2016 Tacoma Dyno Time!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redbusket, Jan 15, 2016.
  1. Jan 22, 2016 at 8:16 AM
    #401
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    Has anyone actually felt the power band dip while driving?
  2. Jan 22, 2016 at 8:51 AM
    #402
    Daytona Coupe
    Daytona Coupe Well-Known Member
    Visalia CA
    16 TRD Sport DCSB
    The dip is not caused by the fueling. Engines are not as sensitive to fuel mixture as many people think, and Toyota would do a better job on the fuel map than that. The dip is more likely due to the variable cam timing - and maybe variable intake tract if it has that. What you are seeing is not really as much of a dip, but the area below the "dip" being a bulge from the advanced "low end" cam timing being in effect. Lock the cams and intake (if it has that) in one position as many people are used to seeing and it is highly likely that the "dip" goes away. When you are dealing with variable geometry systems, it isn't unusual to see torque curves like this. Without it, we'd have no dip, but that low end bulge would be gone too. Either that, or they would tune it for the low end, and the top end would not be as good. This way, we get the best of both. It's a good thing.
    Kevindust, CanadaToy and tacitos like this.
  3. Jan 22, 2016 at 8:57 AM
    #403
    Daytona Coupe
    Visalia CA
    16 TRD Sport DCSB
    The load on that dyno is whatever the dyno operator tells it to be. If you want heavy load, it will do it. As far as the engine management system is concerned, load = manifold pressure. Maximum throttle = maximum load. As far as the dyno is concerned, load = rate of acceleration. More load = slower rate of acceleration. That dyno has enough load capability to stop the axle at full throttle if you wanted to.
  4. Jan 22, 2016 at 9:30 AM
    #404
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    I know it's a different engine, but I saw some posts somewhere that the mid-range dip was smoothed out for the FR-S/BRZ by changing headers and doing a tune. I wonder if it's an emissions issue to make more power in that RPM band with D4-S for some reason?
  5. Jan 22, 2016 at 9:33 AM
    #405
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    I completely disagree.
    A: Engines are very sensitive to fuel mixtures. If my theory is correct, Toyota can very easily tune out the "dip" but it would require a time of overlap between the two fuel injection methods which will result in a period of rich running that will marginally increase emissions and decrease fuel efficiency.
    B: The variable valve timing system on the FKS doesn't use profiles but continuously adapts to the engine speed therefore there won't be any noticeable profile changes in the dyno.
    C: As I mentioned before, the ACIS system can also be a factor but since this is common with all D4S systems, I'm pretty sure its the fueling transition that is causing this.
  6. Jan 22, 2016 at 10:02 AM
    #406
    Daytona Coupe
    Visalia CA
    16 TRD Sport DCSB
    That's your choice, but pretty much everything in your post is incorrect.
    At WOT in this RPM range, it is not transitioning between two fuel modes on this engine, that happens at lower throttle levels, but you refuse to accept this for some reason.
    Nobody is arguing that the actual cam profiles change, their phasing does - if there were no noticeable change in the torque profile on the dyno they wouldn't be doing it. That is the main advantage to having variable cam timing.
    It isn't the fuel transition, that doesn't happen at WOT as pointed out above and previously to you. Believe what you want, but the facts aren't supporting your argument.
  7. Jan 22, 2016 at 10:04 AM
    #407
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Similar wave on the FA20 engine's torque curve. Exacerbated with the addition of the twin scew s/c.
    ***Edit*** Both the Tacoma and this car were dyno'd using a dynapac dyno.
  8. Jan 22, 2016 at 10:18 AM
    #408
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    First, I refuse to accept it because Toyota says differently :notsure: @Torspd may be able to help out here, but I don't know may dynos that put a "Heavy Load" on an engine. The mustang dyno is about as heavy a load you get and the OP used a dynopack.
    Do you understand how the Toyota's VVT-i works? It literally adjusts the valve timing on the fly. Its not a two or three profile cam that kicks down at a certain RPM. '
    Try to look up the facts before saying they don't support my argument.
  9. Jan 22, 2016 at 10:20 AM
    #409
    Daytona Coupe
    Visalia CA
    16 TRD Sport DCSB
    Example of variable cam timing: (not the actual torque curve but a reasonable example to demonstrate the principle)
    Blue line represents likely torque with retarded cam timing only
    Red line represents likely torque with advanced timing and reduced lobe separation for high rpm
    Black line represents the sum of both with variable timing.
