2016 Tacoma or not?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Theheisman19, Jan 17, 2016.
  1. Jan 17, 2016 at 10:21 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Im glad I dont has to highway drive...... would a cold start with no warmup getting onto a highway be bad for the blower? @Torspd @Lucario Runner
  2. Jan 17, 2016 at 10:22 PM
    HAVVOKK
    HAVVOKK Well-Known Member
    2014 DGAF Long Bed
    Fucking look it up
    To warm them up faster I heard pissing on the new 3.4 motor warms it up alot faster
  3. Jan 17, 2016 at 10:24 PM
    Invid
    Invid Well-Known Member
    New Braunfels, Texas
    2016 Tacoma Limited
    I came from a 2002 Tundra Access Cab and in fourteen years I never had to take it in for anything. The truck was absolutely bulletproof. So far, six weeks in, I love my 2016 Tacoma DC Limited and I expect similar reliability.
    As for warming up you don't need to do that but it's recommended you let it idle for sixty seconds to allow the oil circulate through the engine. I could care less about the heater since I have heated seats and they heat up rather quickly :D
    JimJustJim likes this.
  4. Jan 17, 2016 at 10:26 PM
    JimJustJim
    JimJustJim Well-Known Member
    James
    San Antonio, TX
    Super White 2016 DC TRD OR
    Voodoo doll hanging from mirror, Dog Blanket, SR Grille, TRD Badge, Installed factory LED bed lights, Duct-taped Ocarina holes in upper control arm, Predator step, Tacoma bed mat, Softopper, TJM front bumper.
    Well rub it in, already :C
    On cold days when I don't warm it up, I sure do wish I had those heated seats.
  5. Jan 17, 2016 at 10:26 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    is that like an engine?
  6. Jan 17, 2016 at 10:44 PM
    Theheisman19
    Theheisman19 [OP] Member
    Hunter
    Excuse my dumb questions, but does the atkinson engine make it so you cant accelerate faster or go faster for that matter? or can you install after market exhaust systems and intakes to improve Hp and help the acceleration and speed?
  7. Jan 17, 2016 at 10:53 PM
    Theheisman19
    Hunter
    Thats sort of disappointing :/ but ill give it a long test drive before i decide, if i dont like it ill probably get a 15 tacoma.
    JimJustJim and Justus like this.
  8. Jan 17, 2016 at 10:56 PM
    JimJustJim
    James
    San Antonio, TX
    Nah. The "Atkinson Cycle" feature on the new taco is just basically an adjustment to valve cycles. I'm pretty sure all the standard performance mods apply, as the atkinson cycle bit doesn't even come into play until the engine isn't being taxed, like if you're cruising.
  9. Jan 18, 2016 at 7:43 AM
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    The Atkinson stuff is all a gimmick. I mean I am sure it uses a real Atkinson cycle and helps MPG marginally but obviously non-Atkinson motors are getting better MPG than the Tacoma out there.
  10. Jan 18, 2016 at 10:51 AM
    JimJustJim
    James
    San Antonio, TX
    This. The reality is, it's not even a true Atkinson Cycle, all it does is mess with the valve timing to adjust the size of the detonation in the cylinder in the spirit of the mechanical crankshaft Mr Atkinson designed back in 1882.
    It's really no different than the variable displacement hullabaloo brought on when Cadillac introduced their V8-6-4 engine. Of course I think that Toyota got it right with a simple adjustment of strokes. *at least I hope so*
  11. Jan 18, 2016 at 11:39 AM
    BKill
    BKill AKA Threadkiller
    Bill
    College Station, TX
    2013 Tacoma PreRunner
    Now how do you figure that? The Cadillac disabled cylinders in an attempt to save fuel, which the Tacoma does not do.
  12. Jan 18, 2016 at 11:54 AM
    JimJustJim
    James
    San Antonio, TX
    I'm comparing apples to oranges here. I'm not trying to say that they are the same technology. I'm trying to say that the "hullabaloo" is the same. The gimmick of cutting power to save fuel has been around for a while and the two technologies are sort of cut from the same cloth.
    The caddy killed cylinders to lower displacement to save fuel.
    The taco decreases the stroke to save fuel. All cylinders are used, but smaller detonations.
    The point is, it's a thought process that's been around forever, and Toyota's employment of the Atkinson inspired stroke appears to be a far better application of that school of thought. So far.
  13. Jan 18, 2016 at 12:04 PM
    BKill
    Bill
    College Station, TX
    Well...okay, then.
  14. Jan 18, 2016 at 12:05 PM
    JimJustJim
    James
    San Antonio, TX
    Your alias makes me nervous.
  15. Jan 18, 2016 at 12:07 PM
    #35
    BKill
    Bill
    College Station, TX
    If you take the 2nd letter and put it at the end, it should make you feel better.
  16. Jan 18, 2016 at 4:03 PM
    #36
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Taking it easy until everything is up to temp, is preferred.
  17. Jan 18, 2016 at 4:04 PM
    #37
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    thnx buddy.
