2016 Tacoma TRD cam position sensor oil leak!!??
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Sosk, Aug 25, 2016.
  1. Oct 13, 2016 at 5:58 PM
    #41
    tacoflavoredkisses1
    tacoflavoredkisses1 Well-Known Member
    16 TRDOR DCSB (SOLD)
    L O L. You took your truck back with that BS response? I would have left it.
  2. Oct 13, 2016 at 9:56 PM
    #42
    Sosk
    Sosk [OP] Well-Known Member
    Evan
    Vancouver Canada
    2018 TRD Sport
    Are you sure of this? I'm still not experiencing any issues 2900kms after valve cover replacement. Could it be temporary? and would said "pinhole leak" cause other issues internally with out leaking from the sensor?
  3. Oct 14, 2016 at 6:43 AM
    #43
    Badchicken
    Badchicken Toyota Master Tech
    Yes I'm sure. Thread lock on the cam sensor bolts prevent this from happening too but it may only be a temporary fix. If oil was coming from the cam sensor, a valve cover gasket will not fix it. They probably put thread lock on the bolt at the same time.
  4. Oct 14, 2016 at 7:20 AM
    #44
    Sosk
    Evan
    Vancouver Canada
    2018 TRD Sport
    Well for now they replaced the valve cover and gasket as wel as a new sensor. So well see.
    Are you a tech or is this from your own experience with this?
    Evan
  5. Oct 14, 2016 at 7:57 AM
    #45
    Badchicken
    I'm a tech
  6. Oct 14, 2016 at 4:26 PM
    #46
    Rein
    Rein Well-Known Member
    Cole
    San Diego
    2017 TRD Offroad DCLB
    Suspension, racks, tune, bed, lights. See build thread.
    Dropped my truck off for the second time in a month for leaking at the left side cam shaft sensor. Service called me today and told me Toyota knows of the issue and is recommending them to replace a cam shaft sensor cradle. Apparently there are 20 something on order in the US and Im on the list at #5.
  7. Oct 15, 2016 at 8:56 AM
    #47
    Bassfever71
    Bassfever71 Well-Known Member
    New Jersey
    2019 Cement Tacoma TRD DCSport
    Are all 2016's leaking? How about the ones that are not what is the difference with those?
  8. Oct 15, 2016 at 9:00 AM
    #48
    Bassfever71
    New Jersey
    Got mine back on Thursday morning but haven't driven it much just errands around town and mine is bone dry,we'll see on my commute to work that's when I noticed it last time.Ran into a tech yesterday and explained my problem and he said it's a 3 step process to fix it,cam sensor first then thread lock bolts second and final fix is replace cam journal and valve cover.Well see how long before I'm back
  9. Oct 15, 2016 at 9:41 AM
    #49
    Badchicken
    It was just a casting problem with some of the early 16s at least it seems.
  10. Oct 15, 2016 at 12:52 PM
    #50
    JJJZJ
    JJJZJ New Member
    2016 dclb trd
    Mine has been smelling like oil gas been burning since the first miles, found this thread and dropped her off Thursday. 3 hr turnaround with a new sensor and within 30 miles had more oil leaking.
    I called the service manager and she was quite apologetic and willing to listen to information gleaned from this thread and she said she would order the parts listed somewhere in here.
    Dropped her again this morning and was given a loaner and now just waiting to see if they go for the bandaid fix or go for the home run...fingers crossed!
