2016+ Tacoma Hidden Winch Mount
Discussion in 'SDHQ Offroad' started by SDHQ OFFROAD, Apr 5, 2017.
  1. Jan 4, 2022 at 11:50 PM
    #121
    Tacomavkk
    Tacomavkk Well-Known Member
    Woodinville, WA
    2018 TRD Off-road DCSB Quicksand
    Thanks! Did you have to do any cutting?
  2. Jan 5, 2022 at 6:00 AM
    #122
    COdude3
    COdude3 Well-Known Member
    Colorado
    2017 SR5 Access Cab 4x4
    Pro Grille, Pro Whls, King Shocks, 265/75R16 A/T3
    When I put the bumper back on, I had to trim a little plastic to clear the top of winch.
    Tacomavkk likes this.
  3. Apr 10, 2022 at 8:46 PM
    #123
    rka
    rka PAVEMENT PRINCESS
    Rylan
    H A W A I I
    2013 SPORT DCLB
    100% Stock
  4. May 16, 2022 at 10:19 AM
    #124
    awwbugman
    awwbugman Well-Known Member
    Kings/Deavers/SPCs 35x10.5 Kendas, LRA FuelTank, WARN Zeon10s SDHQ mount, Switch Pro, LightForce rock lights, reverse light & Lightbar, Baja Design Squadron Pro fogs, CaliRaised Sliders, RLD Canopy, Odyssey group 31, Dometic CFX3-55IM
    You could definitely bolt it on, however due to the winch mount being set in to the bumper, you might not be able to wrap the line around the edges unless you clearance a decent amount more of the black plastic bumper out which might not look too great imho.
  5. May 10, 2023 at 3:05 PM
    #125
    Bakwoodz
    Bakwoodz Member
    SW Idaho
    2022 SR5 Crew Cab Long Bed
    SDHQ Hidden winch mount Warn VR EVO 10 Winch SDHQ Built A-Pillar Light Mounts Baja Designs Squadron Sport LED ditch lights Baja Designs Squadron Sport Fog Baja Designs 30" S8 LED Light Bar Expedition essentials switch pro panel bracket Switch-pro 9100 OTT tune by Taco Vinyl
    I know I'm reviving an older thread here but will the 30" S8 baja designs lightbar mount kit from @SDHQ work with this winch mount? I ordered the VR EVO 10 winch and I'm worried that I won't be able to have both in since the light would essentially occupy the same space as the clutch
  6. May 11, 2023 at 11:17 AM
    #126
    awwbugman
    You're correct, you cannot use the lower light bar mounts because it will interfere with the winch. SDHQ makes a behind the grill mount that can fit a 30" and also a lower bar or two seperate bars depending on if you have then sensor or not. A side benefit is that light performs better the higher up in the front you can get it (casting less shadows on rocks/objects). https://sdhqoffroad.com/products/16...lt-behind-the-grille-dual-led-bar-light-mount
    A few pics of my setup for reference:
    Bakwoodz[QUOTED] likes this.
  7. May 11, 2023 at 11:34 AM
    #127
    Bakwoodz
    Bakwoodz Member
    SW Idaho
    I ended up getting ahold of @SDHQ and I was told I will be able to install both the light and my winch together. The only difference is I will have to reach through a different way to engage or disengage the clutch. Not a big deal to me since I don't have to use the winch a bunch. I guess I will find out come install time
  8. May 15, 2023 at 7:31 PM
    #128
    Bakwoodz
    Bakwoodz Member
    SW Idaho
    Is there a decent install video on this? All I've found is the short 1.5min video that has a quick time-lapse
