2016+ Tacoma Hidden Winch Mount
Discussion in 'SDHQ Offroad' started by SDHQ OFFROAD, Apr 5, 2017.
  1. Jan 12, 2018 at 8:38 PM
    #61
    Turd Hawg
    Turd Hawg Well-Known Member
    2018 DC SB OR AT (Sold)
    ok great, thanks for the info...was worried the warn fairlead wouldn't stick out past the bumper cover. I'm covering it anyway as it's law to have a front plate.
  2. Jan 13, 2018 at 7:31 PM
    #62
    TRD Pro SoCal
    TRD Pro SoCal Well-Known Member
    2017 Cement TRD Pro
    Would also like to see the close-up pics of license plate install!
  3. Jan 16, 2018 at 7:30 PM
    #63
    Turd Hawg
    I'm interested in that picture too. Would like to see it to decide whether or not to hide it behind the factory plate cover.
    Here is the real question though. I don't plan on lifting the truck or moving up in tire size. I would, however, like to retain the factory rake after the winch install. I received the winch tonight and I believe it to be heavy when coupled with the hidden winch mount. Am I going to need something in the front to keep it factory height? I want to keep it simple and as factory as possible as I believe it to be a capable truck without the lifting. I'm thinking 5100's set on the 2nd to lowest setting, would that keep the factory rake and ride quality of my OR?
  4. Jan 21, 2018 at 6:26 PM
    #64
    Turd Hawg
    Just finished mine, I'll get some pictures up tomorrow. Adding the hidden winch and the zeon platinum 10-s lowered my front end 1/2". The hidden winch install was painless, the 40 clips on the front of the truck were a different story, what a pain in the ass. I put on the flipster v2 as well, that required some extra cutting of the chin that'll show up in the pictures. Overall it went good and took about 6 hours. I have an email out to Marie to figure out my 1/2" drop, I'm hoping 5100's will do the job.
    A couple of notes
    • You'll need two 7/16-14 x 1.5" grade 5 bolts to replace the bolts that came with the winch to hold the hauss on if you are using the flipster, the warn comes with 1.25" bolts that are just a hair short.
    • You'll also need two 3/4" long by 1/4" stainless steel bolts, with 2 matching regular washers, 2 small fender washers, and two nylon locking nuts to attach the bumper skin to the "lower bumper bracket" that you install in step 12 of the SDHQ procedure, it says they were included but I didn't see them.
    MountainManGuy likes this.
  5. Jan 22, 2018 at 9:12 PM
    #65
    TRD Pro SoCal
    2017 Cement TRD Pro
    Really slick. Thank you for posting up the pics. Definitely leaning toward your install.
  6. Jan 22, 2018 at 9:26 PM
    #66
    JerryTaco
    JerryTaco Well-Known Member
    Nice work! Very clean install.
  7. Jan 31, 2018 at 12:21 PM
    #67
    FlapJack935
    FlapJack935 i member
    Jack
    Abq New Mexico
    Wannabe Trophy Truck
    Sick Gnar Trophy Truck Tacoma and King Ranch Raptor Killer
    can we use the cali raised slim led mount with this?
  8. Jan 31, 2018 at 12:23 PM
    #68
    JerryTaco
    Probably not. depends on the winch you choose but space is pretty limited once you get a winch back there
  9. Jan 31, 2018 at 1:37 PM
    #69
    SDHQ OFFROAD
    SDHQ OFFROAD [OP] Cuz Stock Sucks! Vendor
    SALES
    Gilbert AZ
    We have not done any test fitment with other than Baja and Rigid, but those did not fit with our winch mount.
    FlapJack935[QUOTED] likes this.
  10. Feb 16, 2018 at 8:27 PM
    #70
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Admittedly, I havent read all 4 pages of tis post, but Im curious if the D-ring attachments are accessible with an aftermarket (RCI in my case) skid plate. And do they get in the way at all?
  11. Feb 16, 2018 at 8:37 PM
    #71
    Metallikatz3
    Metallikatz3 Well-Known Member
    SLC, UT
    2017 DCLB OR
    Always in process
    It fits perfect with RCI skids. Still have access to the d rings!
    SDHQ OFFROAD[OP] likes this.
  12. Feb 21, 2018 at 10:51 AM
    #72
    RevivalOL
    RevivalOL Well-Known Member
    Pete
    Berkley, MI
    2017 TRD Off-Road DCLB
    Getting ready to install this over the weekend. Anyone install this with a Warn VR-series winch? Curious if the control box relocation is needed - the height on the VR is 0.75" shorter than a Zeon.
    SDHQ OFFROAD[OP] and COdude3 like this.
  13. Feb 21, 2018 at 4:49 PM
    #73
    RevivalOL
    Pete
    Berkley, MI
    Ordered the relocate bracket just to be safe. @SDHQ OFFROAD - I’ll post up when done so you know for sure how the VR series winches fit.
    COdude3 likes this.
  14. Feb 21, 2018 at 5:34 PM
    #74
    COdude3
    COdude3 Well-Known Member
    Colorado
    2017 SR5 Access Cab 4x4
    Pro Grille, Pro Whls, King Shocks, 265/75R16 A/T3
    Thanks! I'm thinking of going the same route. I'll be interested to know if you had to drill new mounting holes for the VR winch.
  15. Feb 21, 2018 at 5:57 PM
    #75
    RevivalOL
    Pete
    Berkley, MI
    The mounting holes for the winch itself line up fine (exact same as the Zeon). Question will be how the control box fits in there as it’s actually smaller in the VR than on the Zeon.
  16. Feb 24, 2018 at 4:47 AM
    #76
    COdude3
    Colorado
    Good luck with the install. I'll be curious to how it goes.
  17. Mar 2, 2018 at 6:09 PM
    #77
    WV Outdoorsman
    WV Outdoorsman Well-Known Member
    Lewis
    2017 Tacoma sport
  18. Mar 5, 2018 at 11:07 AM
    #78
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    Which VR did you go with? I'm considering the VR8-S.
  19. Mar 9, 2018 at 6:22 AM
    #79
    RevivalOL
    Pete
    Berkley, MI
    I have the VR8-S. Still haven’t done the install yet. I did get the control box relocation kit from SDHQ. The holes in that bracket do not match my winch, but I drilled two holes and it fits fine. Install will be next weekend.
    savethewheels[QUOTED] likes this.
  20. Mar 9, 2018 at 6:31 AM
    #80
    jlusmc
    jlusmc Well-Known Member
    James
    Huntsville, TX
    97 Reg Cab SAS
    Finished the SDHQ Hidden winch mount install with a Warn M8000-s. I didn't do a full write up but here are some pic's from the install. SDHQ instructions are quite easy to follow and their online video is even better but both only cover Warn Zeon Winches and I went with an M8000-s instead. As a result I focused on the control pack mounting images since I had to make that up as I went. The M8000 doesn't require the cutting of the center support like SDHQ calls for (Zeon winches are taller and hit the brace).
    [​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
