2016 Tacoma Dyno Time!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redbusket, Jan 15, 2016.
  1. Jan 21, 2016 at 11:39 AM
    #341
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    What's with the torque wave?
  2. Jan 21, 2016 at 11:54 AM
    #342
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Lurkin' :spy:
  3. Jan 21, 2016 at 12:10 PM
    #343
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Toyota uses two injectors per cylinder on the D4-S, a port injector and direct injector. The transition between the way they fire causes the dips. IIRC, they fire both at low RPM's and DI takes over %100 in higher RPM's.
    The FKS also has a variable length intake runners that transitions between lower and upper RPM's that probably affects the torque curve as well.
    No, torque is NOT power. Two different things horse POWER is power.
    The problem with this argument is HP increases with torque. HP = Torque x RPM/5252 IIRC.
    To dumb it down, torque is force, HP is force per unit time.
    Rick111 and Lurkin like this.
  4. Jan 21, 2016 at 12:14 PM
    #344
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Torque is measured, HP is calculated
  5. Jan 21, 2016 at 12:19 PM
    #345
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    It still has no relevance when your actually driving. Smooth torque delivery gives you a predictable and controllable throttle input.
  6. Jan 21, 2016 at 12:23 PM
    #346
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    While this is sort of true, its not exactly complete. Torque is force. Power is force per unit time. HP is a very obscure unit of power.
    So break it down: Torque is measured (in the US) as lbs/ft
    HP = (Torque(lbs/ft) x RPMs (Rotations/min)/5252Rotations (the calculation to get this is complicated)
    So cancel out the units and you get HP=(lbs/ft)/Min
  7. Jan 21, 2016 at 12:27 PM
    #347
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I did not know that the new engine is running two injectors per cylinder, and I know the diff between torque and horsepower
  8. Jan 21, 2016 at 12:28 PM
    #348
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    It has all the relevance when driving. Torque only measures and takes into account 1/2 of the equation. HP is the inclusion of both factors that account for acceleration, the force exerted from the air/fuel mixture detonation and the amount of detonation per unit time. People always say "low end torque" which is fine, but low end torque is also low end HP.
    Yeah, I know Tomatoes, Tomatoes, but understanding how torque and HP relate to each other and relate to the engine will keep you from making stupid ass "van motor" comments.
  9. Jan 21, 2016 at 12:29 PM
    #349
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Not arguing, the point I was trying to impart was that HP is not measured. To your point, torque is measured, rpm is measured, HP is calculated based on those measurements.
    StAndrew[QUOTED] likes this.
  10. Jan 21, 2016 at 12:31 PM
    #350
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    The later wasn't exactly for you.
    Yeah, it has two transitions that take place as the engine rpms increase, the injectors and the variable intake runners (ACIS Acoustic Control Induction System), and for some reason, the stock tune doesn't smooth it out too well; not sure why :notsure:
  11. Jan 21, 2016 at 12:38 PM
    #351
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I'm going to play ignorant for a moment so bear with me on this. With this design, I wonder how new it is and if the engine will be plagued with carbon build up on the intake valves like the 2.0T that's in the VW's and Audi's. A few article I've been reading is even with the advances in technology there is still an inherent flaw with DI that causes the carbon build up on intake valves.
  12. Jan 21, 2016 at 12:45 PM
    #352
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    "In theory" this should be much better since when in port injection mode fuel sprayed will hit the valves and clean them. Unclear if its enough to keep them fully clean though.
  13. Jan 21, 2016 at 12:47 PM
    #353
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    BLUF: You don't have to worry about carbon build up on the Toyota D4S engines.
    There are two issues with carbon build up to worry about on a DI engine.
    One is carbon build up on the valves. This can be mitigated by running a catch can so blow by from your PCV doesn't coat your valves. Port injection engines don't have this issue as the fuel from the injectors "clean off" the valves. Since Toyota's D4S system uses port injectors during low RPM running, in conjunction with the DI (for a more efficient burn), you don't have to worry about this.
