2016 Tacoma Dyno Time!!!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Redbusket, Jan 15, 2016.
  1. Jan 19, 2016 at 2:21 PM
    #161
    crzycav86
    crzycav86 Well-Known Member
    Houston
    Aside from the weird torque-dip in the mid range, it looks like a pretty decent tq and hp curve. I suspect that has something to do with the automatic transmission - I'd really like to see a dyno of the 6 spd manual.
    For those asking, the low end torque is needed for good acceleration while towing (starting from a stop, etc) but you want the high end hp for passing power on the highway.
    The single HP and TQ values you get from the sales brochure are over-rated anyway, since those are peak values at discrete RPM's. It doesn't tell the story of how the engine gets to those values, which is why the dyno chart is important. What you should actually care about is how flat the torque curve is and how long it holds its torque, because that correlates directly to how the car accelerates while you're driving it.
  2. Jan 19, 2016 at 2:26 PM
    #162
    nevadabugle
    nevadabugle Desert Rat
    Elko, NV
    2016 DCSB TRDOR manual in quicksand
    I believe that ops curve was done with a manual.
  3. Jan 19, 2016 at 2:26 PM
    #163
    jonnyozero3
    jonnyozero3 Well-Known Member
    Dry places
    '99 TRD OR V6 M/T
    OME, sliders, dents, hail damage, soiled armrest. Lightbulbs.
    OP's pic is a 6 spd manual. The junky one I found was an AT.
  4. Jan 19, 2016 at 2:33 PM
    #164
    JRaggs
    JRaggs Well-Known Member
    Allen
    Sharpsburg, Ga.
    2016 Silver Tacoma limited
    Aint worth 4K! But that being said, I had the TRD SC on my 2013 and it sure felt like a shit load more that 30 hp/tq difference. I just got tired of the noise. (Getting old)
  5. Jan 19, 2016 at 2:37 PM
    #165
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    Guessing the shifting effects the numbers a little more on the 16 due to the extra gear?
  6. Jan 19, 2016 at 2:42 PM
    #166
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    That's not an accurate dyno run. You want to lock it in direct drive gear (4th?) and lock the converter if its an automatic. The surge as it shifts will cause very erratic readings.
  7. Jan 19, 2016 at 2:42 PM
    #167
    Frank_Zuccarini
    Frank_Zuccarini Obscure Member
    Frank
    Chicagoland
    AC-TRD-OR-4x4-Barcelona Red
    I don't know about you guys, but I think that over 210 ft-lbs torque at 2000 rpm is pretty terrific!
    Thanks to the post originator for doing this for the community.
    Frank
    BMWags, nv529, Wilds1 and 1 other person like this.
  8. Jan 19, 2016 at 2:44 PM
    #168
    Aussiek2000
    2016 Offroad AC
    My car makes that right off idle.
    *click for video*
    th_76C8F6BF-AA05-4F20-97BC-EDA5C4AA19B9__e199e415610dafe7ef4c906de85b2bfff692c2ed.jpg
  9. Jan 19, 2016 at 2:45 PM
    #169
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    its always better to have more power at lower RPMS. Nobody is High revving in traffic, most people are driving in 2k-4 k RPM range. Looking at dyno 1GR is way ahead of its time. Considerign thats a single VVT-i engine, you can only imagine what Dual VVT-i could do with 6 speed. Thats why probably Toyota gave Dual VVTi with 6 speed to Hilux. They wanted to leave the best for Hilux.
    Considering 2gr-fks is dual vvti engine it berely keeps up with older Tacoma engine. Its a difference between Truck engine and new Minivan engine.
    Soundwave likes this.
  10. Jan 19, 2016 at 2:45 PM
    #170
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    Just to be clear for all, the AT dyno is the shitty one I found and posted, not the (nice) MT dyno that OP did.
  11. Jan 19, 2016 at 2:46 PM
    #171
    jeff_taco_4x4
    jeff_taco_4x4 Well-Known Member
    jeff
    16' 4x4 Sport DCSB w JBL, MGM
    so, I paid for an expensive, under powered, under torqued, truck that Toyota lied to us about the facts???
  12. Jan 19, 2016 at 2:46 PM
    #172
    Aussiek2000
    2016 Offroad AC
    what the fuck are you talking about?
    forty2, Lawfarin and Daytona Coupe like this.
  13. Jan 19, 2016 at 2:47 PM
    #173
    Aussiek2000
    2016 Offroad AC
    advertised HP/TQ numbers are measured at the crank, not the wheels
  14. Jan 19, 2016 at 2:48 PM
    #174
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    correct, and tested on an engine dyno prior to installation
  15. Jan 19, 2016 at 2:49 PM
    #175
    jeff_taco_4x4
    jeff
    Toyota's literature says Hp is 278 but this dyno test says 232. Toyota literature says torque is 265 but this dyno test says 234. Just trying to digest all this. Seems bad news to me.
  16. Jan 19, 2016 at 2:50 PM
    #176
    AK Taco
    AK Taco Well-Known Member
    matt
    Anchorage, Ak
    chrome-free '99 sr5
    20% tint on all windows, Deckplate mod, satoshi-ish grille, blacked out and/or body matched emblems, rattle canned rims, red l.e.d. interior lights, bilstein 5100's and OME 881 coils , deaver 8 leaf pack, 1.5" lift shackle, alpine sound system, 55w HID lightforce 140 and 170 fogs
    Those are at the crank, not the wheels.
    Heepspo, Lawfarin and Aussiek2000 like this.
  17. Jan 19, 2016 at 2:50 PM
    #177
    tacitos
    16 TRDORDCLBJBL
    there is power loss between the crankshaft and the tire contact patch.. in this case we are seeing the power that is lost to the rear axle.
    Lawfarin likes this.
  18. Jan 19, 2016 at 2:50 PM
    #178
    Aussiek2000
    2016 Offroad AC
    its called parasitic loss. they don't measure HP/TQ at the wheels. A 4wd truck with a6 can expect to lose 20% of its power by the time it gets to the wheels
  19. Jan 19, 2016 at 2:52 PM
    #179
    jonnyozero3
    Dry places
    '99 TRD OR V6 M/T
    Jeff - what everyone is saying is that drop in numbers is to be expected. It happens to ALL vehicles when put on a dyno. The amount of loss from the crank (engine) to the wheels on the ground varies, but it is 100% normal.
  20. Jan 19, 2016 at 2:53 PM
    #180
    Daytona Coupe
    Daytona Coupe Well-Known Member
    Visalia CA
    16 TRD Sport DCSB
    A TRUE Aussie! Lol!
    Good on ya mate!
    Redbusket[OP] likes this.
