2016 Tacoma Wiring Diagram
Discussion in '3rd Gen. Tacomas (2016+)' started by Dillypoop, Feb 14, 2018.
  1. Feb 14, 2018 at 8:46 AM
    Dillypoop
    Dillypoop [OP] Well-Known Member
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    Does anyone have a wiring diagram for the '16 Tacomas? Trying to track down an electrical issue. Overhead console lights come on when I turn on the wipers every now and then.
  2. Feb 14, 2018 at 10:00 AM
    gator2764
    gator2764 Well-Known Member
    Mid Ga
    2016 TRD DCLB 4X
    Are you out of warranty?
  3. Feb 14, 2018 at 10:20 AM
    Dillypoop
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    No. But I'm the second owner and the PO did some wiring and i'm trying to track down what he did and see if that's part of the problem.
    This is how he spliced a hard wired GoPro line into the moonroof power. Who just zip ties the wires together?? it's not hard to splice it correctly..
  4. Feb 14, 2018 at 11:04 AM
    Captqc
    Captqc Well-Known Member
    Tigard, OR
    2017 Tacoma 4x4 TRD AC Off Road
    Disconnect that and see if your problem goes away before you do anything else. I've got the wiring diagrams on my home PC so if nobody replies before tonight I'll find it for you.
  5. Feb 14, 2018 at 11:48 AM
    Dillypoop
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    That'd be awesome if you could do that.
    Thinking through it, I'm not sure why this would cause the switch to be over-ridden. The PO said he got power from the moon-roof which I'm guessing meant that he just found a hot wire (which may happen to be the overhead lights?) and ghetto spliced into it.
    hazey likes this.
  6. Feb 14, 2018 at 12:00 PM
    MVMike
    MVMike Well-Known Member
    2016 White Tacoma TRD OffRoad Double Cab
    That splice photo is classic. Unbelievable. Not even a stitch of insulating tape. What else did he jury-rig on that truck?
    daddy_o likes this.
  7. Feb 14, 2018 at 12:04 PM
    VangaSTL
    VangaSTL Well-Known Member
    Garrick
    St. Louis, MO
    2016 TRD Sport 4x4
    :eek::eek::eek::eek::annoyed:
  8. Feb 14, 2018 at 12:06 PM
    Dillypoop
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    It looks like it's going to rain this weekend so I'm taking the time off enduro to check that out... Can't wait to find what else!
    He said he got a friend to do that for him. I think the rest of the stuff he did himself (really just wiring lights and a CB radio; the usual bro stuff) so I'll have to look and see what the deal is. He makes it look really clean on the outside but the wiring on the inside is a different story.
  9. Feb 14, 2018 at 1:30 PM
    Optimaltaco
    Optimaltaco Well-Known Member
    Dave
    Cochrane, AB
    '17 Tacoma DCSB TRD Off-Road
    TRD Pro - Grill and Rear Tail-Lights OEM Roof Rack FN overland 17x8.5” -6 BFG KO2 Morimoto 2 stroke LED headlights 30” auxbeam light bar Custom built Canopy Readylift 3" spacer kit Deaver 1.5-2" AAL Amber hazard strobe lighting
    :eek: :eek: I have seen some really dumb installs before... but that is up there with using duct tape to insulate a connection.
  10. Feb 14, 2018 at 1:34 PM
    Dillypoop
    Dillon
    Killeen, Texas
    2016 Tacoma TRD OR
    Apparently it's not as uncommon as you'd think. I talked to my boss about it (since he headed the electronics on an Indy car team) and he said he's seen it a lot..
  11. Feb 14, 2018 at 2:08 PM
    Optimaltaco
    Dave
    Cochrane, AB
    That's Crazy! I am a 12-V installer (now Manager) and have never seen that before...but there is a first for everything hahah
  12. Feb 14, 2018 at 2:28 PM
    splitbolt
    splitbolt Well-Known Member
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
  13. Aug 19, 2018 at 7:26 PM
    JohnDeere55
    JohnDeere55 Member
    Sandown, NH
    2018 Tacoma Limited Double Cab
    AR914 20x8.5 wheels, Toyo 285/50/20 Proxes S/T, Westin 3" bars, PowerBass speakers
    Exactly what I've spent countless hours searching for … Thanks !
  14. Dec 23, 2018 at 11:01 PM
    wfaraoni
    wfaraoni Member
    2019 tacoma sr
    Thank you for the files
  15. Apr 1, 2019 at 3:49 AM
    Tullie D
    Tullie D Well-Known Member
    Tullie
    Wilson, NC
    2019 SR5 V6 SSM Access Cab
  16. Apr 1, 2019 at 4:28 AM
    splitbolt
    NW Arkansas
  17. Apr 1, 2019 at 5:25 AM
    Tullie D
    Tullie
    Wilson, NC
    Thanks. I'll check 'em out. :thumbsup:
  18. Jun 2, 2019 at 3:30 PM
    lussier1985
    lussier1985 New Member
    jonathan
    Tullie D and splitbolt like this.
  19. Jun 12, 2019 at 3:48 PM
    lussier1985
    jonathan
    anyone knows wich is the wire for the start at the ignition switch with the wireless key? i dont find anything
  20. Mar 20, 2020 at 4:24 PM
    RetiredRedneck
    RetiredRedneck Well-Known Member
    Bruce
    Port Moody, BC
    2018 TRD Off-Road - The Grey Ghost
    Toyota Roof Rails/Rack Toyota front Skid Plate BAKflip Hard Tonneau Cover iBoard Running Boards AVS Hood bug/rock deflector AVS Window Rain Gutters Amazon Centre Console Tray Larsen 2m/70cm antenna QYT VHF/UHF Mobile Radio Auxting LED Reverse Lights Taco Garage DMM with RAM bits-n-pieces Toyota OEM Bed Mat Interior LED Light upgrade - SuperBrightLEDS.com Pop-n-Lock OG Fabrication Centre Console Molle Panels Decals and badges removed CaliRaisedLED Amber Fogs, Ditch Lights and bumper Light Bar MESO Switch Panels AirOnBoard Switches Home Brew Auxiliary Electrics Panel
