2016 Tacoma Dyno Time!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redbusket, Jan 15, 2016.
  1. Jan 19, 2016 at 9:26 AM
    #101
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    That is where peak torque is on my 2002, between 3 and 4k rpm. I get that power output to the wheels will be less than from the actually engine, but shouldn't the torque curve be the same as what Toyota advertises at 4600?
  2. Jan 19, 2016 at 9:31 AM
    #102
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Graph looks strange to me due to torque dips and peaks. Not sure why those are so pronounced. Also run should be made at tranny's 1:1 ratio to minimize gear ratio deltas. Autos are next to impossible to get good results on since they cant lock it to a gear.
  3. Jan 19, 2016 at 9:33 AM
    #103
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    Fuel remap may find a small bump in torque output but the only thing that's really worth fixing is that dip at 4300. Other than that it's a pretty smooth and decent torque curve..
  4. Jan 19, 2016 at 9:33 AM
    #104
    TacoJonn
    Jon
    Laramie, Wyoming
    Is OP's engine modified somehow? So many questions! Also, I too want to know why there are so many peaks and valleys between 2000 - 5200 rpm.
    AlpineTaco16 likes this.
  5. Jan 19, 2016 at 9:33 AM
    #105
    Hammer16
    Hammer16 Well-Known Member
    Western MA
    2016 Quicksand Tacoma DCLB TRD OR
    The peaks and dips are so pronounced because of the Atkinson cycle vs. Otto cycle and Direct vs. Port injection. The engine operates in both cycles and uses both injection types as needed.
  6. Jan 19, 2016 at 9:34 AM
    #106
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I'm not smart enough to tell you why they are so pronounced. However I can tell you that while driving the manual I can clearly feel those peaks in tourqe number in the same spots.
    tcBob and forty2 like this.
  7. Jan 19, 2016 at 9:35 AM
    #107
    tacitos
    16 TRDORDCLBJBL
    Which graph are you looking at? I only see the k&n one
  8. Jan 19, 2016 at 9:38 AM
    #108
    nevadabugle
    Elko, NV
    I'm looking at the photo of the computer screen in post 101.
  9. Jan 19, 2016 at 9:39 AM
    #109
    Toyko Joe
    Toyko Joe Here for the pictures
    I am not sure this is correct.
  10. Jan 19, 2016 at 9:42 AM
    #110
    Hammer16
    Western MA
    "That's a little silly. I would assume that it would select one mode that makes the most power for a full load but then again it is a Toyota."
    Toyota engineers have said that the engine operates in Atkinson cycle for efficiency and switches to Otto cycle for the power. If you gradually transition the throttle, Atkinson cycle is how the engine will operate. If you mash the throttle, it will switch to Otto.
    Injections methods are similar concept from what I hear, but less is said about that.
  11. Jan 19, 2016 at 9:43 AM
    #111
    TacoJonn
    Jon
    Laramie, Wyoming
    My conclusion from this dyno test is that I don't have a conclusion.
    JimJustJim and nevadabugle like this.
  12. Jan 19, 2016 at 9:43 AM
    #112
    tacitos
    16 TRDORDCLBJBL
    Missed that one, definitely needs a fuel remap to smooth out the torque curve. But as advanced as this engine is it may need more tweaking. I would disable Atkinson altogether if possible then dyno.
  13. Jan 19, 2016 at 9:47 AM
    #113
    TacoJonn
    Jon
    Laramie, Wyoming
    I guess without a gen 1 4.0 or a gen 3 auto doing the same test on this machine, it's not really possible to see how the new 3.5L compares. Just by going off the dyno chart OP posted, it would seem that the torque curve isn't as bad as people said it would be. While the 3.5L is meant to rev, you still get some pretty good torque sub-4200 rpm.
    jonnyozero3 likes this.
  14. Jan 19, 2016 at 9:50 AM
    #114
    Hammer16
    Western MA
    Engine cycles are my only thought. I'm guessing (just my hunch) that Toyota might have programmed the computer to run on Atkinson for low rpms and Otto for higher rpms. Again this is just a guess. Until someone is able to "unlock" the engine control module and tune it, we likely will never know the real cause.
  15. Jan 19, 2016 at 9:52 AM
    #115
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    DUH!
  16. Jan 19, 2016 at 9:57 AM
    #116
    tacoma4
    tacoma4 Well-Known Member
    Why do the torque and power curves not cross at 5250 rpm? Something looks off with that chart.
  17. Jan 19, 2016 at 9:57 AM
    #117
    Toyko Joe
    It looks like as the load is increased the Torqe is sawtoothing because of ECU controlled fuel limitations. Just a guess.
  18. Jan 19, 2016 at 9:59 AM
    #118
    Toyko Joe
    They would if the Y axis were the same scale.
  19. Jan 19, 2016 at 10:06 AM
    #119
    TacoJonn
    Jon
    Laramie, Wyoming
    Is this the only known dyno chart of the 2016 out there?
  20. Jan 19, 2016 at 10:07 AM
    #120
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    I haven't driven the 3rd gen, so bear with me. My understanding though is at full throttle, which you should be in for a dyno run, that it will not drop into an Atkinson cycle or injection mode, they should stay in full power mode, eg, open loop.