    The other place carbon can build up is on your Direct Injectors. It doesn't just clog the injectors but it can heat up and act as a glow plug of sorts and cause pre detonation. Toyota's D4S uses side ports on the injector to clean them off during a Cleaning cycle that occurs at idle when the ECU decides its due for one.
    Rick111 likes this.
  14. Jan 21, 2016 at 12:54 PM
    #354
    tacitos
    16 TRDORDCLBJBL
    I think you are confused with the difference between overall measured power / torque output vs power / torque output at a given RPM. All I'm saying is that the torque curve is more important because it will determine how power / torque is delivered throughout the rev range.
    Here is and example what I mean, and I've actually experienced this.
    Your driving a big horsepower v-8 RWD car down the straight on an oval track. As you approach the banking you have to shift the weight of the car forward to increase your front tire grip. After you pointed the car properly, you use the throttle to shift the weight towards the back so that the rear does not loose grip. Without a smooth torque delivery, the transition of weight from front to back would be allot more dangerous and difficult to manage.
    Please understand I'm not trying to win an argument here, but unless you've driven on a track at high speeds this concept is difficult to comprehend. If your experience at a race track is different than mine, then I'm happy to hear how.
  15. Jan 21, 2016 at 1:03 PM
    #355
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    We're splitting hairs. You can't make an argument about "low end torque" or "flat torque curve" as each equate to low end HP and a linear HP curve respectively. They are both the same thing; all I'm saying is people that make that argument (generally the people that say "torque win's races") are not getting the whole picture.
  16. Jan 21, 2016 at 1:12 PM
    #356
    BMWags
    BMWags Well-Known Member
    Brent
    2012 Ford Raptor
  17. Jan 21, 2016 at 1:13 PM
    #357
    tacitos
    16 TRDORDCLBJBL
    We are splitting hairs..
    What kind of racing are we talking about? I'm talking about the ones that have corners that need to be steered.
    Straight line speed requires good torque and horsepower output.
    High speed cornering requires good throttle control, good throttle control requires smooth torque delivery.
    This at least has been my track experience. Not only that, its what I've been told by some top engine tuners and pro racers in the country.
  18. Jan 21, 2016 at 1:14 PM
    #358
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Some of what I was reading just now is that some overlap in the intake valve duration and post ignition leads to some of it. A catch can may help some of it but there is still a bit of oil that'll rundown the valve and cook off.
    Off topic but I see you're in hampton roads, I got to Portsmouth this summer. Seen a few Tacoma's running around but they seem few and far between.
  19. Jan 21, 2016 at 1:24 PM
    #359
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    I found this interesting tidbit on Edmunds. "the rapid adoption of DI has actually illuminated an issue, not caused one. A “dirty” intake or exhaust-recirculation design can easily go undetected in a conventional port-injected engine due to the cleaning effect of gasoline passing over the intake valves. When the same engine designs are adapted to direct-injection fueling, however, that cleaning effect is suddenly lost – and the carbon layers can build."
  20. Jan 21, 2016 at 1:26 PM
    #360
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Yeah, a catch can won't fix it as many ford Ecoboost owners are finding out. And intake cleaners are blowing up their turbos :facepalm:
    Since Toyota uses both direct and port injectors pretty much most of the time, unless you are driving around at 3-4k+ rpms all day, the port injectors will keep your valves clean. My theory with the dip is when they tuned the engine when for the eco transition. I'm sure you can make the transition smooth by overlapping the DI and PI injectors during the transition, but at the expense of running rich during the transition. I'm not sure its the intake valve duration as the dip is common across all D4S engines, including the Scion FRS. When I get entirely too board, Ill probably read more into it; for now I'm happy with my "no technology" 5VZ :thumbsup:
    There's a few around here. Lots in Va Beach, Hampton, Newport News/Yorktown ways. I think Tanner and Clint (who drives a Honda DD) are the only ones that live in Portsmouth.
    Exactly but the D4S system still uses port injectors (in conjunction with DI) during idle, up to about 3-4k rpms.
    Mosquisite likes this.