    At high torque (throttle) engine is operating on direct injection only.
    At lower settings, and until a certain rpm point, both systems are used.
  10. Jan 22, 2016 at 10:23 AM
    #410
    WOODEX M.E.
    WOODEX M.E. Well-Known Member
    Corey
    Maine
    2013 Tacoma TRD OR Pyrite Mica
    TRD Supercharger, Speedhut TRD Boost Gauge, Speedhut TRD AFR Gauge, PLX Wideband Controller W/Bosch O2 Sensor, Cravenspeed Boost Pod, AFE Pro Dri II Si Intake, Calvert Racing Caltrac Traction Bars. URD Catback Exhaust, URD 2.825" Super Grip Pulley, URD Spec-U Equal Length Headers, URD 255lph Fuel Pump, OEM FPR Mod.
    I disagree. If you want to go fast in a truck, do it in a truck that is fast. Or make the truck you have fast. Saying "just get a sports car" is a cop out and total BS for most anyone on this forum who has ever done any sort of performance modifications. Tell guys on XRU that and they will you the same shit. The comments you made were so generalized that they can not be appropriately applied to any person who has ever considered themselves a motor head or enthusiast. Some times you also have to make due with what you have, or bought.
    Torspd likes this.
  11. Jan 22, 2016 at 10:24 AM
    #411
    Daytona Coupe
    Visalia CA
    16 TRD Sport DCSB
    The dyno load on a Dynapack is user defined. It can be very light, very heavy, or wherever you want in between. A Mustang dyno is also somewhat user defined, and it nowhere near as heavy as you can get. You obviously don't know much about how different dyno operate.
    Yes I do understand it - fairly well actually. Like I said believe what you want. You're still wrong on most points.
  12. Jan 22, 2016 at 10:26 AM
    #412
    StAndrew
    Hampton Roads, Va
    SR5 4x4TRD
    Ok, all you idiots out there spouting off motivated me to actually look into this deeper, not speculate.
    From the D-4S development papers for the 2GR-FSE:
    Its due to intake port designs. We were all wrong.
    /discussion
    Rick111, tacitos and Torspd like this.
  13. Jan 22, 2016 at 10:37 AM
    #413
    crepr12
    crepr12 Well-Known Member
    25 Limited Hybrid
    Was the dyno ran at "part loads"...that would be unusual
    Daytona Coupe likes this.
  14. Jan 22, 2016 at 10:37 AM
    #414
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I purchased a Tacoma to go off-roading. Must have purchased the wrong parts because it turned into a race truck. With 400+ whp and 450+ wtq. (@~8 psi.Hehe.)
    Curious to see what a motivated person like me can do with this engine in the 3rd gen.....
  15. Jan 22, 2016 at 10:38 AM
    #415
    tacitos
    16 TRDORDCLBJBL
    fair enough, my opinion is based on experience. I've been in fast trucks, fast cars, modded and un-modded but the only vehicle that I ever felt the most speed in was a motorcycle (175mph). Sure motorbikes may not be for everyone and IMO the next best thing would be a sports car then a modded car or truck.
  16. Jan 22, 2016 at 10:38 AM
    #416
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    Hahaha, they said homogeneous and heterogeneous
    Metalnut, Torspd and StAndrew like this.
  17. Jan 22, 2016 at 10:40 AM
    #417
    tacitos
    16 TRDORDCLBJBL
    This is the kind of data all these conversations should start with.. thanks for looking that up.
  18. Jan 22, 2016 at 10:46 AM
    #418
    4x4Runner
    Drunken Sailor
    1WD
    nuttin fancy
    Meanwhile the rest of us are going "shit, why didn't I find that?"
  19. Jan 22, 2016 at 10:47 AM
    #419
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pfff....facts....
    Metalnut likes this.
  20. Jan 22, 2016 at 10:47 AM
    #420
    Daytona Coupe
    Visalia CA
    16 TRD Sport DCSB
    He just proved my point. (ignoring the fact that he posted info on a different engine)
    It says right there in the highlighted area that it uses both set of injectors "at part loads" - meaning less than full throttle.
    Dyno tests (and nearly all power and torque graphs published for public viewing) are done at full throttle - a.k.a. full load. The dyno test being argued was at FULL throttle.
    Case closed on that one. I hope...
    crepr12 likes this.
