed out that dip and made a more consistent torque curve, this allows you to have a predictable throttle allowing you to control weight transfer without brakes.
    forty2 likes this.
  16. Jan 19, 2016 at 4:02 PM
    #216
    TacoJonn
    Jon
    Laramie, Wyoming
    Nice! Is it not possible to see it starting from 0-500 rpm? Curious as to how the torque is introduced.
  17. Jan 19, 2016 at 4:03 PM
    #217
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    :lalala:
  18. Jan 19, 2016 at 4:06 PM
    #218
    cgalloni
    That looks very nice
  19. Jan 19, 2016 at 4:07 PM
    #219
    Daytona Coupe
    Visalia CA
    16 TRD Sport DCSB
    You tested it again... Different test :)
  20. Jan 19, 2016 at 4:09 PM
    #220
    jeff_taco_4x4
    jeff_taco_4x4 Well-Known Member
    jeff
    16' 4x4 Sport DCSB w JBL, MGM
    ok, that does make sense. Did you like what you saw on the Tacom's dyno charts?