  11. Oct 15, 2016 at 7:38 PM
    #51
    Bassfever71
    New Jersey
    Used it most of the day today even got on it a few times and it's bone dry for now,keeping my fingers crossed
  12. Oct 15, 2016 at 7:41 PM
    #52
    Bassfever71
    New Jersey
    Hey it was a 5.00 o-ring that blew up the space shuttle maybe it's a 75 cent tube of lock tite holding my oil in for now,only time will tell
  13. Oct 17, 2016 at 12:08 PM
    #53
    MaxZorin
    MaxZorin Member
    Indiana
    2016 TRD OR AC
    I've had this problem for a while on my 2016. After long haul highway trips I've noticed an extremely slow oil leak and film of oil developing below only one of the cam position sensors on driver's side bank. Already brought it to Toyota's attention twice and they haven't done anything to mitigate it but put a tracer dye in and tell me at a follow up appointment that it wasn't a problem. Eventually when I have more time and get annoyed enough by it I'll actually grill them on it. Hopefully Toyota hashes out a complete fix for this and actually contacts owners about it.
  14. Oct 17, 2016 at 4:47 PM
    #54
    Rein
    Cole
    San Diego
    The tech told me today that Toyota has put out a fix for it. Involves replacing the Cam Cradle, and the tech made it sound like it was a bit of work. Not happy with having my brand new engine disassembled after a month of use. Going to see about extending my warranty since its never a good thing to break all the factory seals at 900 miles.
  15. Oct 17, 2016 at 5:32 PM
    #55
    MaxZorin
    MaxZorin Member
    Indiana
    2016 TRD OR AC
    Rein, thanks for the info. Would you guys recommend I just call Toyota corporate directly and get them to force my dealer to replace the cam cradle and all?
  16. Oct 17, 2016 at 6:18 PM
    #56
    Rein
    Cole
    San Diego
    I called corporate after the initial fix failed and started leaking oil again just so I can get a case number (success) and attempt to get a truck rental, which failed. Going to have to go back tomorrow to turn in my rental truck for a Camry...
  17. Oct 18, 2016 at 8:33 AM
    #57
    MaxZorin
    MaxZorin Member
    Indiana
    2016 TRD OR AC
    Man that blows. Hopefully they finally fix it. Makes me wonder if we're gonna see this at other cam position sensors or if it is just this driver's side casting for the cam cradle that is messed up. I'm also apprehensive about tearing open my engine with barely 15k on the clock. Is there a TSB out for this yet?
  18. Oct 18, 2016 at 10:43 AM
    #58
    JJJZJ
    JJJZJ New Member
    2016 dclb trd
    I called the dealer today and they said they are replacing the valve cover and the plenum underneath it. I asked the ASM about any cam cradle fix information and he stated he didnt know of anything. I also called corporate and described the problem and they were not able to find anything in their system about the cam shaft oil leak either. I guess I will pick it up tomorrow and keep an eye on the engine and this thread for any applicable information. I did get a case number and the rep said she would let me know if anything comes down from their end.
    Those of you that have heard Toyota has a fix, do you have any paperwork or information to bring to the dealer or is it just word of mouth at this point?
  19. Oct 19, 2016 at 10:34 PM
    #59
    LePetomane
    LePetomane Active Member
    Rick
    Spokane WA.
    08 Sport 4X4
    I am still waiting on parts, and they are replacing the cam cradle on mine, I was told it should be in on the first of November and will take 2 or 3 days to complete. Since BadChicken is a Master Tech, answer me this; Is this the fix it forever "fix" for this, or is this just another shot in the dark on a design flaw that they are not quite sure yet what to do about? As far as a bit of oil sweating is concerned...., I am sorry, but that is unacceptable on a brand new engine. Do you think a Lexus owner would accept that?, I sure don't. And why did they design an engine in this way, where it is so very touchy where leaks are concerned.
    This will be my 3rd time in the shop for this one thing, and if they don't fix it for good, I will be calling corporate and having a good old fashioned parlay, as I have to assume that the corporate FST knows full well what is going on, as this is what my dealership told me, so if that is the case, then the corporate front office had better know.
    If they get a whiff of lemon law cake, it might rattle their memories. This is getting old real quick.
    Rein likes this.
  20. Oct 20, 2016 at 8:24 AM
    #60
    Rein
    Cole
    San Diego
    Jesus first of November? My Tech told me "hopefully" this week he could get the part. How long has your vehicle been at the dealer?
