2016 Tacoma wont start
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joey42655, Oct 19, 2022.
  1. Oct 20, 2022 at 7:15 AM
    Joey42655
    Joey42655 [OP] Member
    2016 Tacoma Limited
    But this is after the fact of all the other problems it’s been giving me. Put a tester on the battery and it’s fine.
  2. Oct 20, 2022 at 7:15 AM
    Joey42655
    2016 Tacoma Limited
    No it won’t
  3. Oct 20, 2022 at 7:16 AM
    Joey42655
    2016 Tacoma Limited
    The battery is fine, connection is good, wires to and from the battery are good. It’s not the battery.
  4. Oct 20, 2022 at 7:20 AM
    LunarTeal
    LunarTeal Rarely interested....
    Smells like a bad alternator - voltage at battery dropping while running - giving low power/stall/death. Click and no start.
    Just 2 days ago - car will light up, click and no start. Battery's "fine" on tester but not enough cranking amps. New battery - it cooks off just fine. Starts.
    DES2009 likes this.
  5. Oct 20, 2022 at 7:29 AM
    avi8or_co
    avi8or_co Well-Known Member
    2022 Lunar Rock TRD Sport
    Not saying yours is covered by the recall, matter of fact pretty sure the 16 wasn’t. All I’m saying is that based on the symptoms you are describing they mirror exactly what mine was doing when the fuel pump began to fail. It was quite obvious what was going on as soon as I got it home and plugged in my basic scan tool. It had multiple misfires along with a low fuel pressure code. I’d hook up a scan tool to it and see what it’s trying to tell you but I have a feeling I know what you are going to find.
    Mine was replaced by the recall and now has been fine since. You may be on the hook for another fuel pump but it may solve your problem pending some simple diagnosing.
  6. Oct 20, 2022 at 7:42 AM
    MGMoverland
    MGMoverland Well-Known Member
    Brad
    Golden, CO
    22 Tacoma TRD 4x4 Offroad
    Full RCI Armor/Sliders, Bilstein 6110/5160 w/Deaver stage 3 leaf pack, Method 703 titanium wheels, BFgoodrich KM3 265/70/16, BD Sport Amber fogs, OEM LED HL, Meso 1st stage Tail conversion, Anytime front camera, EE accessory dash mount, Alu-Cab Contour canopy, Alu-cab ammo box slide, Alu-cab fridge slide, Alu-cab large cupboard, Alu-cab gen 3 tent, Goose gear deck plate, ARB twin compressor w/DDI under seat mount, Yaesu FTM 400XDR ham radio, Snomaster 72 classic fridge freezer, Battleborn 100AH lithium house battery, Front Runner 17.7 gallon onboard water.
    What about the connection at the starter? Starter having issues?
  7. Oct 20, 2022 at 7:48 AM
    Hooper89
    Hooper89 Well-Known Member
    2016 White TRD Sport
    Yeah when my 3rd brake light was leaking they told me it wasn't on the recall, then later on it was on the recall, take it to the dealer and raise hell for the camshaft and fuel pump recall work.
  8. Oct 20, 2022 at 7:53 AM
    Clearwater Bill
    Billy
    Largo Florida
    Is your key fob battery dead?
    I think you are describing 2 problems. Your original running issue, now a no start issue.
    A bad fuel pump or crank sensor would not stop the engine from turning over.
  9. Oct 20, 2022 at 7:57 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    The ECU would need to have at least a pending code for something related to no start. You need a better mechanic.
  10. Oct 20, 2022 at 8:08 AM
    Hooper89
    Another thing I just thought of is a loose or bad ground wire/blown fuse.
  11. Oct 20, 2022 at 11:35 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    I don't think 2016 or 2017 were part of the fuel pump recall.
  12. Oct 21, 2022 at 8:39 AM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Has the OP disappeared? :anonymous:
    Do you think a new battery fixed it? :burp:
  13. Oct 21, 2022 at 9:04 AM
    Hooper89
    I don't see a battery causing it to die at intersections.
    Maybe he found out he needed an alternator?
  14. Oct 21, 2022 at 9:11 AM
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Right. But it seems like he has two separate issues... the battery likely being one of them.
  15. Nov 30, 2022 at 3:12 PM
    #35
    Clearwater Bill
    Billy
    Largo Florida
    Hasn't been on since Oct 20, so over a month.
    Really disappointing when we don't learn resolution to the issues folks bring to the table. We just keep waiting and waiting, trying to learn new things...............
    DES2009[QUOTED] likes this.
  16. Nov 30, 2022 at 6:29 PM
    #36
    DES2009
    Southeast Louisiana
    2017 MGM Limited
    Yeah he joined on the 19th to ask his question. :help: Probably learned that he needed a new battery. Vanished into the ether on the 20th, never to be seen again . . . :curls:
    shakerhood likes this.
