2016 Tacoma no throttle, check engine light on, trac off light on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pioneer59, Jul 2, 2020.
  1. Aug 9, 2020 at 7:11 PM
    Chuck X1
    Chuck X1 Well-Known Member
    Chuck
    NW Indiana
    2020 Tacoma TRD Off Road
    So far they have changed out both the high and low pressure fuel pumps. It’s still in the shop now. Their only comment is that they are working with Toyota corporate to fix the problem. I have a separate thread on this forum dedicated to my problem.
  2. Aug 9, 2020 at 7:13 PM
    Chuck X1
    Chuck
    NW Indiana
    I’m in northwest Indiana, right below Lake Michigan. I’ve only had the truck since May 2020, just three months. It’s been in the shop four times, over 30 days total. I had a 1998 Honda Civic once with a similar problem. It turned out to be a bad solder joint on the fuel pump cutoff relay. Whenever the joint heated up, the connection was lost and the car stalled. When it cooled down, contact was made again. There’s a website out there dedicated to this problem. My guess is Toyota is having a similar problem but can’t figure it out yet or hasn’t communicated it yet
  3. Aug 9, 2020 at 7:44 PM
    pioneer59
    pioneer59 [OP] Active Member
    GREG
    Pioneertown, Ca
    2020 Tacoma TRD Off Road 4x4
    Add a leaf to springs at Deaver Springs Santa Ana.
    I believe you may be right, a bad soldier joint. My lack of trust on this 2016 is what made me go get a new 2020. I thought about your issues before buying but I love Tacomas and have had several over the years, always superior performers. My wife's 2009 Tacoma TRD OFF ROAD 4X4 has over 318k miles. She won't give it up.
    I read your thread, similar issues but different. My always idles fine, it goes into limp mode, just can't climb hills in limb mode.
    AthensTac likes this.
  4. Aug 10, 2020 at 12:27 AM
    92ehatch
    92ehatch Well-Known Member
    Kinley
    Hendersonville NC
    2019 Cavalry Blue DC TRD OR 6MT
    I've resoldered a bunch of those. Plagued hondas all the way to 2000.
  5. Aug 10, 2020 at 7:07 AM
    WVTacoma08
    WVTacoma08 Well-Known Member
    West Virginia
    '20 TRD PRO Super White
    Same issues in a 2018 I had.....Luckily enough it was still under warranty so it was lemmoned and Toyota repurchased
  6. Aug 10, 2020 at 7:11 AM
    WVTacoma08
    West Virginia
    Keep service records. If after 3 unsuccessful attempts to fix they will Lemon it and Toyota will repurchase. It is a long-drawn out process though. I had same exact issues in my 2018 and that was the result
    Chuck X1[QUOTED] likes this.
  7. Aug 10, 2020 at 8:29 AM
    Chuck X1
    Chuck
    NW Indiana
    Thanks. This my fourth trip to the dealer. It’s been in the shop 31 days now and I haven’t even owned it 90 days. It’s still in the shop even now. The last time I broke down a local Toyota service advisor gave me a ride back while I waited to get towed. I’m glad he came because it didn’t start for him, either. Will keep everyone updates regardless of what happens.
  8. Aug 10, 2020 at 8:35 AM
    WVTacoma08
    West Virginia
    My case was identical and was in on 4 separate occasions. Was in loaner more than my truck. Hopefully you've contacted corporate and have the process started.
  9. Aug 10, 2020 at 2:05 PM
    Chuck X1
    Chuck
    NW Indiana
    Update..the dealer just replaced both the high and low pressure fuel pumps AGAIN. They are now keeping it for a week to drive it around and verify it’s fixed. I contacted corporate and they will get back with me on Wednesday regarding next steps. Six fuel pumps in three months?!? (Original+Set 1 + Set 2)
  10. Aug 10, 2020 at 5:25 PM
    WVTacoma08
    West Virginia
    identical situation. They kept mine for a week the final time after replacing fuel pumps for the 2nd time as well and I kid you not I got 2miles out and happend for the 4th and final time. They towed it back to dealership and that was final time I drove it
  11. Aug 10, 2020 at 5:35 PM
    Chuck X1
    Chuck
    NW Indiana
    Wow. So you know how frustrating and dangerous it is. What year was your Tacoma?
    WVTacoma08[QUOTED] likes this.
  12. Aug 10, 2020 at 7:55 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    but you got over 4 years and 124k on it, so not too bad unless you had other major issues..
  13. Aug 11, 2020 at 4:53 AM
    WVTacoma08
    West Virginia
    2018 with less than 12K miles
  14. Sep 8, 2021 at 6:06 PM
    TOY515
    TOY515 Member
    Reviving this old thread....I just purchased a 2016 and on my 3rd day of ownership, this has happened...checking to see if there is a fix yet...thanks in advance for any help...
  15. Sep 8, 2021 at 9:29 PM
    #35
    Chuck X1
    Chuck
    NW Indiana
    After four trips to the shop and change outs of the high and low pressure fuel pumps the problem was a loose wire in the fuse box. No problems since the loose wire in the fuse box was found. You might want to give the wiring harness a gentle push and make sure everything is seated correctly.
    TOY515 and Kev250R like this.
  16. Sep 9, 2021 at 5:48 PM
    #36
    TOY515
    TOY515 Member
    Added Notes:
    Trac Off light and Check Engine light are on at start up. While driving, at 30mph, the Trac Off light will shut off, Check Engine light remains on. Trac Off light comes back on when speed is below 30mph....
  17. Sep 11, 2021 at 2:40 PM
    #37
    TOY515
    TOY515 Member
    Update:
    I have now used about a half tank of gas and all lights have shut off...
  18. Sep 20, 2021 at 7:34 AM
    #38
    2021TacoTruck
    2021TacoTruck Active Member
    Erik
    Mesa, AZ
    2021 TRD Off-Road 4x4
    RC Vertex 3” adjustable c/o’s w/ resis, RC UCA’s and RC 2.5 adjustable rears w/ resis. TRD Pro Black wheels wrapped in 285/75 R16 BFG AT’s. Nitro 4.88’s KD Max tune
    Thanks for this post and PM about the solution.
    I removed the engine bay junction box (Fuse and Relay Box) but never found a loose wire, or anything out of place. I’m curious if anyone else attempted this repair/inspection. Further, if anyone found anything, did you snap some pics? So far, this has happened twice and both times I was able to disconnect the neg battery terminal to get up and running. I’m hoping we can collectively solve this.
    Thanks in advance!
  19. Sep 20, 2021 at 11:42 AM
    #39
    TOY515
    TOY515 Member
    Code that is being displayed is
    P107A2A
  20. Sep 20, 2021 at 12:49 PM
    #40
    TOY515
    TOY515 Member
    P107A2A Fuel Rail Pressure Sensor (Low) / Fuel Rail Pressure Sensor "B" Signal Stuck in Range
    Called local Toyota dealership. No known issue with my make/model.
    The small dealership I bought it from will not cover the cost of diagnosis and repair.
