2016+ Toyota Tacoma OVTUNE 1.05 - Tune Development thread
Discussion in '3rd Gen. Tacomas (2016+)' started by OVTune, Jun 9, 2017.
  1. Apr 25, 2019 at 3:22 PM
    Venator_2033
    Venator_2033 Well-Known Member
    4" inch lift Dakar leafpacks/Bilstein 5100 B110/Fox 2.0 coil-overs/Catless Dual Exhaust w/H-pipe/OVtuned1.05/RCI Sliders/HID kits Hi/Low/AFE Intake with scoop and 76mm throttle body/Total chaos Fab UCA's
    In the drop down menu for selecting which J2534 device tool you need to select open port 2.0 which is your tactrix adapter and then should be good to go.
    lapoltba and PhogDog like this.
  2. Apr 25, 2019 at 3:22 PM
    ihatemytruck
    ihatemytruck Professional dumbass
    Dave
    Southern California
    '17 Tacoma 4x4 off road DCLB.
    OV tuned
    Change #4 to tactrix
  3. Apr 25, 2019 at 3:39 PM
    DuttonCD
    DuttonCD Well-Known Member
    Alabama
    2018 TRD OR CEMENT
    Ok
    Well I will try that tomorrow then.
  4. Apr 25, 2019 at 3:42 PM
    FritoBandito
    FritoBandito Well-Known Member
    Austin Texas
    2016 Limited 4X4 DCSB OV Tuned
    Thanks for the quick reply but I don't have a tactrix cable and it's not an option in my drop down menu. I don't have the OV Tune kit yet but am getting ready for it by applying the TSB first. Bought a cable off Amazon that works fine for everything but for some reason I'm not able to apply the TSB. GTSAPI_TGD.EXE got quarantined by McAfee during the TS install and I'm going to try to move it out of quarantine and back into the file system and see if that helps.
  5. Apr 25, 2019 at 3:54 PM
    Venator_2033
    I wouldn't use that cable to flash the tsb as you could brick your ecu, if you've already bought the kit and are waiting for it to come in the mail I highly recommend to just wait till then that way if something goes wrong you can unbrick the ecu yourself.
    taco abbo, MOC221_, SC4333 and 4 others like this.
  6. Apr 25, 2019 at 4:00 PM
    wiljayhi
    wiljayhi “Two wheel in, my son. Four wheel out.”
    Jim
    True North
    3rd Gen, Off Road, 6AT, (OVTuned)
    OVT1.05.1 87GL, MESO LED interior lights, MESO coin bucket, ScangaugeII, Weathertek floor liners,OEM running boards, mud flaps, OEM soft tonneau, Tacowiede radio knobs, MESO gasshole, Driver seat lift, Vehicle OCD glove box & console organizers, tailgate inserts.
    Next time have an opinion will ya?
    Neutron and TacoBella like this.
  7. Apr 25, 2019 at 4:24 PM
    xxTacocaTxx
    xxTacocaTxx Well Unknown Member
    ThreeOhThree.co
    2017 TRD OR DCLB 4x4 OMGWTFLOLBBQ
    RCI skid plates Mobtown sliders Lots of patches
    WTF can I not feed the trolls? Because someone is wrong on the internet and it's serious business.
    Friction with the inside of the wheel? You mean the drum, right? That's different.
    This is a problem how? To do any real service on disc brakes, you have to take the wheel off too.
    Both systems are hydraulic from the master cylinder to the wheel. Technically both are mechanical braking systems actuated via hydraulics, because the stopping action is created by pushing 2 surfaces together to create friction. Contrast that with regenerative breaking on a hybrid or EV, where kinetic energy is converted to electical energy by switching the electric motor into a generator.
    ABS can be used with either disc or drum brakes. ABS, VSC, ATRAC, MTS all use the same systems, so no clue why you mention ABS in this discussion.
