2016 Tacoma Foced Induction
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kev_, Aug 25, 2016.
  1. Aug 25, 2016 at 11:12 AM
    Kev_
    Kev_ [OP] Active Member
    Kevin
    16'Tacoma soon
    when will someone make an aftermarket forced induction kit? Love the truck but lacks power big time.
  2. Aug 25, 2016 at 11:12 AM
    Iamraiderpower
    Iamraiderpower Well-Known Member
    will not happen for a long time
  3. Aug 25, 2016 at 11:14 AM
    Kev_
    Kevin
    16'Tacoma soon
    That's what I figured.
  4. Aug 25, 2016 at 1:02 PM
    Dirty Harry
    Dirty Harry Well-Known Member
    Andrew
    SW Florida
    2021 Tacoma 2.7 SR 4x4
    The nature of the Atkinson cycle makes boost a very tricky project as the intake gases are vented with the opening of the intake valve. I'd love to see a little more power out of the engine for some scenarios too, but I'm not sure how reliable it would be to go forced induction on this 3.5.
    Garyji likes this.
  5. Aug 26, 2016 at 8:24 AM
    khamil4
    khamil4 Well-Known Member
    Kevin
    Evergreen, Colorado
    2017 Magnetic Gray Off Road Access Cab
    TJM Rock Crawler Front Bumper Smittybilt X2O 10,000 lb Winch KC Gravity® LED G34 Wide-40 Driving KC 6" Pro-Sport HID Distance TRD CAI Custom Built CatBack Exhaust SnugTop Rear Cap Spidertrax Wheel Spacers Old Man Emu BP51 Suspension Kit SPC Adjustable Upper Control Arms Yaesu FTM-400DR Radio
    Sorry for the newbie question, but is the US 3.5 the same motor and specs as the 3.5 in the Toyota Aurion in Australia?
  6. Aug 26, 2016 at 8:32 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    No. The engine in the Tacoma is the 2GR-FKS, while the engine in the Aurion is the 2GR-FZE...I believe.
    Edit: The FZE is a supercharged version of the 2GR-FE.
  7. Aug 26, 2016 at 8:46 AM
    Aussiek2000
    Aussiek2000 Well-Known Member
    2016 Offroad AC
    atkinson is used through the use of VVT. A retune would turn the engine back into otto cycle.
  8. Aug 26, 2016 at 8:58 AM
    khamil4
    Kevin
    Evergreen, Colorado
    Thanks for the clarification!!
  9. Aug 26, 2016 at 9:02 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    No problem...welcome to TW. I just noticed you are new here.
  10. Aug 26, 2016 at 11:49 AM
    Sheepshead45
    Sheepshead45 Well-Known Member
    NC
    PreRunner SR5
    Not sure why Toyota has refused to go turbo on anything yet; it's always seemed to me they could modestly boost the 2.7L 4cyl and create a 270hp torque MONSTER that would make the 6cyl completely unnecessary in the taco. Or boost a 6 to satisfy those that want 8 cyl power in a taco. Think of the possibilities!!
    Just 10 years ago turbos would have been considered heresy at BMW, who prided themselves with perfecting NA engines. Now you can't buy a NA BMW, and even the bottom of the model lineup has more power than anyone could have hoped for 10 years ago. Ford's turbo 6 for the F150 has more punch than the 8! Instead of throwing a bit of R&D, Toyota seems content to just move existing motors around. The "all new" taco 6 is a good example of the blah mediocrity that comes from such compromises.
    Ah well, maybe G4.
    specter208 likes this.
  11. Aug 26, 2016 at 12:03 PM
    forty2
    forty2 Well-Known Member
    Cascadia
    2016 DCSB OR 6MT
    That's right. The supercharged 2GR-FZE is also used in the Evora 400.
  12. Aug 26, 2016 at 12:15 PM
    Dirty Harry
    Andrew
    SW Florida
    Everything I have read about the new 3.5 eludes to Toyota just not seeing a whole lot of "real world" improvement in mpg's from turbo charging. They claim that although turbo charging looks good driving like a grandma, most people don't and their real world MPG as well as need for premium fuel due to the higher compression ratios ends up costing the customer annually and compromises reliability. I'd rather have a reliable power plant in my truck than a risky hot rod.
    YMMV
    sadmrhappy likes this.
  13. Aug 26, 2016 at 1:48 PM
    Sheepshead45
    NC
    PreRunner SR5
    Yeah, I agree that more often than not you will not see much improvement in fuel economy from turbocharging. The F150 with the 3.5(?) 6cyl turbo is not much different from the V8 for fuel consumption, but the acceleration, towing, and overall performance is better in the 6 turbo because it just has so much torque available. To my original point, the 2.7 4cyl could easily be tuned to beat the snot out of the new V6 in the taco. It would be lighter, have more torque, and I doubt that with modern turbo systems and design would be that much more costly to maintain than the V6. Premium fuel is normally only required in very high performance turbos. I doubt it would be required in a truck application. Combine with a designed to match state of the art 8 speed auto (they really are making some fantastic slush boxes these days, I hate to admit), and I bet the fuel economy could be better too if you drive in "eco" mode.
    Anyway just a thought.
  14. Aug 29, 2016 at 6:50 AM
    Dirty Harry
    Andrew
    SW Florida
    I would certainly be interested to see it happen! Especially with an 8 speed beast of a transmission.