  8. Apr 25, 2019 at 4:49 PM
    Shellshock
    Shellshock Guy who drives a lot
    Iowa
    2017 DCSB TRD OR MT QUICKSAND
    You kinda can. If you and try to read and it fails you are running some version of 1.05 cuz it’s read locked
  9. Apr 25, 2019 at 4:50 PM
    treimche
    treimche Well-Known Member
    Fargo, ND
    '17 Cement TRD Pro FOR SALE-PM ME
    @TacoBella I'm interested to hear more about switching from Tacoma to Ranger. I'm considering doing the same. Point me toward some info or PM me. Or just post here in this thread since its basically a giant cluster of everything the way it is.
  10. Apr 25, 2019 at 5:20 PM
    DES2009
    DES2009 Well-Known Member
    Southeast Louisiana
    2017 MGM Limited
    OVTune 1.05B(91)
    So if someone drives down your street and sees a piece of litter in front of your house...
    is it ok to dump a load of garbage on your from lawn?????
    Neutron, SC4333 and lapoltba like this.
  11. Apr 25, 2019 at 5:27 PM
    inksin
    inksin Well-Known Member
    Hawaii
    2016 Off Road access cab
    Also note that you may still be on 1.05 but they may have disconnected the battery to service the truck so your ECU would be relearning and maybe be driving all kinds of weird right now giving you the impression of being on a stock tune.
    MOC221_, ihatemytruck and TRDOBSESSED like this.
  12. Apr 25, 2019 at 5:39 PM
    lapoltba
    lapoltba Well-Known Member
    '17 Sport ACLB V6/6MT OV-Tuned
    I have the "x-horse" cable. It's pretty much garbage. Definitely get the Tactrix cable. If you don't want to buy the tune yet you can buy the cable direct, and message Matt @OVTune for the dicounted price since you already have the cable. You're doing the right steps, but your hardware is failing you.
    Heed this warning.... The Tacrix cable may seem expensive, but it is known good hardware and works. The Tactrix adapter isn't listed at the website suggested in the warning, but it is recommended by @OVTune, and of known good quality.
  13. Apr 25, 2019 at 5:56 PM
    FritoBandito
    Austin Texas
    Thanks for the advice. I plan on keeping this truck for a long time and hope to pass it on to my son who’s 5 now so I’m going to get the tune with the good cable. I’ll hold off on any flash attempts until I get the OV kit. Just waiting until my next paycheck.
    ihatemytruck, SC4333 and lapoltba like this.
  14. Apr 25, 2019 at 5:57 PM
    OVTune
    OVTune [OP] Well-Known Member
    OVTune
    Not to stir the pot in any way but you'll hate buying a ranger when you see the next gen tacoma.
  15. Apr 25, 2019 at 5:58 PM
    lapoltba
    It's well worth the wait. You were .5-1 min away from completing the TSB. Once you have the tune/kit it's not really a significant delay.
    FritoBandito likes this.
  16. Apr 25, 2019 at 5:58 PM
    lapoltba
    You're a god damn tease.
    paleh0rse, jholc21, chittyrox and 2 others like this.
  17. Apr 25, 2019 at 5:59 PM
    OVTune
    OVTune
    I know what it's coming with. That's all ;)
    Chipi3s, jholc21, hbaade and 6 others like this.
  18. Apr 25, 2019 at 5:59 PM
    SpeySquatch
    2016 TRD Off-Road DBLCB SB
    I’ll pay you to replace my rear drums. :D
    I boiled my fluid and my drums are out of round. The rear brake shoes turned blue. Since then have switched to DOT-4, higher boiling point and “feels” like it stops better
    Btw 91 base tune rocks!!!
  19. Apr 25, 2019 at 6:02 PM
    lapoltba
    So you're telling me that I shouldn't plan to keep my 3rd gen forever? That's it, no mods until 2nd year of 4th gen. and I can trade up.
    Cav_BluTRD and mZiggy like this.
  20. Apr 25, 2019 at 6:05 PM
    lapoltba
    You have drum brakes so you must not have ABS.
    Have you ever locked up your breaks and felt the ABS kick in? If not, Toyota and the NHTSA *must* be lying to you.
